More Characters
More Characters
Postby solo » Sun Dec 19, 2010 9:03 pm
Playing again, a quick Odie. I used SDS2, FFD and TOS.
And for those proxy junkies, here is the basic form.
http://www.solos-art.com
solo
Global Moderator
Re: More Characters
Postby liam887 » Sun Dec 19, 2010 9:12 pm
Awesome! I cant wait for SDS2!!! :D :D :D :D :D :D
VISIT MY ONLINE GALLERY
liam887
Re: More Characters
Postby Rich O Brien » Sun Dec 19, 2010 10:14 pm
Excellent Pete :thumb:
For the render/line overlay, what was the studio setup?
Rich O Brien
Administrator
Re: More Characters
Postby solo » Sun Dec 19, 2010 10:17 pm
I used Thea, posed in SU, exported the line image, opened same camera in Thea, added shadow catcher inifite plane, added HDRi image for reflection and white background (just a white .jpg I created in PS)
Combines using 'multiply in PS...done.
solo
Global Moderator
Re: More Characters
Postby Rich O Brien » Sun Dec 19, 2010 10:32 pm
It was the White BG that i needed to know. Was the infinite plain a Diffused White? I really like that setup :thumb:
Rich O Brien
Administrator
Re: More Characters
Postby pilou » Mon Dec 20, 2010 12:47 am
Very cool Toon Dog :enlight:
Does the new SDS2 has a Points/faces/polygons counter visible on the screen?
Top SketchUcator
Re: More Characters
Postby solo » Mon Dec 20, 2010 4:05 am
It's Odie, from Garfield. :mrgreen:
solo
Global Moderator
Re: More Characters
Postby michaliszissiou » Mon Dec 20, 2010 1:23 pm
Nice dog.
Well done Pete, :berserk:
Crits? Too many polys (but its OK here) much stretching on ears area, not the best for UVs.
michaliszissiou
Re: More Characters
Postby Frederik » Mon Dec 20, 2010 4:10 pm
solo wrote:...exported the line image...
I've never figured how to do this...
Please enlighten us mortals...
If I export a line image, the background will not be transparent...
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Re: More Characters
Postby Rich O Brien » Mon Dec 20, 2010 4:13 pm
I presume he sets the blend mode to overlay in Photoshop? That's what i do anyway :oops:
Rich O Brien
Administrator
Re: More Characters
Postby solo » Mon Dec 20, 2010 4:16 pm
@michal, Poly count is no issue, I dont mind high poly models, I use a studio renderer so that hurdle is overcome. I used FFD on ears so yes I stretched the mesh.
@Frederick and Rich, I use a white background when rendering so exporting SU lines with a white background actually helps, in PS I use 'multiply' for blend, makes lines pop better.
solo
Global Moderator
Re: More Characters
Postby jeff hammond » Mon Dec 20, 2010 4:37 pm
Frederik wrote:If I export a line image, the background will not be transparent...
if you export a tiff or png which support transparency then click 'transparent background' in the export options.
[though i'm thinking this may be a mac only feature?]
dotdotdot
jeff hammond
Global Moderator
Re: More Characters
Postby solo » Mon Dec 20, 2010 4:39 pm
Mac only... :mrgreen:
See, there is a reason for owning a Mac. ;)
solo
Global Moderator
Re: More Characters
Postby Rich O Brien » Mon Dec 20, 2010 4:40 pm
What is it? You can it disappear into the BG
Rich O Brien
Administrator
Re: More Characters
Postby Frederik » Mon Dec 20, 2010 4:40 pm
solo wrote:@Frederick and Rich, I use a white background when rendering so exporting SU lines with a white background actually helps, in PS I use 'multiply' for blend, makes lines pop better.
Cheers, Pete...
Just thought you had a trick in your sleeve to export the lines with transparent background, but blending using 'multiply' works just fine... :thumb:
Edit: I knew I had seen somewhere that you're able to get transparent background on a Mac...
Well, well... thomthom's Export 2d with Alpha can make similar png's for us depending on Windows... :P
Unfortunately only the background will be transparent and not objects (not even if you paint them in the same color as the bg)...
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Re: More Characters
Postby michaliszissiou » Mon Dec 20, 2010 10:50 pm
Multiply works fine, no need for transparent background.
If you want transparent or semi transparent exports (lets say window glass etc) apply a strong color (pure magenta or green) then use it as mask in Ps. ;) A nice way for fake reflections in PP.
michaliszissiou
Re: More Characters
Postby Chris Fullmer » Tue Dec 21, 2010 1:59 am
solo wrote:Mac only... :mrgreen:
Actually, that is no longer true. I think since they re-built the SU render engine in 7.1, PC has been able to export transparent png's.
All my Plugins I've written
SketchUp Team
SketchUp Team
Re: More Characters
Postby Frederik » Tue Dec 21, 2010 1:47 pm
Chris Fullmer wrote:Actually, that is no longer true. I think since they re-built the SU render engine in 7.1, PC has been able to export transparent png's.
Please elaborate and post some screen shots, Chris...
Cause I sure can't find this in the option menu...
I've tried both tif and png - and I don't see any option for selecting transparent background...
Frederik wrote:Well, well... thomthom's Export 2d with Alpha can make similar png's for us depending on Windows... :P
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Re: More Characters
Postby michaliszissiou » Tue Dec 21, 2010 11:15 pm
Really Frederik, you don't need this much. You may need to mask some glass windows too, transparency doesn't help much there. Try to assign a pure green or magenta instead. Ps can do miracles this way. From a mac user anyway.
michaliszissiou
Re: More Characters
Postby Frederik » Wed Dec 22, 2010 9:56 am
I know, michalis...
I can make incredible things in post pro with PS for Win... :)
I also know about the work arounds, but if I can avoid them, it would be great...
Chris F. states that transparent background is possible with SU for Win since ver. 7.1 but I can't find how/where, hence my question to Chris to post some screen shots...
Well, well... I don't want to hijack this thread... :)
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Re: More Characters
Postby Gaieus » Wed Dec 22, 2010 12:11 pm
I'd also be curious, Chris. What beta build are you using?
:lol:
Re: More Characters
Postby Chris Fullmer » Thu Dec 23, 2010 9:30 am
This is bizarre - is it seriouslly not possible? I swear I've done this a dozen times in the last week. Even wierder is I'm sure it was Gaieus who corrected me last time I said the same thing as Solo. I think I'm experiencing early onset dimentia. I suddenly am unsure of everything.
I'm on vacation now and I don't have access to SU at the moment. So when I can play with SU, I'll test it. so weird....... :?
SketchUp Team
SketchUp Team
Re: More Characters
Postby Gaieus » Thu Dec 23, 2010 3:41 pm
First, there is no checkbox for transparent background at all so I cannot set it. When I export (even with sky and ground turned off), the white background appears, too.
I can of course export with transparent background from LayOut.
Re: More Characters
Postby Frederik » Thu Dec 23, 2010 6:35 pm
Gaieus wrote:First, there is no checkbox for transparent background at all so I cannot set it. When I export (even with sky and ground turned off), the white background appears, too.
Thanks for confirming this, Csaba... :thumb:
Gaieus wrote:I can of course export with transparent background from LayOut.
I have ver. 7 Pro, but I haven't upgraded ver. 8 to Pro... :oops:
Besides, I've never really used LayOut...
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Re: More Characters
Postby solo » Fri Dec 31, 2010 1:07 am
Back to topic, more characters, this is a WIP, still got more face detail to do, it's supposed to be... why don't y'all guess, that way I know how bad it is.
solo
Global Moderator
Re: More Characters
Postby Whaat » Fri Dec 31, 2010 1:39 am
Looking good, solo! Was most of this model created with the SDS2 sculpt tool? Or did you use your proxy/subdivision workflow?
Whaat
PluginStore Author
PluginStore Author
Re: More Characters
Postby solo » Fri Dec 31, 2010 1:42 am
Proxy base, then divide,sculpt,divide,smooth, I know it sounds like a silly workflow but once SDS2 is released most folk will understand.
solo
Global Moderator
Re: More Characters
Postby Rich O Brien » Fri Dec 31, 2010 1:58 am
Did Richard Prior and Kevin Spacey have a love-child?
Rich O Brien
Administrator
Re: More Characters
Postby EarthMover » Fri Dec 31, 2010 3:46 am
Hmmm....it's either Obama or Robert Downey Jr's character in Tropic Thunder. :D
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Re: More Characters
Postby SketchUpNoobie » Fri Dec 31, 2010 3:46 am
Obama!!!
*ducks for cover*
:lol:
Edit: Aww, Adam beat me to it.
SketchUpNoobie: the complete noob in all things SketchUp.
SketchUpNoobie
Next
Return to Organic Modelling
