error: #syntaxerror - plugins/followandrotate_en.rbs?
Postby archmlcm » Tue Sep 28, 2021 5:28 am
Hi Guys,
Just installed sketchup pro 2021. And encounter this error.
Error: #<SyntaxError: c:/users/mark.m/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
Is this something we need to worry about?
Looking forward for your response and suggestions.
Thank you.
Mark Leo
https://ae.linkedin.com/in/archmlcm
archmlcm
Re: error: #syntaxerror - plugins/followandrotate_en.rbs?
Postby Rich O Brien » Tue Sep 28, 2021 8:53 am
The clue is in the error message....
Code: Select all
...that right there is what WE need not to worry about.
Rich O Brien
Administrator
Postby Box » Tue Sep 28, 2021 9:54 am
For a bit more info on that, follow and rotate hasn't worked for a long time. So it isn't a bug, just a bugged plugin. Remove it or you will continue to get that error.
Postby Dave R » Tue Sep 28, 2021 7:46 pm
Since this isn't a SketchUp bug and is instead related to an old extension, I've moved the thread to the Plugins folder.
BTW, your profile says you are still using SketchUp 2014. Please update your profile. That information helps others help you.
Global Moderator
Return to Plugins
Users browsing this forum: 1mustafakol, c52017ben, Daniel S, DoMiniC81, junior0808, Natalie1234 and 13 guests
