[RV226.1165] Thea for SketchUp 2015 - 32/64-bit!
General discussion on Thea Render for SketchUp
Moderator: Frederik
Postby Frederik » Tue Nov 04, 2014 1:46 pm
Tomasz wrote:Hello All,
Here it comes a new revision of the plugin with a support for SketchUp 2015 x64
and bug-fixes:
- relative path support for loading and displaying external dependencies (/ModelName_files/ )
- fix for "Container" for Lights
- roughness control exposed for Colored Metal preset
- Thea Image removed from animation export options (not supported)
- FrontFace material is added only when necessary
- Default Preset handles correctly textured SU Material with alpha map AND opacity<1.0
- Display Settings show correct default values of Vignetting,Chroma,Contrast
- WhiteBalance checkbox is enabled when WB value changes
- fix for IR Preset first time modification for a SketchUp material #1274
Enjoy full memory address space with SU2015 64 bit!
Please visit our download thread (for licensed users only).
3
Cheers
Kim Frederik
User avatar
Frederik
Thea Render Support
Thea Render Support
Re: [RV226.1165] Thea for SketchUp 2015 - 32/64-bit!
Postby Rich O Brien » Tue Nov 04, 2014 1:55 pm
Sweet.
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby solo » Tue Nov 04, 2014 3:16 pm
Timing is everything.
User avatar
Global Moderator
Postby Mistro11 » Wed Nov 05, 2014 5:00 pm
I love the quick response to this. At first I thought I would have to wait a bit for Thea team to catch up but pleasantly found myself downloading all parts within the same hour. :thumb:
i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
Structural Integrity is Not Just Physical...It's in the Design and Purpose
User avatar
Mistro11
Postby tomasz » Fri Nov 07, 2014 12:51 pm
There is a small update in RV228. It is also available for all to test now!
tomasz
SU2TH & SU2KT Developer
Postby Krisidious » Fri Nov 07, 2014 1:02 pm
I'm totally jelly... No, like really. One of these days I'll have it.
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby hvanessen » Thu Nov 27, 2014 12:18 pm
Where can i find the thea render plugin for SU2015pro for 32 bit.
Because i can't find it
hvanessen
Postby Frederik » Thu Nov 27, 2014 9:50 pm
There's no separate installer for 32-bit...
It's the same as installer as for SU 2015 64-bit...
The installer should locate the version of SU you're running... :?
I'll have to ask Tomasz, as I don't know why you experience this...
Cheers
Kim Frederik
User avatar
Frederik
Thea Render Support
Thea Render Support
Postby Frederik » Fri Nov 28, 2014 10:32 am
Correction...
Tomasz wrote:There is no SU2105 32bit version in the installer.
Let me know, if you need 32bit version, please.
I suggest that you forward a PM to Tomasz at the Thea Render forum... :)
Cheers
Kim Frederik
User avatar
Frederik
Thea Render Support
Thea Render Support
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Thea
Who is online
Visit our sponsors:
