[Plugin] LordOfTheToolbars - v2.2a - 28 Jun 22
Re: [Plugin] LordOfTheToolbars - v2.0a - 24 Feb 22
Postby resetarionut » Sun Mar 06, 2022 10:06 am
Hi fredo6,
I am also having a problem with LOT, not a big one but the plugin is not loding with sketchup, I have to manualy open it by navigationg to tools>fredo6>LOT>Master Toolbar Manager, or any other menu that forces LOT to start, and my custom toolbars lose placement, the toolbars are reseting to floating toolbars.
I have sketchup 2022 on windows 10, everytinh is up to date.
It worked before the latest update.
resetarionut
Postby fredo6 » Fri Mar 11, 2022 11:16 pm
resetarionut wrote:I am also having a problem with LOT, not a big one but the plugin is not loding with sketchup, I have to manualy open it by navigationg to tools>fredo6>LOT>Master Toolbar Manager, or any other menu that forces LOT to start, and my custom toolbars lose placement, the toolbars are reseting to floating toolbars.
Could you update to LibFredo6 v12.7a and check if you see errors displayed in the Ruby console at startup.
fredo6
Premium Member
Premium Member
Postby resetarionut » Sun Mar 27, 2022 12:26 pm
Hi Fredo,
Sorry I didn't answer back but it seams I don't get any emails with replays, I didn't know there is no email notifications ...
I keep all plugins up to date. Right now I have LibFredo6 12.8a the latest.
The issue is still present and I have attached what comes up in the console at startup.
If you don't find anything relevant to help me fix this from what I am sending should I try a full reinstall of sketchup and see if that works?
Thank you very much for your time.
resetarionut
Postby aa6 » Tue Apr 05, 2022 8:28 pm
Having similar problem... the plug-in seems to work fine, but I can't get the vignette stripe to display. I can see it with "pop up the vignette stripe" but it comes up as a floating menu and then disappears when I click away.
aa6
Premium Member
Premium Member
Postby fredo6 » Tue Apr 05, 2022 8:32 pm
aa6 wrote:Having similar problem... the plug-in seems to work fine, but I can't get the vignette stripe to display. I can see it with "pop up the vignette stripe" but it comes up as a floating menu and then disappears when I click away.
Could you open the Ruby Console at startup to see potential errors (just open the Ruby console, quit Sketchup and restart Sketchup).
fredo6
Premium Member
Premium Member
Postby AISmebel » Wed Apr 06, 2022 11:37 am
I really look forward to fixing this error.
I have been working with this problem for several months, it greatly interferes when after each launch of SU. When you first need to run Lord (so that the icons appear), and then they need to be put in their places (because after launch they appear in the center of the monitor) :(((
AISmebel
Postby aa6 » Wed Apr 06, 2022 5:56 pm
Hi - Thanks for the quick response! I re-started with the ruby console open, but I don't see any errors - although I'm not exactly sure what I'm looking for.
aa6
Premium Member
Premium Member
Postby rv1974 » Thu Apr 07, 2022 7:28 am
Fredo, is there any technical obstacle to show user's shortcuts in the tool tips and command search?
rv1974
Postby digitect » Wed May 11, 2022 4:40 pm
No vignette stripe for me either on SketchUp Pro 2020 on Windows 10, with LOTT v2.0a and LibFredo6 v12.8a.
I can make it temporarily visible via menu Tools > Fredo6 Collection > LOTT > Pop Up but then it disappears the first click anywhere in the SketchUp window. Ruby Console shows no actions or errors.
digitect
Postby Scozzarella » Wed May 11, 2022 4:55 pm
Sketchup 2022 MAC
the Pie Tool doesn't work if I press the button on Palette of LordofTheToolbars.
Is it a bug?
Scozzarella
Postby digitect » Wed May 11, 2022 6:05 pm
digitect wrote:No vignette stripe for me...
UPDATE: I position my Windows taskbar at screen top, and found LOTT beneath it. So that default needs to be adjusted. Once I found, and adjusted, several LOTT positioning options from their defaults (sticky to Sketchup window, position in Popup mode, position when cycling), it behaved as expected.
digitect
Postby fredo6 » Wed May 11, 2022 6:41 pm
Scozzarella wrote:Sketchup 2022 MAC
Is it a bug?
As far as I now the Pie tool (from Rich O Brien) is not supported on Mac.
fredo6
Premium Member
Premium Member
Postby Dave R » Wed May 11, 2022 8:08 pm
Scozzarella wrote:Sketchup 2022 MAC...
Is it a bug?
No. As Fredo indicated, Pie is Windows only.
Global Moderator
Postby Scozzarella » Thu May 12, 2022 3:46 am
/Users/angeloscozzarella/Desktop/Schermata 2022-05-12 alle 04.42.13.png
Scozzarella
Postby Scozzarella » Thu May 12, 2022 3:47 am
Scozzarella
Postby fredo6 » Thu May 12, 2022 7:55 am
@Scozzarella
What is the problem?
fredo6
Premium Member
Premium Member
Postby Scozzarella » Thu May 12, 2022 8:37 am
fredo6 wrote:@Scozzarella
If I click on the button with tool indicates by my arrow, (Arc Pie Tool) the tool doesn't activate.
Scozzarella
Postby fredo6 » Thu May 12, 2022 9:28 am
Scozzarella wrote:If I click on the button with tool indicates by my arrow, (Arc Pie Tool) the tool doesn't activate.
Strange. On Mac, it works for SU2021, but not for SU2022
Thanks for signaling the problem.
fredo6
Premium Member
Premium Member
Postby Scozzarella » Thu May 12, 2022 9:40 am
you are welcome
Scozzarella
Re: [Plugin] LordOfTheToolbars - v2.1a - 14 May 22
Postby fredo6 » Sat May 14, 2022 8:56 am
NEW RELEASE: LordOfTheToolbars v2.1a - 14 May 22
Requirements
  • LibFredo6: v12.9a or above
LordOfTheToolbars 2.1a includes
  • Bug fixing
  • Future compatibility
Home Page of LordOfTheToolbars for information and Download.
Main post of this LordOfTheToolbars thread.
fredo6
Premium Member
Premium Member
Postby Scozzarella » Sat May 14, 2022 2:48 pm
thank you very much
Scozzarella
Postby Rougeee » Tue May 17, 2022 4:06 pm
Why the "selection arrow" is not on the master toolbar list ?
This would be very useful for me to customize a side toolbar on a single column rather than the two columns of the "large toolset" bar.
I know that I can use the spacebar at any time, but it would be more practical for me to have the "selection arrow" icon accessible.
Thanks.
Rougeee
Postby Dave R » Tue May 17, 2022 4:17 pm
Rougeee wrote:This would be very useful for me to customize a side toolbar on a single column rather than the two columns of the "large toolset" bar.
You could natively (without LOTT) create a custom toolbar to replace the Large Toolset.
Global Moderator
Postby Rougeee » Tue May 17, 2022 4:23 pm
Thanks, indeed, I don't know why I never thought of that... :lol:
Rougeee
Postby Whitelizard » Fri May 20, 2022 11:04 pm
Hello, I found a compatibility issue with the Universal Importer.
https://sketchucation.com/pluginstore?pln=universal_importer
When I installed this plugin, any interaction with LordOfTheToolbars started creating unnecessary icons on custom panels. It is solved by disabling the Importer, but at first it was not clear what was happening, then I figured it out myself. So I'm just informing you that such a case took place.
Whitelizard
Postby rv1974 » Tue May 31, 2022 9:11 am
Currently the plugin prohibits to use itself if 'the version is expired' (at least the history command). Could it just inform user instead of prohibition? It's very uncomfortable to restart multiple files.
rv1974
Postby fredo6 » Tue May 31, 2022 11:46 am
rv1974 wrote:Currently the plugin prohibits to use itself if 'the version is expired' (at least the history command). Could it just inform user instead of prohibition? It's very uncomfortable to restart multiple files.
What do you mean by 'version is expired'?
fredo6
Premium Member
Premium Member
Postby rv1974 » Tue May 31, 2022 1:22 pm
A pop-up window saying version is expired and DL link below
rv1974
Postby fredo6 » Tue May 31, 2022 1:45 pm
rv1974 wrote:A pop-up window saying version is expired and DL link below
Version of what? Could you show the screenshot.
fredo6
Premium Member
Premium Member
Postby rv1974 » Wed Jun 01, 2022 7:25 am
this one, it should inform just once and let user continue use LOTT commands without restart.
rv1974
PreviousNext
Return to Plugins
Users browsing this forum: hanielenzo, McMakki, pranto009, Renders and 17 guests
