little help please
General discussion on Thea Render for SketchUp
Moderator: Frederik
little help please
Postby dgood133 » Mon Aug 16, 2021 4:25 am
I just bought a lic for Thea ver3
I want to remove the thea ver 2 for a clean install of 3 but I do not see anywhere online discussing this, including Altair's almost non existent support system for Thea.
can someone tell me #1 do I need to uninstall Ver2 and if so how...
SU 2021
win 10
Thanks in advance
D
dgood133
Premium Member
Premium Member
Re: little help please
Postby Rich O Brien » Mon Aug 16, 2021 9:55 am
Major versions should run separately as standalone render engines. Not sure if the SketchUp plugin for v2 and v3 can run in SketchUp though.
Did you got through Windows Control Panel to Add/Remove Programs?
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby duanekemp » Tue Sep 21, 2021 8:48 am
dgood133 wrote:I just bought a lic for Thea ver3
I want to remove the thea ver 2 for a clean install of 3 but I do not see anywhere online discussing this,...
D
Hopefully, you've discovered that both V2 and V3 can run on the same machine and that once V3 is installed, you'll even find the "switch version" option in the SketchUp Extension hamburger menu. No reason to uninstall V2. It's been since August that you posted this, so... I fairly certain you have already seen this, right?
Duane Kemp
Kemp Productions
Puidoux, Switzerland
Gallery:
https://duanekemp.artstation.com/
User avatar
duanekemp
Postby pbacot » Tue Sep 21, 2021 5:03 pm
Post on the Thea Site forum if you have more problems. I had an unusual crash problem with version three and Tomasz kept helping with me over email, providing special versions of Thea and utilities until it worked.
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Thea
Who is online
Users browsing this forum: No registered users and 2 guests
