Hello everybody,
Does anybody have any contacts with the Author of Edit Flag plugin - AshScott?
The plugin seems to didn't work with SU2021, but it is very useful for construction projects.
Thanks in advance
Edit Flag plugin need update for sketchup 2021
• Page 1 of 1
Re: Edit Flag plugin need update for sketchup 2021I don't think the author has been around for many years...
However, the error relates to one line of code - where newer Ruby versions are less forgiving about messing about with 'frozen-strings' etc... Edit this file using a plain-text editor like Notepad++ or TextWrangler. ../Plugins/Coastal_Concepts_EditFlag/EditFlag.rb Find line #19 which reads:
Edit it to read:
Save the edited RB file and restart SketchUp... Now with the additional .dup code you are working with a copy of the Module's name, not the name itself ! It now adds menu items etc as intended... TIG
Greetings, How about SU 2022. I have changed the code as above. Alas it does not function with the 2022 version. Is there any fix for it? Thank you in advance.
Re: Edit Flag plugin need update for sketchup 2021It works fine for me in v2022, with the simple .dup edit...
Are you following the instructions exactly - e.g. editing the correct file, then saving it and restarting SketchUp. Its entry is in the Edit menu and should be 'ticked'... TIG
Thank you, Indeed it works. I've made a mistake, mea culpa.
• Page 1 of 1
