[Plugin] LordOfTheToolbars - v2.2a - 28 Jun 22
Re: [Plugin] LordOfTheToolbars - v1.6a - 27 Nov 21
Postby rv1974 » Wed Dec 29, 2021 2:07 pm
Manipulations with large palettes became (so far) much more predictable and stable with latest release. Thank you very much Fredo :thumb:
P.S. Could theoretically LOTT show user's shortcuts directly in tool tips and command search?
rv1974
Postby haymaker » Wed Jan 05, 2022 10:35 pm
Please help
I have set up LOTT but the vignette strip is stuck on my laptop screen and will not drag to my 2nd larger screen where I use SU. I can solve this by making the 2nd screen the main screen in windows11 but then SU does not allow me to access the standard menus and SU freezes. I run lot s of pluggins and this is the first time I have had this issue. Having the vignette strip on the laptop screen also means The favourite pallets I have made open on that screen as well and the shortcuts don't work. This make LOTT un useable for me which would be a shame because it looks awesome.
I would be extremely grateful if you cold help trouble shoot this issue.
Kind regards
Mike
haymaker
Postby haymaker » Wed Jan 05, 2022 10:46 pm
Further to previous post. It is worth noting that the LOTT toolbar is open on the main screen. The favourite, master and shortcut menus open on laptop and can be dragged to main screen but everything else is stuck on the laptop screen. Its like the vignette strip does not recognise the second screen.
I am using LOTT V1.6a and LIBfredo6 v12.3a. SU2021 all up to date.
haymaker
Postby fredo6 » Wed Jan 05, 2022 10:59 pm
It's funny, because other users have complained that the Vignette Stripe does not follow Sketchup when the main SU window is moved to another monitor (hence the changes I made to keep the Vignette Stripe position relative to the Sketchup viewport).
I need to think a little bit to see how to accommodate all requirements.
fredo6
Premium Member
Premium Member
Postby haymaker » Thu Jan 06, 2022 2:17 am
Thanks for the prompt response.
Would it be possible for me to download an earlier version that would work?
Cheers
Mike
haymaker
Re: [Plugin] LordOfTheToolbars - v1.6a - 27 Dec 21
Postby rv1974 » Thu Jan 06, 2022 10:47 am
Talking of moving to 2nd monitor.. I'm so pleased with rosette behavior - it preserves location perfectly and no more disappearings :enlight:
Hope one day palettes will be able to keep their relative location while manipulating SU viewport in precise manner as well.
rv1974
Postby fredo6 » Thu Jan 06, 2022 11:18 am
rv1974 wrote:Talking of moving to 2nd monitor.. I'm so pleased with rosette behavior - it preserves location perfectly and no more disappearings :enlight:
What is the rosette behavior again?
fredo6
Premium Member
Premium Member
Postby rv1974 » Thu Jan 06, 2022 11:43 am
I mean vignette. I got addicted to Stromae's Sante lately Haha
rv1974
Postby fredo6 » Thu Jan 06, 2022 3:33 pm
haymaker wrote:Thanks for the prompt response.
Instead, I would suggest that you install LOTT V1.6b, which includes an option for setting or unsetting the stickiness of the Vignette Stripe to the Sketchup window (ON by default, so you would need to disable it in the Default Parameters).
fredo6
Premium Member
Premium Member
Re: [Plugin] LordOfTheToolbars - v1.6b - 06 Jan 22
Postby fredo6 » Thu Jan 06, 2022 3:36 pm
NEW RELEASE: LordOfTheToolbars v1.6b - 06 Jan 22
Requirements
  • LibFredo6: v12.3a or above
LordOfTheToolbars 1.6b includes
  • New parameter (in the Default Parameter dialog box) to enable / disable the stickiness of the Vignette Stripe to the Sketchup Window (default is enabled).
Home Page of LordOfTheToolbars for information and Download.
Main post of this LordOfTheToolbars thread.
fredo6
Premium Member
Premium Member
Postby haymaker » Fri Jan 07, 2022 9:11 am
Hey.
Great customer service.
I have updated LOTT to 6b but the problem persists. The vignette strip and the favourite pallets that I have made are stuck on the main laptop screen. I also have the problem that whenever I enter text into a dialogue box then the shortcut keys are activated. For example when I make a component with the name 'nog' as soon as I type O the Edit pallet opens up.
I have disabled all my other extensions but it makes no difference. Could this be an installation error. If delete the LOTT extension and reinstall it will I lose all my pallets and shortcuts.
Thank you for your help so far. I am really looking forward to getting this sorted as your plugin will improve my workflow.
Mike
haymaker
Postby fredo6 » Fri Jan 07, 2022 10:09 am
haymaker wrote:I have updated LOTT to 6b but the problem persists. The vignette strip and the favourite pallets that I have made are stuck on the main laptop screen.
Did you disable the stickiness of the Vignette Stripe in the Default Parameters?
For palettes, they are sticky. So I will make an option to release stickiness for them.
haymaker wrote:I also have the problem that whenever I enter text into a dialogue box then the shortcut keys are activated. For example when I make a component with the name 'nog' as soon as I type O the Edit pallet opens up.
Good catch. I will fix that.
fredo6
Premium Member
Premium Member
Postby haymaker » Fri Jan 07, 2022 10:12 am
Hey
I deleted LOTT. I reinstalled it and have attached a screenshot of the error that showed up. I continued with the install and have the same issues. I am not sure if this error has anything to do with the problems I have or not.
Mike
haymaker
Postby haymaker » Fri Jan 07, 2022 10:37 am
fredo6 wrote:Did you disable the stickiness of the Vignette Stripe in the Default Parameters?
Sure did, problem still persists, I can work around it by going into windows display settings and making my external screen the main screen however this seems to cause problems, mainly that if I try and open the Preferences or Model info then SU freezes?? So not really an option..
Cheers
Mike
haymaker
Postby fredo6 » Fri Jan 07, 2022 10:39 am
Cheers
Mike
I sent you a PM for the multiple issues you have
fredo6
Premium Member
Premium Member
Re: [Plugin] LordOfTheToolbars - v1.6c - 08 Jan 22
Postby fredo6 » Sat Jan 08, 2022 6:11 pm
NEW RELEASE: LordOfTheToolbars v1.6c - 08 Jan 22
Requirements
LordOfTheToolbars 1.6c includes
  • Bug fixing for palette and personal commands shortcuts
  • New parameter (in the Default Parameter dialog box) to enable / disable the stickiness of the Palettes to the Sketchup Window (default is enabled).
fredo6
Premium Member
Premium Member
Postby arnestein » Sat Jan 08, 2022 8:15 pm
Started to look at this very rich looking extension - via SketchupEssentials video.
I have the issue of the main "palette" (Vignette stripe?) not showing up in the Sketchup main window bar - but rather at the top of the screen - See image.
I tried the setting: "Palettes are sticky to the Sketchup window" - still stays on top of screen.
Advice ?
arnestein
Postby fredo6 » Sat Jan 08, 2022 9:46 pm
For clarification
  • Stickiness means that the palettes or Vignette Stripe follow move when the Sketchup window is moved. But you decide where to position them manually
  • There are separate stickiness options for the Vignette Stripe and for palettes
fredo6
Premium Member
Premium Member
Postby arnestein » Sat Jan 08, 2022 11:28 pm
I got the Vignette stripe to move with the SU window now, thanks.
However, I had do both activate the "Vignette Stripe is sticky" option and then manually move it somewhere over the Sketchup window.
If I did not move it manually somewhere over the Sketchup window, the Vignette option just stayed in one place, even when I moved the SU window.
For me, good enough :enlight: !
arnestein
Re: [Plugin] LordOfTheToolbars - v1.7a - 09 Jan 22
Postby fredo6 » Sun Jan 09, 2022 6:03 pm
NEW RELEASE: LordOfTheToolbars v1.7a - 09 Jan 22
Requirements
  • LibFredo6: v12.4a or above
LordOfTheToolbars 1.7a includes
  • Bug fixing for list of shortcuts dialog
  • Bug fixing for appearance of palettes when never displayed.
fredo6
Premium Member
Premium Member
Postby greatoe » Tue Jan 18, 2022 2:00 am
Hi Fredo, I'm having problem trying this plugin on a M1 chipset Apple MacBook Pro.
I'm on SketchUp Pro 2021 on 16" MacBook Pro with Apple M1 Max running macOS Monterey. And LordOfTheToolbars is not running properly. All other plugins by Fredo is fine, including FredoCorner and JointPushPull. Only when SIP is disabled, LordOfTheToolbars will run without issue.
Will try to make some screenshots later.
greatoe
Postby cmeed » Mon Jan 24, 2022 5:53 pm
Hi Fredo
Thank you for all the time you put into these plugins! legend!!
I've attached a little video of my problem with Palette line breaks, copying of icons and deleting them
I'd guess this is not expected behaviour? or Have i go this completely wrong....
All I'm trying to do is create a few rows of plugins, I also am attempting to move them about to suit my needs.
cmeed
Premium Member
Premium Member
Postby rv1974 » Tue Jan 25, 2022 7:06 am
@cmeed the plugin needs extra polishing. From my experience you should start a new empty file, make all the desired changes in lott toolbars and restart SU afterwards.
Trying to make changes in the middle of long editing of complex files might be too buggy.
rv1974
Postby cmeed » Tue Jan 25, 2022 10:19 am
WIP! :)
I was going for a big palette with lots of icons I'll have to plan a bit better and maybe use more palettes with reduced amounts in
C
cmeed
Premium Member
Premium Member
Re: [Plugin] LordOfTheToolbars - v1.8a - 31 Jan 22
Postby fredo6 » Mon Jan 31, 2022 2:10 pm
NEW RELEASE: LordOfTheToolbars v1.8a - 31 Jan 22
Requirements
LordOfTheToolbars 1.8a includes
  • Bug fixing for ghosted icons (appearing grayed-out, although they are installed)
  • Bug fixing for blocking of UI right after import (specific SU2022)
  • Bug fixing for line-breaks and insertion of icons in palettes.
fredo6
Premium Member
Premium Member
Postby AISmebel » Mon Jan 31, 2022 2:14 pm
Hey Freddo. First I want to thank you for your work, your extensions are very helpful.
With "LordOfTheToolbars" I'm having trouble loading the tabs I've created.
These problems started after my SU crashed. Resetting the settings and reinstalling the plugin can not solve the problem (((
Loading tabs starts only after clicking on any icon of the LordOfTheToolbars plugin.
Very inconvenient (Icons constantly fly off from the places where I installed them (
https://youtu.be/EWKnFRXS1NE
AISmebel
Postby fredo6 » Mon Jan 31, 2022 2:14 pm
cmeed wrote:I've attached a little video of my problem with Palette line breaks, copying of icons and deleting them
The problems when inserting and deleting icons and line-breaks should be fixed in LOTT v1.8a.
fredo6
Premium Member
Premium Member
Postby fredo6 » Mon Jan 31, 2022 2:20 pm
AISmebel wrote:With "LordOfTheToolbars" I'm having trouble loading the tabs I've created.
Could you first confirm which SU version you have (SU2018?).
Then be more precise on the problem. And could you keep the Ruby console opened when dealing with LOTT, in case there are some error messages displayed.
I would also recommend that you upgrade to LOTT V1.8a just published.
fredo6
Premium Member
Premium Member
Postby AISmebel » Mon Jan 31, 2022 2:34 pm
Now I use SU 2020. The plugin version is the latest and I update it regularly as soon as a new version appears.
Reinstalling the plugin didn't help.
AISmebel
Postby fredo6 » Mon Jan 31, 2022 2:52 pm
If you do not see the Vignette Stripe at start up, it maybe be stuck off-screen (I guess you have multiple monitors).
Could you go to the menu Tools > Fredo6 Collection > LordOfTheToolbars > Reset the Vignette Stripe position.
fredo6
Premium Member
Premium Member
PreviousNext
Return to Plugins
Users browsing this forum: Google Bot and 20 guests
