Spaceship time again!
Re: Spaceship time again!
Postby Bryan K » Sun Mar 26, 2023 3:16 am
Got to think about this a few more days. Not feeling it.
User avatar
Premium Member
Premium Member
Postby Bryan K » Wed Mar 29, 2023 3:18 am
I've sliced the tail. I see a difference from the original right away, but I may just go with it. I'm noticing more and more impossible geometry of the original.
But that's OK. I may be doing more skin re-curving later.
I also changed the angle of the slice and then scaled (shortened) the vertical of the lower fuselage.
It appears I'll have to make initial slices, then build out the engine pods things, and THEN re-curve the skin to the added geometry.
User avatar
Premium Member
Premium Member
Postby Bryan K » Fri Mar 31, 2023 2:41 am
So a little bit of squashing and scaling and then slicing and I'd say I'm in the ballpark.
Fiddled with the cockpit some more and I think I've got it. Now on to the engines.
User avatar
Premium Member
Premium Member
Postby tuna1957 » Fri Mar 31, 2023 2:55 am
Nice progress :thumb:
tuna1957
Premium Member
Premium Member
Postby Mike Amos » Fri Mar 31, 2023 1:19 pm
^ Agreed mate. Nice progress, Bryan. :thumb:
Premium Member
Premium Member
Postby Bryan K » Fri Mar 31, 2023 11:58 pm
Thanks mike!
Thanks tuna!
Not really much to look at right now.
I've been busy with other things and no real time to work in this.
User avatar
Premium Member
Premium Member
Postby L i am » Sat Apr 01, 2023 8:34 am
Nice work mate, I have a new job thanks to sketchup and am pretty busy so I am not very active here much. But I occasionally have a quick look into what's going on in sketchucation forums, but I always need to check out the progress of your work on this project. :thumb: :thumb:
Premium Member
Premium Member
Postby Bryan K » Sun Apr 02, 2023 1:34 am
Thanks L i am. I'm anxious to move ahead with this, but I'm just too busy.
User avatar
Premium Member
Premium Member
Postby Bryan K » Mon Apr 03, 2023 10:12 pm
L i am wrote:Nice work mate, I have a new job thanks to sketchup and am pretty busy so I am not very active here much. But I occasionally have a quick look into what's going on in sketchucation forums, but I always need to check out the progress of your work on this project. :thumb: :thumb:
And congratulations on your new job! :thumb: :thumb:
User avatar
Premium Member
Premium Member
Postby Bryan K » Fri Apr 07, 2023 3:47 am
This is the framework I'll use. Just rough blocking right now. I intend to use the vectors of the hull to "smooth" it all together.
Checking scale and rough postition right now. I'll probably do what I did with the Nadesico and rough it in, then start adding more lines as needed, moving vector points until it smooths out. Or Curviloft or Artisan, depending on situation. Or some combination of all.
Had to shorten the back end some more. Horizontal scale front to back.
Wanted to work on it a lot more tonight, but a bad storm is in the region. Can't chance a power flicker.
User avatar
Premium Member
Premium Member
Postby Mike Amos » Sat Apr 08, 2023 8:23 pm
Moving on very nicely mate. :thumb:
Premium Member
Premium Member
Postby Bryan K » Fri Apr 14, 2023 2:43 am
Mike Amos wrote:Moving on very nicely mate. :thumb:
I'm having to think this one through because once I commit to the rear shapes, there is no going back. I will of course save this stage of the model and use a copy, but there will be so many steps to getting the shapes to flow together that it will not be salvageable and I'll have to revert back to this shape and start again.
And right now, I don't have time.
Usually I do have time and just bull on through until I get it. But right now I can't.
Which may be a fancy way of saying I'm procrastinating, but for reasons! :lol:
User avatar
Premium Member
Premium Member
Postby Bryan K » Sat Apr 15, 2023 6:47 am
I'm getting closer. But still have a long way to go. The lines are still off. I have no problem seeing it in my head, but getting SU to cooperate is a different story. :lol:
User avatar
Premium Member
Premium Member
Postby ntxdave » Sat Apr 15, 2023 3:47 pm
Educate me. Where do you get the info to do models like this?
User avatar
ntxdave
Postby Bryan K » Sat Apr 15, 2023 7:04 pm
ntxdave wrote:Educate me. Where do you get the info to do models like this?
I just google search images for random spaceships.
As for modeling, it's straight up trial and error and more years than I care to admit for not being any better than I am.
But mostly, just slinging lines and faces around until it works. Or doesn't.
I do use Curviloft and Soap bubble and Artisan and Tools on Surface, but more often it's just connecting lines and arcs and moving vector points by hand. Move tool, grab vector intersection, move.
If I was better with Artisan, I could cut my modeling time in half. I see what it can do, but I can't seem to grasp the number of triangles needed to produce the desired results. Yet I can do those triangles manually. Drives me crazy.
User avatar
Premium Member
Premium Member
Postby Bryan K » Sun Apr 23, 2023 12:27 am
No way, no how was that going to work for the rear engines. I've deleted the block, re-skinned the hull and will hand draw the engines in place.
User avatar
Premium Member
Premium Member
Postby Bryan K » Sun Apr 30, 2023 11:17 pm
Taking a break. Between the weather (huge temp swings) and seasonal allergies, I'm not able to focus like I need to.
User avatar
Premium Member
Premium Member
Postby Mike Amos » Mon May 01, 2023 9:38 am
It's not going anywhere mate, time to be kind to one's self for a while. See you on the flip side.
Premium Member
Premium Member
Postby Bryan K » Thu May 04, 2023 4:30 am
Alrighty! I'm getting a handle on this. This is not it either, but I now know what direction to go in. I am quite close. I'll have to rip all this out again, but the next one should be it. Or very damn close to it.
User avatar
Premium Member
Premium Member
Postby Bryan K » Wed May 10, 2023 3:05 am
Just a bit more refinement and I'll have the upper shell of the rear engine pods.
You can see the block sections I had to create to make this work. Lot and lots of arcs and then Curviloft to skin. I also had to shorten the rear section by a lot. Just selected all four rear sections and scaled along the red axis. Then built the engine pods sections.
A little more refinement to the front hull as well by changing the white section.
User avatar
Premium Member
Premium Member
Postby Bryan K » Thu May 11, 2023 2:34 am
Now we're gettin' somewhere!
I do believe I can start the bottom hull now. I'll come back and detail the engine pods later. I need to get the whole thing roughed in first.
Thank you Tools on Surface and Curviloft!
User avatar
Premium Member
Premium Member
Postby ntxdave » Thu May 11, 2023 2:34 pm
Always interesting to watch these progress. :thumb: :thumb:
User avatar
ntxdave
Postby Bryan K » Thu May 11, 2023 7:47 pm
ntxdave wrote:Always interesting to watch these progress. :thumb: :thumb:
User avatar
Premium Member
Premium Member
Postby Bryan K » Fri May 12, 2023 3:17 am
So a bit more squashing here and there. I can already see this will not be one-for-one, but there is only one view to go by, so it will only be close.
User avatar
Premium Member
Premium Member
Postby L i am » Fri May 12, 2023 11:45 am
Hi Bryan, when I first saw you reference Spacship the first thing I saw was the thrust engines and how it looks like that craft relies fundamentaly on thrust vectoring. Am aware you have plans for that but I think that function rests heavily on those thrusters. Just for consideration I think that doing a really cool thrust vector mechanism along with some titanium materials could make that model when you get to detailing that part :thumb:
Premium Member
Premium Member
Postby Bryan K » Sat May 13, 2023 4:33 am
I think you're right , L I am. Those may very well be swivel engines. It's certainly the only way I can reconcile the odd perspective.
And it also looks like swivel engines under a top cover. I've already stated moving in that direction by making the engines themselves separate.
User avatar
Premium Member
Premium Member
Postby Bryan K » Wed May 17, 2023 2:17 am
Moving along now.
User avatar
Premium Member
Premium Member
Postby Mike Amos » Wed May 17, 2023 10:36 am
Getting closer mate, like it a lot. :thumb:
Premium Member
Premium Member
Postby Bryan K » Thu May 18, 2023 8:42 am
Mike Amos wrote:Getting closer mate, like it a lot. :thumb:
Thanks.
This one is weird, I can feel it, I can see it, but it still eludes me.
But I'll sure as hell will nail it. :fro:
And then find a simpler one to do for the next project. HA! Who am I kidding? :lol: (Damn you Aronnax!)
User avatar
Premium Member
Premium Member
Postby Bryan K » Sun May 21, 2023 9:49 am
Cockpit rough-in. Just trying to get a sense of scale and plan the cockpit. This is very rough. Just for scaling.
User avatar
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to WIP
Who is online
Users browsing this forum: No registered users and 2 guests
