Model a boat from drawings
Postby Lersince1991 » Thu Apr 03, 2014 10:13 am
I have some drawings of a boat attached (dwg file/ my own work) and would like to make a rough 3D model of this for a scene. I don't want to spend too long on this and would prefer just a simple 3d form, doesn't have to be that accurate either! I can then project the side elevation onto both sides to give the look of a detailed 3D model.
How can I model this?
I can't think of any plug ins or approach to model this with?
Thanks,
Luke
Lersince1991
Re: Model a boat from drawings
Postby Box » Thu Apr 03, 2014 10:48 am
There are lots of tutorial around for modelling boats. You have all the profiles you need in your drawings. You can lay out the rib and skin it all or even as I have done below, just taken the three main profiles and used Tig's Extrude Edges by rails to produce a simple hull.
Basically, Beziers curves, curviloft and extrusion tools should be more than enough to get a nice finish.
User avatar
Postby pilou » Thu Apr 03, 2014 12:06 pm
And see this thread :)
By Axeonalias
Speedy Galerie
User avatar
Top SketchUcator
Postby Lersince1991 » Thu Apr 03, 2014 1:32 pm
Thanks for the helps up, already had TT extrude tools but never used the extrude edges by rails before.
Just a heads up, I had to 'weld' the imported profiles as the TT extrude wouldn't recognise them as curved before that.
A little fat at the middle but it will do!
That boat building process is amazing, god only knows how many hours he dedicated to that!!!
Cheers
Lersince1991
Postby Lersince1991 » Thu Apr 03, 2014 1:35 pm
And some wider context: boat repair workshop in sorrento, italy, (architecture university project)
Lersince1991
Postby Box » Thu Apr 03, 2014 1:41 pm
You can get a much more accurate finish if you use the ribs to skin it, but If you are happy with the results for what you need then all is well.
User avatar
Postby Lersince1991 » Thu Apr 03, 2014 2:33 pm
Yeah I thought about that but since I haven't got the ribs drawn and don't fancy spending the time to draw them I just used what I have :)
Lersince1991
Postby Box » Thu Apr 03, 2014 3:16 pm
Doesn't take much work.
One rib profile arrayed and scaled to fit, then curviloft to skin.
User avatar
Postby Lersince1991 » Thu Apr 03, 2014 3:43 pm
Oh that looks much better!
I've got curviloft too but didn't know I could skin that well with it!
Cheers, I'll give it another go when sketch up finishes its long intersect job...
Lersince1991
Postby cotty » Thu Apr 03, 2014 5:06 pm
Lersince1991 wrote:Thanks for the helps up, already had TT extrude tools ...
Extrude tools are from TIG and not TT.
User avatar
cotty
Top SketchUcator
Postby Lersince1991 » Thu Apr 03, 2014 5:24 pm
Ah ok easily confused with the amount of developers/plugins!
I did it with the loft by spline to skin the ribs in the end, worked out really well!
edit: added images
Lersince1991
Postby Box » Thu Apr 03, 2014 5:26 pm
That's the one, so it should look something like this.
Edit: Images look very nice. Well done.
User avatar
Postby garydorn » Thu Feb 25, 2016 3:28 am
User avatar
garydorn
Postby Clatu1234567890 » Sat Oct 01, 2016 5:22 am
pilou wrote:And see this thread :)
By Axeonalias
how u did this? v nice
Clatu1234567890
Postby Clatu1234567890 » Thu Oct 06, 2016 5:27 pm
Box wrote:There are lots of tutorial around for modelling boats. You have all the profiles you need in your drawings. You can lay out the rib and skin it all or even as I have done below, just taken the three main profiles and used Tig's Extrude Edges by rails to produce a simple hull.
Can you please help me to draw this fishing boat?
Clatu1234567890
Re: Model a boat intuitively in terms of spatial contours
Postby bambutec » Fri Apr 20, 2018 12:13 pm
Hi Guys,
m trying to create a hull from my imagination, means not from given contours.
Boat contour plans are actually a projection to the standard orthogonal planes,
, these are sections through the hull, which would not be applicable for this intuitive process.
I have a certain spatial curve in the mind, which I´d like to draw in SU.
So I created contour lines f.e. as a bezier curve.
But, the curves are always related to a plane. It is anyway difficult to intuitively draw a spatial curve.
Now m looking for a way how to create a spatial contour from two related planar contours.
I guess it sounds a bit confusing. Does anybody have a solution for this ?
Thanks for responding !
bambutec
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Organic Modelling
Who is online
Visit our sponsors:
