TIG's Free Rotate crashes SU2020 and 2021
Postby johnwmcc » Sat Nov 21, 2020 8:16 pm
I've looked at the thread about this plugin, and it seems development stopped in 2013, with a comment in the 'release notes' that it has been future proofed.
It's just the thing I was looking for, but it doesn't seem to work in either SU2020 or SU2021.
I get first a hang (Mac OS X Mojave 10.14.6) then a bug splat in both, after starting the plugin and making the first click. The black ball for the rotation point appears, but jumps of of its own accord to a point near the cursor, then freezes SU. I wait for a minute to see if it clears, but it doesn't.
@TIG, is it fixable? I'd REALLY like to be able to use it in later versions of SU.
I'll try it in 2018 or 19 to see if I can get it to work in one of those, or even an earlier version or two that I have installed.
johnwmcc
PluginStore Author
PluginStore Author
Re: TIG's Free Rotate crashes SU2020 and 2021
Postby TIG » Sat Nov 21, 2020 8:35 pm
Future-proofing in v2013 has its limits !
7 years later !
I'd be surprised if it worked in the newest versions...
I haven't looked at it for some years.
It is very old and clunky...
If you run it with the Ruby Console open are there any error messages ?
It is 'open-source' so if you are up to it you can try editing the code to see what happens...
Global Moderator
Postby johnwmcc » Sun Nov 22, 2020 1:20 am
There are no messages at all in the Ruby console, either when it is working in 2017, nor when it crashes in 2020 and 2021.
A different plugin (PointTool.rb by Matt666) crashes in 2020 onwards, and Steve Baumgartner looked at it as I got no response from Matt. Steve said it blew up something in the graphics driver, but could get no further than that.
I'll try it in Windows 10/SU2020 and also on my Mac Book Pro, to see if a different OS or graphics card allow it to work.
I've published several plugins, but only with help from a more experienced Ruby programmer - several with Steve, and a couple with help from ThomThom.
I could have a look at the code but its unlikely I can spot anything. And I half-remember reading somewhere on the SketchUp forum that Ruby shouldn't be able to generate a bugsplat, but I'm not sure if that's right.
But thank you for such a prompt response.
In an ancient SU Forum post there was reference to both your plugin (which in 2017 does exactly what I want to do) and another which I'll try again to track down and see if that works in current versions.
johnwmcc
PluginStore Author
PluginStore Author
Postby johnwmcc » Sun Nov 22, 2020 11:02 am
I've since found another plugin that does a similar job - Eneroth 3D Rotate, from the Extension store.
So it's not so important to get this one working, but a pity it no longer works in later versions of SU.
I'm still curious as to what has broken it - some Ruby update? Something else in the environment like graphics driver or OS?
johnwmcc
PluginStore Author
PluginStore Author
Postby TIG » Sun Nov 22, 2020 2:22 pm
With so much legacy stuff that's years old I don't have time to fix them unless it's obvious whats wrong and/or it's 'paid' !
Often the younger coders like Eneroth have made similar tools that are better anyway...
PS: I just tried my FreeRotate in v2021 on my PC and it worked fine !
I can't test it on a MAC as my old-thing can't upgrade Catalina to let v2020 or newer be installed...
Global Moderator
Return to Plugins
Users browsing this forum: Google Bot, KseniaNikolaevainsi, riobamba, YEOGYEONG and 14 guests
