convert drawing lines to orthogonal
• Page 1 of 1
convert drawing lines to orthogonalHi, I don't know if it's the correct place to ask this, sorry if not.
The thing is that yesterday I was searching for more than 3 hours for a possible plugin to be able to convert a drawing that is not orthogonal to right angles. And I'll need this, because I found a way to make the environment buildings when there's no an OpenStreetMap resource abailable, from capturing the footprint of the houses directly from Google Maps as a JPG and converting that image into a DWG (https://convertio.co/es/jpg-dxf/). So, the problem is that without the orthogonal edges, I can't make a succesful used of the plugin "Automatically create hip roof from a face" from 1001BitTools. So, if someone know a way to transform the drawing from whatever angle to 90º right angles I'll be much more than grateful. Regards and have a nice sunday. Nicolás Re: convert drawing lines to orthogonalInteresting. I've never seen anything like that. I wonder if it is possible to do.
FWIW, Google's terms of use for Google Maps and Google Earth prohibit the kind of thing you are doing with their imagery. Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: convert drawing lines to orthogonalHave you Try Joint Push Push Interactive: Normal / Taper and some various parameters... by Fredo6 ?
Click on the 3 Green Arrows But sorry i just understand your problem! Convert an angle to 90° ![]() Maybe Thomthom tools has a Snipset for that...
Re: convert drawing lines to orthogonalInteresting idea... I'll investigate the feasibility.
There should be some parameters to drive the 'reshape' process (from where to start, what dimensions to maintain, etc). Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F) Re: convert drawing lines to orthogonalHi Didier, that would be awesome, just the attempt already deserves my thanks, I appreciate
![]() Re: convert drawing lines to orthogonalHi,
This idea is more complex than I though ![]() I have writen some dirty code just to see if it is doable. It needs now heavy testing in various situations, with complex face shapes. A threshold parameter (angle) tells the script in which range each angle at each corner of the face has to be 'orthogonalized' (or not). For now, a face like on the left side of the image is reshaped to the one on the right ![]() Click on the image to see it in action on a more complex face: Last edited by Didier Bur on Mon Aug 24, 2020 1:58 pm, edited 2 times in total.
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F) Re: convert drawing lines to orthogonalBon courage!
Re: convert drawing lines to orthogonalHi Didier Bur, this looks excellent!!!
![]() Thanks for your hard work and invested time, I hope one day see it as a plugin ![]() Re: convert drawing lines to orthogonalDidier it could be important tool!
Please check if you could add to round the lengths values and unifying almost overlapping lines Re: convert drawing lines to orthogonalHi,
The future 'orthogonalize' plugin is on its way... But I've encountered some problems to solve before reshaping a face: sometimes there are double points (especially when the face comes from an external content, such as an OSM map for instance), sometimes edges are reversed in the face record, sometimes there are colinear edges or overlapping edges, etc... I've almost solved all of these and the script is under heavy testing ![]() Below is a preview of the interface: you'll choose between 3 options, preserve the global shape of the face, preserve the segments lengths, or click on the first segment of a single face to give the script a start. Script will process a single face or a bunch of selected faces. Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F) Re: convert drawing lines to orthogonalPlease grant ability to save current settings as default globally.
P.S. Would it be possible to implement coordinates rounding? (for instance: 1,5,10 cm?) Re: convert drawing lines to orthogonal@rv1974
Settings are remembered all along the session, but I can also save them saved in the skp file (as model attributes). Concerning the rounding of coordinates, it's also an interesting idea that I will look into. Regards Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F) Re: convert drawing lines to orthogonalYet another idea: arch\circle conversion (if some portions +\- resembles them)
I use curic's(?) one and it's super useful functionality, but conversion won't happen if sefments aren't equal. So implementing arc conversion with threshold would be awesome. [Plugin] beta version of 'orthogonalize'Hi everybody,
Below is the beta version of my Orthogonalize plugin. I would have some feedback from the users, so I can enhance the plugin. Install it the usual way, with the extensions manager. First usage: select one or more faces in the model, righ-click on the selection and select 'Orthogonalize N faces'. Please click on the Help button and read the PDF file to get information about how the script works. Please report any bug you encounter, and feel free to report what's good and what is not convenient to you. Best regards Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F) Re: convert drawing lines to orthogonalHello
I have nothing! (with some parameters) Same no result in 2017, 2015 Make! 1 st segment is working Help is well working! ![]() My figure is too brutal ? (file linked)
Re: convert drawing lines to orthogonalWow I very pleased
![]() My observations: *)Currently plugin keeps to pop up in default location. Could it memorize the last re-location? *)In attached image, the plugin builds approx 90 degree angles (at least SU indicates ~90. *) In case of multiple faces, could we have an option to select the general rectification edge (AB)? If the face is rotated less than user's angle threshhold, then it'd be rectified by this general AB direction *) Currently, it leaves co-linear points (no problem- I can delete them Fredos 'remove lonely vertices) *) Is rounding planned? Re: convert drawing lines to orthogonalHowever "Preserve segment length" option delivers bizarre result. Faces get deleted, only 2 edges survive.
Hmmm, maybe try it in SU V6? Save the Earth, it's the only planet with chocolate.
Re: convert drawing lines to orthogonal@Pilou:
Your file is SU v6. This means the plugin isn't compatible with SU versions that use older releases of Ruby and API. Below is your file 'orthogonalized' with SU2020, with the same parameters as yours. BTW, your white dashed lines indicate a better way to preserve the global shape of the face than the one I've implemented, this will become an option in the next release (I hope). Cordialement, Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F) Re: convert drawing lines to orthogonal@rv1974:
Thanks for reporting this bug, sort of. I see on your image that you are in a group or component. The plugin behaves weirdly in such a context. I'll fix that. Regards Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F) Re: convert drawing lines to orthogonalI have posted my file in "save as V6" but use these last Make (2017,2016,2015)all tested!
![]() See from your Doc that 2015 is out of use your plugin but must be fine for 2016 and uper... I will try with your uper left selected as first segment... Always not result when OK is pressed! ![]() If that can help : verbose don't make nothing in the Ruby console opened! (tested in 2017) Ruby Console works in 2016 but always no result :File linked (with no first segment selected)
• Page 1 of 1
Users browsing this forum: Abu Mbolo, dudasenges, jilali, mac3D, pedroleiva, Raidone87, Rougeee and 19 guests
