The Nadesico A
The Nadesico A
Postby Bryan K » Tue Mar 08, 2022 5:09 am
Next up , the Nadesico (A). This one is going to take a while. It has a lot of very deceptive curves and I have nothing to scale it against yet.
If you have not seen this anime, it's pretty funny and old school anime corny. You can watch it for free on Retrocrush.
If this goes well, I'll do the Nadesico B.
Premium Member
Premium Member
Re: The Nadesico A
Postby Rich O Brien » Tue Mar 08, 2022 2:59 pm
https://otakuhq.com/figures/10375
When it comes to this type of project I like to see if there's Airfix models on ebay.
In the link above there's some nice pics to use for reference
Rich O Brien
Administrator
Re: The Nadesico A
Postby Bryan K » Wed Mar 09, 2022 12:56 am
Rich O Brien wrote:https://otakuhq.com/figures/10375
FANTASTIC! Thanks!
That will help immensely!
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Thu Mar 10, 2022 6:06 am
Found the original drawings and now have a very close scale.
Premium Member
Premium Member
Re: The Nadesico A
Postby Mike Amos » Thu Mar 10, 2022 11:34 am
A great subject you have there, with you eye for detail it is going to be interesting for sure. :thumb:
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Sat Mar 12, 2022 4:10 am
First block-out.
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Thu Mar 17, 2022 4:30 am
:lol: :lol: :lol:
Yeah, this one is going to take a while.
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Mon Mar 21, 2022 7:03 am
I dunno. It's close, but not quite there.
It looks more curved in the anime, but the model reference shows it as more angular. I'm going to go with the angular and ditch this curving modeling.
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Wed Mar 23, 2022 3:20 am
I've almost got head wrapped around this.
Premium Member
Premium Member
Re: The Nadesico A
Postby L i am » Wed Mar 23, 2022 11:32 am
I generally am not so interested in anything other than Architecture or Landscape. But I am looking forward to seeing the progress on this project :)
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Thu Mar 24, 2022 2:07 am
Finally some real progress. Not much to look at, but the overall profile of the nacelle is good.
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Thu Mar 24, 2022 2:15 am
Started with this shape.
Then +Push/Pull and resized each face along the profiles. Now need to do the indents. Still needs some tweaking on the shape. I see one profile out of alignment.
Premium Member
Premium Member
Re: The Nadesico A
Postby Mike Amos » Thu Mar 24, 2022 1:32 pm
Nice mate, on a roll. :thumb:
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Sat Mar 26, 2022 5:48 am
Thanks Mike!
Same technique for rear half of the front nacelles. Started with the same shape, +Push/Pull following the profile working backwards. Make component, then mirror the copies.
Tweaked the front a bit more. Will stop here and and reference the images and tweak before building more shapes.
The issue I'm seeing is the drawings are just slightly different from the actual model kit, so I'm going to end up with a hybrid because each reference offers details the other doesn't. The shape and scale will be exact, but minor detail like curves and angles are going to differ. So I'm going to have to find a middle ground. But I'm going to default to the drawing and anime references when in doubt. Hence, the nose is more rounded than the model kit, yet more angular than the drawing.
LOL. No wonder I've only seen one CG model of this ship and references were hard to find. It's a crazy design!
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Sun Mar 27, 2022 2:36 am
Coming along.
I tweaked the nose some more. Slightly flattened the curve and made it slightly wider again toward the point.
I +Push/Pull'd the vertical profile through the component and then intersected (Selection ONLY). Had to erase a LOT of hidden lines after. Then copy and cut the lines I wanted and pasted into nacelle component and then closed some small gaps, but this worked out as I wanted.
Premium Member
Premium Member
Re: The Nadesico A
Postby tuna1957 » Sun Mar 27, 2022 7:36 pm
Great progress :thumb:
tuna1957
Premium Member
Premium Member
Re: The Nadesico A
Postby Mike Amos » Mon Mar 28, 2022 12:25 pm
^ Agreed mate, he knocks out great product. :thumb:
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Tue Mar 29, 2022 9:00 pm
Thanks tuna. Thanks Mike. :thumb:
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Sat Apr 02, 2022 9:45 am
Not much to look at but I had to narrow the top crest/ridge and then adjust each section to curve smoothly. I scaled the top rectangle and then used the move tool to adjust each vertices intersection to flow into the lower wider sections. (remember, I'm using components so I only have to do one to get the other three to match. This model now has 8 quarter panels. 4 for the front section and 4 for the rear)
I also had to narrow the very back faces as well and make them more square.
Tedious, but I have to get the proportions perfect before I commit to the phase of push out of the sides or I'll be push/pulling vertices for ages later on.
Still more tweaking before I do the side push out.
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Sun Apr 03, 2022 12:55 am
Again, not much to look at, but the details are tough on this one.
Rounded the leading face of the crest/ridge. This took days to figure out because it's narrow at the top and wide at the bottom AND the profile has a slight curve. WHEW!
Changed the nose detail. There were several different versions, but this was the most common one used.
Now for the issue that will NOT be fixed. The outer edges of all the main shapes have a slight beveled/rounded edge to them. This will not be included. I cannot be done on this model due to many of the faces having 3 vertex points. I will still do edge breaks where possible.
The reason for the 3 vertices on a single point is the old "twisted trapezoid" shape so many designers like to use. Take a trapezoid, then slightly twist one edge. This causes triangle faces to be created to fill in the outline with a face. This prevents ANY type of "follow me" or edge modifications without a ridiculous number of more lines and connecting vertices. Which of course, makes the model bigger and does not guarantee a better look at the smaller scales.
So I'm skipping it unless absolutely necessary. It should still look good. After all, this is a hybrid model to begin with and will make the fifth version in existence.
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Sun Apr 03, 2022 1:10 am
Overview to date.
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Sun Apr 03, 2022 4:37 am
Some minor tweaking and detail left and the forward nacelles are done.
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Sun Apr 03, 2022 4:39 am
2 more views. And one of the geometry. The crazy, crazy geometry.
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Sun Apr 03, 2022 8:50 am
Details completed. I'm happy with it.
I had to fiddle with the vertex lines, swapping one point to point for the reverse to flip the triangles and smoothing out other faces as best as possible.
Also had to make the rear section with the holes a unique component as the other three quarter sections do not have those holes. Drew the holes with Tools on Surface, then indented push/push with Joint Push/Pull tool.
Premium Member
Premium Member
Re: The Nadesico A
Postby HornOxx » Sun Apr 03, 2022 1:17 pm
Bryan, these kind of procedural stories are your brand here and I love them! :thumb:
never trust a skinny cook
HornOxx
Re: The Nadesico A
Postby Bryan K » Sun Apr 03, 2022 7:58 pm
Thanks HornOxx! It was something I picked up from previous members years ago and it helped me to improve my modeling ability, so I do it hoping it helps others.
Gah! Almost one month to make just this section. To be fair, I have a new job, and my pollen allergies have been bad as well, so there is that.
On to the next section!
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Sun Apr 03, 2022 7:59 pm
L i am wrote:I generally am not so interested in anything other than Architecture or Landscape. But I am looking forward to seeing the progress on this project :)
Thanks L i am! Sorry I didn't reply earlier. I was busy with my new job and my spring time allergies have been kicking my but. Sorry I missed your post.
Premium Member
Premium Member
Re: The Nadesico A
Postby Rich O Brien » Sun Apr 03, 2022 8:55 pm
Its a real shame there's so little reference for this craft.
So far its been a pleasure to follow.
Rich O Brien
Administrator
Re: The Nadesico A
Postby Bryan K » Sun Apr 03, 2022 10:05 pm
Thanks Rich!
The shapes of this are so deceptive. I thought it would be easier, especially after you helped with those great kit references.
This one is going to take a while. I bit off a lot here.
Premium Member
Premium Member
Re: The Nadesico A
Postby Bryan K » Thu Apr 07, 2022 2:36 am
Forward nacelle support pylons. Just rough in place holder for now until I model the main lower hull.
Premium Member
Premium Member
Next
Return to WIP
