Shape Bender producing 2D results
Postby mannequiin » Tue Jun 14, 2022 8:58 am
Good day. This is my first time using Shape Bender. I have done all that I can but cannot seem to surpass this issue. Whenever Shape Blender is applied there are no errors...just flat, 2D results.
mannequiin
Re: Shape Bender producing 2D results
Postby pilou » Tue Jun 14, 2022 9:41 am
Post your skp in v 2017! ;)
Top SketchUcator
Postby Box » Tue Jun 14, 2022 9:54 am
Looks like you posted the same image twice.
Postby pilou » Tue Jun 14, 2022 10:53 am
Else Shape Bender works fine like it must to do with a vertical flat group! :)
For avoid the big deformation of one part of the cross result
Take the same length of the horizontal cross'length than the length's Arc! :ugeek:
That is not the case here! :mrgreen:
Top SketchUcator
Postby pilou » Tue Jun 14, 2022 11:34 am
Maybe True Bend by Thomthom will be more suitable ?
Top SketchUcator
Postby mannequiin » Tue Jun 14, 2022 2:17 pm
My apologies! Here is the true before ans after:
mannequiin
Postby Box » Tue Jun 14, 2022 2:44 pm
You need to attach your model for us to give a full answer, but it looks like it is doing what you have told it to do.
Postby mannequiin » Tue Jun 14, 2022 2:44 pm
Here in the SKP in 2017.
I was following a tutorial and modified the form a bit to suit my own interests. In the tutorial, the individual is able to achieve a more 3-dimensional form, if you will
mannequiin
Postby Box » Tue Jun 14, 2022 2:52 pm
It's what I thought from your photo, the arc is on the wrong plan.
Postby mannequiin » Tue Jun 14, 2022 2:55 pm
Thank you so much for your quick response!
mannequiin
Postby mannequiin » Tue Jun 14, 2022 2:58 pm
Update: It worked beautifully!
mannequiin
Postby pilou » Tue Jun 14, 2022 5:31 pm
As said in my previous post you will have deformations! ;)
(needing or not, depending of the result really wanted! :)
Arc's length is 24,15 m
Line's length is 22, 94 m
So for a perfect result arc must be reduced! :ugeek:
Top SketchUcator
Postby pilou » Tue Jun 14, 2022 6:20 pm
About True Bend
You must make a component if you want a specific axis!
Top SketchUcator
Postby pilou » Tue Jun 14, 2022 6:43 pm
As True Bend works only Object by the middle maybe you can use this little trick! ;)
Open the component and add a little line! :ugeek:
Top SketchUcator
Return to Organic Modelling
