Fredo tools not working . Please help !!!!!!
Postby iainteriors » Sat May 16, 2020 11:09 am
Hello
Please help anyone
I have tried reinstall repair deleting tgat file from app data : local : lib ....
But still my fredo tools are not working
Now this is appearing in ruby console .
Let me know what i can do next to reaolve this issue
I have sketchup 2017 and 2020
It was working fine yesterday morning but suddenly it stoped working
Error: #<NoMethodError: undefined method `set_min_max_width' for #<Traductor::Wdlg:0x000001a39db79548>>
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6quicklauncher.rbe:81:in `initialize'
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:47:in `new'
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:47:in `invoke'
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredotools/fredotools.rbe:200:in `invoke_quick_launcher'
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredotools/fredotools.rbe:222:in `block in startup'
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1095:in `command_invoke'
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1077:in `block (2 levels) in build_config_commands'
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1285:in `block in add_command'
iainteriors
Re: Fredo tools not working . Please help !!!!!!
Postby Dave R » Sat May 16, 2020 1:49 pm
First thing I would do is update LibFredo6 to the current version. Then close SketchUp and start it again.
Global Moderator
Postby iainteriors » Sat May 16, 2020 2:14 pm
I did that already . Stil i doesn't work
iainteriors
Postby TIG » Sat May 16, 2020 3:22 pm
Have you installed SketchUp properly ?
Try a 'repair' as follows...
Whilst you are logged into your normal Windows user-account, ensure that SketchUp [and Layout] are no running.
Find the installer's exe file - usually in your Downloads folder ?
Select the installer's exe file, right-click > context-menu > "Run as administrator"
When prompted choose "Repair".
When it completes restart SketchUp...
Any better ?
Running any complex app's installer exe file in another way will lead to unpredictable weird issues, often involving file/folder permissions - sometimes these problems don't appear immediately, leading to extra confusion !
Never double-click an installer's exe file to 'Run' it.
Even if your normal user has admin-powers it is NOT the same as doing it as outlined above.
Global Moderator
Postby iainteriors » Sat May 16, 2020 3:31 pm
Yes i did the repair method also it doesn't work
iainteriors
Postby TIG » Sat May 16, 2020 4:50 pm
Hopefully Fredo can chip in with some ideas... :shock:
Global Moderator
Postby fredo6 » Sat May 16, 2020 5:28 pm
I would suggest to have a look at the Plugins directory and clean up the LibFredo6 file and folder, check if there are old ones, and then re-install LibFredo6.
fredo6
PluginStore Author
PluginStore Author
Return to Plugins
Users browsing this forum: emilioella, oman3000, yeataro and 10 guests
