Animation plugin for thea / Sketchup?  Topic is solved
General discussion on Thea Render for SketchUp
Moderator: Frederik
Postby tallbridgeguy » Wed Nov 19, 2014 2:29 pm
Hi, I used to use keyframe animation with Thea for simple animations. (It still works great for sketchup animations and I like the plugin.)
Now the latest version of both Thea and Keyframe don't seem to work. Thea animation (Thea4SU) doesn't seem to understand turning on and off layers anymore.
So is there an reasonably priced plugin for animation that renders in Thea4Su? That allows layers to turn on and off? Any recommendations?
s
tallbridgeguy
Re: Animation plugin for thea / Sketchup?  Topic is solved
Postby tomasz » Mon Dec 15, 2014 6:03 pm
It is not a question of the animation plugin. "Thea for SketchUp" doesn't export animation frame by frame, but it exports whole model and all movement paths for camera and all objects. Such animation can be opened in Thea Studio afterwards and rendered there.
After a release of 1.4 version, which is coming shortly, I will have a look at rendering animation in SketchUp which would take layers visibility into account. This won't be exported to Studio though.
tomasz
SU2TH & SU2KT Developer
Postby duanekemp » Sat Jan 13, 2018 3:21 pm
Tomasz,
Is this still planned for the next upcoming version? "After a release of 1.4 version, which is coming shortly, I will have a look at rendering animation in SketchUp which would take layers visibility into account. This won't be exported to Studio though."
Duane Kemp
Kemp Productions
Puidoux, Switzerland
Gallery:
https://duanekemp.artstation.com/
duanekemp
Postby JQL » Sat Jan 13, 2018 6:22 pm
Thea 4 SU for long now supports animation plugins like Animator and Sketchy physics for instance.
JQL
Premium Member
Premium Member
Postby duanekemp » Tue Jan 16, 2018 6:55 pm
Yes... true. And somehow, I misread this post to include something additionally to the animation ability already introduced. I confused one issue with the ability to have motion blur... which I did not precise and is not yet implemented. Thanks for the confirmation. My hopes for the new version are spilling out in these old posts. :-)
Duane Kemp
Kemp Productions
Gallery:
duanekemp
Postby JQL » Wed Jan 17, 2018 12:04 am
Motion Blur is implemented. There's a cool helicopter animation example in Thea's site.
JQL
Premium Member
Premium Member
Postby duanekemp » Wed Jan 17, 2018 12:17 pm
Yes, but that was using Studio, not Thea for SketchUp.
Duane Kemp
Kemp Productions
Gallery:
duanekemp
Postby JQL » Wed Jan 17, 2018 4:48 pm
Ahh... I didn't know T4Sketchup didn't support it then. Don't do animations...
JQL
Premium Member
Premium Member
Postby NigeC » Thu Jan 18, 2018 12:12 pm
why do people say it doesn't work when it does, I have said it works elsewhere..
“It’s only impossible if you stop and think about it!”
NigeC
Postby JQL » Thu Jan 18, 2018 1:16 pm
There you have it... It seems Nige fixed it, so it works after all ;)
JQL
Premium Member
Premium Member
Postby NigeC » Thu Jan 18, 2018 1:43 pm
MsPhysics animation etc was one of the last things I beta tested... the pic used MSP which is what I'd use if something was spinning .. all I did was set the shutter speed to .8 and attached a motor to a wheel and recorded it.. I set it to render a Selected frame (10) so the motor had done accelerating
It should work with Fredo's animation plugin..
NigeC
Postby Frederik » Fri Jan 19, 2018 7:14 am
NigeC wrote:why do people say it doesn't work when it does, I have said it works elsewhere..
The motion blur option inside Thea Studio isn't implemented in T4SU, hence I've said it doesn't work inside T4SU...
What you're showing here is a workaround, where you've used MSP...
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby JQL » Fri Jan 19, 2018 9:09 am
Sorry Kim but what do you mean?
Nige just showed that as long as it is moving, it blurs.
JQL
Premium Member
Premium Member
Postby Frederik » Fri Jan 19, 2018 11:21 am
JQL wrote:Sorry Kim but what do you mean?
It was a simple answer to the question Nigec posted...
JQL wrote:Nige just showed that as long as it is moving, it blurs.
Yes, however, it's not the native Thea Render motion option/tool, since it's not available in T4SU, but only in Thea Studio...
Hence Nigec have used a workaround - in this case MsPhysics - to spin the wheel and then set the shutter speed so the render captures the motion blur created by MSP...
duanekemp wrote:I confused one issue with the ability to have motion blur... which I did not precise and is not yet implemented.
My answer was an answer to Nigec's question:
I simply wanted to be more specific and explain that the native Thea motion blur tool is still only available in Thea Studio...
Satisfied...??
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby NigeC » Fri Jan 19, 2018 12:09 pm
But it also works in Proper Animation.. or rather it did, it would seem support was dropped for that plugin, it no longer shows in the list of animation tools in thea4su .. I'm pretty sure Solo posted a picture of motion blur created with Animator
Honestly if I was doing a helicopter rotor spinning or a wheel I wouldn't use Animator, MSP you can adjust the speed on the fly without expanding the timeline
If I get time I'll update Animator and see if it works
NigeC
Postby NigeC » Fri Jan 19, 2018 12:35 pm
Animator and Thea4SU
I've never really used it, again I set the shutter speed low (0.8) and used the rotate option Animator has, I set the Render Frames, to Selected, the selected frame being 1
You don't need to create SU animated scenes, maybe this is were people go wrong, I have no idea
NigeC
Postby NigeC » Fri Jan 19, 2018 12:58 pm
here's the setup
NigeC
Postby duanekemp » Fri Jan 19, 2018 1:01 pm
Guys, this is very cool to follow! Thank you so much.
Duane Kemp
Kemp Productions
Gallery:
duanekemp
Postby NigeC » Fri Jan 19, 2018 1:18 pm
you're welcome..
With MSP you can play with the fps but Animator overrides it so you have to use the shutter speed, I find 1 and 0.8 seems a good ball park number.. you have to be careful as say 0.4 made the wheel appear static again
NigeC
Postby tomasz » Wed Feb 07, 2018 10:05 pm
The motion blur works in animation, because I export a full animation path to Thea.
It will not work when rendering frame by frame from Animator. When rendered from Thea's Animation tab it works just fine.
tomasz
Return to Thea
Users browsing this forum: No registered users and 5 guests
