2.5D tree rendering issue
General discussion on Thea Render for SketchUp
Moderator: Frederik
Postby KENTUCKY » Sun Jan 17, 2016 4:45 am
I am having trouble rendering 2.5D trees.
Clip mapping is correct.
When I render with IR presto modes I get black polygons where there are multiple transparent faces over top one another. With IR adaptive I get semi transparent faces.
The black polygons are not an entire face, just where the faces overlap in line of sight.
Everything renders fine with the non IR modes. Only have the black polygon issue with the IR modes.
I don't recall having this issue before.
Using latest version of Thea. Have tried on SU 2014, 2015 and 2016.
Have tried multiple trees, created by multiple people.
Any suggestions would be appreciated.
KENTUCKY
Premium Member
Premium Member
Re: 2.5D tree rendering issue
Postby cotty » Sun Jan 17, 2016 8:32 am
Usually, there are parameters like "tracing depth" or "transparency depth", have you tried to increase those?
cotty
Top SketchUcator
Postby KENTUCKY » Sun Jan 17, 2016 8:37 pm
Thanks for the suggestion.
While I was looking at the transparency depth, I ended up checking the extended tracing tab.
That took care of the problem.
Thanks again.
KENTUCKY
Premium Member
Premium Member
Return to Thea
