Problems with polygons
Postby kellenraidfractal » Sun Aug 14, 2016 9:50 pm
I just downloaded and began to use SU2015. I cannot make a circle or other polygon. I did just what I did in earlier versions, but when I click to change the diameter, it disappears. Is there a setting I need to change?
kellenraidfractal
Re: Problems with polygons
Postby Box » Mon Aug 15, 2016 3:38 am
Firstly, if you are starting with something new, why aren't you using 2016?
Secondly, what do you mean when you say click to change diameter? What do you click and what disappears?
Postby baz » Wed Aug 17, 2016 12:49 am
kellenraidfractal wrote:I just downloaded and began to use SU2015. I cannot make a circle or other polygon. I did just what I did in earlier versions, but when I click to change the diameter, it disappears. Is there a setting I need to change?
Check your model units?
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
Return to Organic Modelling
