Lotus 49
Lotus 49
Postby Mike Amos » Sat Jun 04, 2022 10:48 pm
G'day folks,
Probably a long termer. Much detail that changes with the car you look at. Far too many changes to list here.
As far as the wire guards on the inlet trumpets go, the extent of mapping I have is overwhelmed and geometry is not working at the moment.
Premium Member
Premium Member
Re: Lotus 49
Postby ntxdave » Sun Jun 05, 2022 12:04 am
I have to ask, is this a photo you are using for reference or you model? If it is your model, I am blown away!
ntxdave
Re: Lotus 49
Postby tuna1957 » Sun Jun 05, 2022 12:32 am
I want to see more :roll: :thumb:
tuna1957
Premium Member
Premium Member
Re: Lotus 49
Postby Mike Amos » Sun Jun 05, 2022 12:39 am
Thanks folks, it's a model, no more than ten percent on.
Premium Member
Premium Member
Re: Lotus 49
Postby Bryan K » Sun Jun 05, 2022 1:20 am
That's the model? I also thought it was photo reference.
This is going to be good! :thumb:
Premium Member
Premium Member
Re: Lotus 49
Postby Mike Amos » Sun Jun 05, 2022 11:10 am
Thanks, I hope so. Like you I get memory issues slowing stuff down.
Premium Member
Premium Member
Re: Lotus 49
Postby L i am » Sun Jun 05, 2022 12:25 pm
That looks really exiting Mike, what renderer are you using?
Premium Member
Premium Member
Re: Lotus 49
Postby Mike Amos » Sun Jun 05, 2022 5:53 pm
Thanks mate, Twilight V2 Pro. Slow process.
Premium Member
Premium Member
Re: Lotus 49
Postby L i am » Mon Jun 06, 2022 7:54 am
Hi Mike
You may already have some texture but here are some PBR textures, https://www.sketchuptextureclub.com/tex ... es?n=S&m=S
I usualy find if the texture are applied in the render engine and not in SU it maps correctly
Premium Member
Premium Member
Re: Lotus 49
Postby Mike Amos » Fri Jun 10, 2022 3:26 pm
Ta mate. :thumb:
Premium Member
Premium Member
Re: Lotus 49
Postby Bryan K » Tue Jun 21, 2022 5:37 am
Don't keep us hanging! This was one of my favorite cars! Really looking forward to progress updates!
Premium Member
Premium Member
Re: Lotus 49
Postby Mike Amos » Tue Jun 21, 2022 11:12 am
I finally found a decent rev counter (Smith's instruments 12,000rpm) so hopefully I can move on with the dashboard/instruments. Engine details have been tough to find with depictions stated to be for 1967 actually referencing a 1973 engine which is wrong for this car. The 1973 car has the low mounted 'Wings'..
Premium Member
Premium Member
Re: Lotus 49
Postby Mike Amos » Sat Jun 25, 2022 10:32 pm
Well, trying to clean up inside the jam jar, annoying. Starting to run into some serious glitches which I will have to work at to clear.
Premium Member
Premium Member
Re: Lotus 49
Postby tuna1957 » Sat Jun 25, 2022 10:51 pm
Progress is a good thing :thumb:
tuna1957
Premium Member
Premium Member
Re: Lotus 49
Postby Bryan K » Sun Jun 26, 2022 3:12 am
Better and better. Nice! :thumb:
Premium Member
Premium Member
Re: Lotus 49
Postby L i am » Sun Jun 26, 2022 7:21 am
Lovely work Mike :thumb: :thumb:
Premium Member
Premium Member
Re: Lotus 49
Postby Mike Amos » Sun Jun 26, 2022 9:33 am
Thanks folks, getting closer to the correct geometry for the centre cab. I guess number 20 is the charm.
Premium Member
Premium Member
Return to WIP
