[REQ] remove backface materials (selected)
• Page 1 of 1
[REQ] remove backface materials (selected)Does anyone know of a plugin that can remove backface materials from a selection. I use TT's Material tools which are excellent. But the actions seem to work on the whole model instead of selections, and removing materials from ALL backfaces is a problem when I just need to work on a specific selection.
Re: [REQ] remove backface materials (selected)If you inverse Selection / Hide then Remove that works not ? (not tested)
Re: [REQ] remove backface materials (selected)put selection in separate file, run TT tools and paste it back- what's the problem?
Re: [REQ] remove backface materials (selected)If you are within a group you can use the Specific Material option to remove the backface material without effecting other backfaces.
Edit: actually you don't need to be in groups, Remove Specific works on selection not entire model. Re: [REQ] remove backface materials (selected)Thanks going into every group is what I was hoping to avoid. If there's nothing out there, I can deal with it these different methods.
Re: [REQ] remove backface materials (selected)You don't have to go into each group, if the material is only on the back faces you can select groups components and raw geometry and it will remove the chosen material from anywhere in the selection while leaving the rest of the model alone. If the material is both back and front then this wouldn't work.
Re: [REQ] remove backface materials (selected)Now i see what you mean--that's a different approach to the same solution. Thanks!
Here are a quick one...This will remove Back Face Material from selection recursively. You can undo it. Start by toolbar icon or context menu after selection. The result will be printed out to Ruby Console e.g.: "Back Face Material removed from 11 faces." or "Back Face Material removed from 0 face." Quickly tested only on Windows. No responsibility... but should be okay on MAC too. (Sorry about the ugly icon ![]()
Man can do everything. Only a matter of time and money.
Re: [REQ] remove backface materials (selected)Nice one Dezmo.
I really must learn to code one day. Re: [REQ] remove backface materials (selected)Wow! Thanks so much for writing that! It works great!
![]() ![]() ![]() MacOSX MojaveSketchUp Pro v19 Twilight v2 Thea v3 PowerCADD
• Page 1 of 1
Users browsing this forum: badrakh2020iqp, KARTHIKEYAN SRINIVASAN, mrc3ll, siddeshtr, Yacov and 15 guests
