Grooves on cylinder surface?
Postby dragontech » Sat Jan 28, 2017 7:18 pm
Before I even ask my question, THANK YOU!
OK, so I have a cylinder shaped object and I want small grooves running up and down on the outside surface. Its the end cap for a nacelle. Is there a way to do this with the follow me tool or something? I could do it by hand, each groove, but being so small , I'd be in a nursing home by the time I finished, :roflmao:
User avatar
dragontech
Re: Grooves on cylinder surface?
Postby cotty » Sat Jan 28, 2017 8:53 pm
One quick way without plugins...
User avatar
cotty
Top SketchUcator
Postby dragontech » Sat Jan 28, 2017 9:10 pm
cotty wrote:One quick way without plugins...
Seriously.. Did you just do that to show me? You rock, either way. I have SU15 right now so it's not letting me open the file, (I need to upgrade I guess), so did you just draw the grooves?
Thank you for this. Just might work. :thumb:
User avatar
dragontech
Postby cotty » Sat Jan 28, 2017 9:23 pm
Here's the file as version 8.
User avatar
cotty
Top SketchUcator
Postby pbacot » Sat Jan 28, 2017 11:34 pm
IDK just how he did the grooves, but you could for example, just use two edgs in a "v" set to a facet in the circle, then copy/rotate all around.
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Postby dragontech » Sun Jan 29, 2017 12:08 am
pbacot wrote:IDK just how he did the grooves, but you could for example, just use two edgs in a "v" set to a facet in the circle, the copy/rotate all around.
I don't know how to do that but I'll check it out.
User avatar
dragontech
Postby cotty » Sun Jan 29, 2017 10:06 am
A little making-of...
User avatar
cotty
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Organic Modelling
Who is online
Visit our sponsors:
