Simple Artisan examples collection
Re: Simple Artisan examples collection
Postby john2 » Sat Nov 29, 2014 11:22 am
This is really awesome. Can you explain the procedure for making this please? :thumb:
john2
Postby Hieru » Sat Nov 29, 2014 11:37 am
The modelling stages illustrated are pretty straightforward. Is there a particular stage you don't understand?
Hieru
Premium Member
Premium Member
Postby baz » Sat Nov 29, 2014 1:42 pm
Yes it is quite awesome. Perhaps you could tell us which parts of the 'procedure' that you are wanting?
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
Postby john2 » Sun Nov 30, 2014 4:15 pm
Hexagonal chain onwards, it was rotated and copied around a central axis,. Then what happened? You did a joint push pull I suppose, but how did the final outcome, the bend occur?
john2
Postby olishea » Sun Nov 30, 2014 7:01 pm
Free Form Deformation plugin. FFD. A classic.
Could also do it with a couple of other plugins.
There are some other similar things on this thread:
viewtopic.php?f=333&t=50584
oli
olishea
Premium Member
Premium Member
Postby Rich O Brien » Mon Dec 01, 2014 12:54 pm
Click image....
Click Image...
3
Rich O Brien
Administrator
Postby mitcorb » Mon Dec 01, 2014 1:04 pm
Very nice, Rich:
Which viewer is this?
mitcorb
Top SketchUcator
Postby Box » Mon Feb 16, 2015 3:19 am
I was just fiddling with some ideas while eating lunch and thought it might fit this thread.
I wanted a solid egg shape with pulled legs.
I can make it in glass, I just wanted to see if I could model and effectively show it.
So a very quick model, and an equally quick render.
The whole thing could have been done in a 30min challenge.
So here's the proxy and the artisan result.
And a very fast Twilight render.
Postby pilou » Mon Feb 16, 2015 3:23 am
Philippe Stark revival! :)
Speedy Galerie
Top SketchUcator
Postby cotty » Mon Feb 16, 2015 7:20 am
Nice example, Box!
cotty
Top SketchUcator
Postby panixia » Tue Feb 17, 2015 2:25 pm
really nice.. just try to achieve a bit cleaner topology in the bottom to avoid those little smoothing artifacts.. :thumb:
panixia
Postby Box » Tue Feb 17, 2015 2:39 pm
I'm not quite sure which artifacts you mean but I deliberately wanted to create the stretch you get when you pull hot glass.
I took this another step further and made the full Faberge/Stark lemon juicer with a turned wood base. The glass picks up the wood texture nicely.
The client specifically asked for something earthy with a modern feel and mentioned both Faberge and Stark and then threw in "but we love oriental Lacquer-ware". They looked at this today and said when can we have it.
5
Postby Rich O Brien » Tue Feb 17, 2015 2:42 pm
wow!
can you wing me the proxy?
Rich O Brien
Administrator
Postby Box » Tue Feb 17, 2015 2:53 pm
If by the proxy you mean the rough before subdivide and smooth, No, fraid not, I'm far too casual to keep that. If I don't like something I start again or go back. Once it's working I move ahead so all I have is the model.
Postby Rich O Brien » Tue Feb 17, 2015 3:40 pm
it's ok. i just wanted to have a doodle....
Rich O Brien
Administrator
Postby panixia » Wed Feb 18, 2015 8:04 pm
Box wrote:I'm not quite sure which artifacts you mean
i mean the subdivision artifacts between the legs and the base wich usually can be simply avoided doing exactly what rich did with those control loops..
panixia
Postby cotty » Wed Feb 18, 2015 10:29 pm
panixia wrote:i mean the subdivision artifacts between the legs and the base wich usually can be simply avoided doing exactly what rich did with those control loops..
He did this intentionally...
Box wrote: I deliberately wanted to create the stretch you get when you pull hot glass
I think he reached a realistic effect in this special case. :thumb:
cotty
Top SketchUcator
Postby Box » Thu Feb 19, 2015 1:45 am
Thanks Cotty, Yes, I'm fully aware of how to make the faces flat or regular. That's not what I wanted, so they aren't Artifacts they are design decisions.
Look at the shape you get when you pull a spoon out of thick honey, it's a fluid solid and behaves in a very particular way. The surface tension isn't uniform so you get stretching.
Postby solo » Thu Feb 19, 2015 1:55 am
Rich O Brien wrote:it's ok. i just wanted to have a doodle....
Blender?
http://www.solos-art.com
solo
Global Moderator
Postby pilou » Thu Feb 19, 2015 10:03 am
Ultra nice! :fro:
Speedy Galerie
Top SketchUcator
Postby panixia » Thu Feb 19, 2015 12:07 pm
Box wrote:Thanks Cotty, Yes, I'm fully aware of how to make the faces flat or regular. That's not what I wanted, so they aren't Artifacts they are design decisions.
ok if it's intentional and you are happy with thw result that's fine :thumb:
i was only pointing it in case you did'nt know of the control loops stuff, when you know what you are doing, "rules" can be broke here and there :enlight:
panixia
Postby Hieru » Fri Feb 20, 2015 11:40 am
panixia wrote:i was only pointing it in case you did'nt know of the control loops stuff, when you know what you are doing, "rules" can be broke here and there :enlight:
Makes sense to me.
Molten glass has a much greater surface tension than something like honey, so whilst you will get deformation when pulling away gathers of glass, flat surfaces will tend to remain pretty even.
If I was modelling this I would add control loops and then move their position to allow for varying degrees of deformation/stretch.
I'd forget about actually making it in glass as it would be an absolute nightmare. Pulling multiple gathers off the plate whilst maintaining it's shape is one thing, but then adding in a pre-blown centre piece and twisting the gathers before everything collapses is insane....and then you'll have to keep everything in place whilst reheating the plate so that it will form-fit with the wood.....aaaarghhhh!!!!
Hieru
Premium Member
Premium Member
Postby Box » Fri Feb 20, 2015 11:51 am
Obviously my 35 years of working with molten glass are meaningless.
Postby Rich O Brien » Fri Feb 20, 2015 12:40 pm
solo wrote:Blender?
yes, and rendered using freestyle edges
Rich O Brien
Administrator
Postby Hieru » Fri Feb 20, 2015 2:41 pm
Box wrote:Obviously my 35 years of working with molten glass are meaningless.
Pretty sure I didn't say that or give cause for you to take offence.
If you aren't bothered about the topology and the model/render works for your purposes, then you've done a good job. I was just offering some friendly advice on how you could improve the model next time around.
And just because I can see the difficulty in making the design in reality, it doesn't follow that I think you don't know what you are doing and you are not up to doing the job.
Hieru
Premium Member
Premium Member
Postby Box » Fri Feb 20, 2015 4:05 pm
I must have a better look at Blender when I have time.
Postby panixia » Thu Feb 26, 2015 11:45 am
quadface/vertextools training.. work in progress.. 8-)
any good reference for ear topology?
panixia
Postby baz » Thu Feb 26, 2015 12:08 pm
panixia wrote:quadface/ 8-)
Pardon, could you say that again?
baz
Postby olishea » Thu Feb 26, 2015 1:28 pm
oli
olishea
Premium Member
Premium Member
Postby baz » Thu Feb 26, 2015 1:58 pm
Ah...thanks Oli, I woz a bit sarcastic, as in simple aritsan examples. Go for it tho, its educational :)
baz
PreviousNext
Return to Organic Modelling
