by fredo6 » Sun Apr 26, 2020 4:53 pm
NEW RELEASE: FredoCorner v1.8a - 26 Apr 20Requirement: LibFredo6 9.1bFredoCorner 1.8a is a major release ----------------------------------------- Please note that, in the current version of FredoCorner: - there are issues with some shortcut modifiers (Ctrl, Alt) on Mac) - there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large. - Terminal corners (that is ending on a single edge) may present issues and bugs - No documentation yet, so watch the videos that I will publish. Please report issues, questions and any feedback in the present thread ----------------------------------------- Home Page of FredoCorner for information and Download. Main post of this FredoCorner thread.
fredo6
- PluginStore Author
- Name: Fredo6
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: interior design
by Einstein » Wed Apr 29, 2020 11:38 pm
Thank you so much! I needed this change a lot  Your fantastic tools are like air to me.
Einstein
- Name: Michal P
- SketchUp version: 2020
- License type: Pro
- SketchUp use: architecture
by comsasa » Mon May 25, 2020 2:12 pm
FredoCorner v1.8a & LibFredo6 v10.5a User.
I want the edge color to appear as the sketchup default.
At the moment of using the Fredocorner brown, magenta, red and violet materials appear in the material window.
I don't want this to appear. What should I do?
comsasa
- Name: Kim Si Hong
- SketchUp version: 2019
- License type: Free/Make
- Level of SketchUp: Beginner
by Dave R » Thu May 28, 2020 7:06 pm
comsasa wrote:I don't want this to appear. What should I do?
First show an example of what you are seeing. What version of SketchUp are you using. Your profile says "2019 Free/Make" but there is no such version.
- Global Moderator
- Name: Dave R
- SketchUp version: 2021
- License type: Pro
- SketchUp use: woodworking
- Level of SketchUp: Advanced
by fredo6 » Thu May 28, 2020 9:27 pm
NEW RELEASE: FredoCorner v1.8b - 28 May 20Requirement: LibFredo6 9.1bFredoCorner 1.8b is a maintenance release fixing an issue with improper coloring of edges ----------------------------------------- Please note that, in the current version of FredoCorner: - there are issues with some shortcut modifiers (Ctrl, Alt) on Mac) - there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large. - Terminal corners (that is ending on a single edge) may present issues and bugs - No documentation yet, so watch the videos that I will publish. Please report issues, questions and any feedback in the present thread ----------------------------------------- Home Page of FredoCorner for information and Download. Main post of this FredoCorner thread.
fredo6
- Name: Fredo6
- License type: Pro
by fredo6 » Thu May 28, 2020 9:29 pm
comsasa wrote:I want the edge color to appear as the sketchup default.
Sorry for that. I use colors for debugging purpose and apparently I left them in the published version. This is fixed in FredoCorner v1.8bFredo
fredo6
- Name: Fredo6
- License type: Pro
by fredo6 » Fri Jun 19, 2020 7:47 am
NEW RELEASE: FredoCorner v1.9a - 19 Jun 20Requirement: LibFredo6 10.7aFredoCorner 1.9a is a maintenance release - fixing an issue with reselection of edges after a Repair - Edit
- Exit via a single click
fredo6
- Name: Fredo6
- License type: Pro
by sehuz » Wed Aug 12, 2020 12:08 am
Hello. Great job with this amazing tool Fredo ! I'v just installed today and test it with the direct link for Twinmotion, sadly the beveling doesn't appear, and also it shows issues on the geometry. But exporting the model to Twinmotion it works great.
sehuz
- Name: Sehuz
- SketchUp use: hobby
by fredo6 » Fri Aug 14, 2020 6:27 pm
What is this "direct link for Twinmotion"?
Did you generate the geometry or just activate the Preview mode (whihc is just drawing, not generating geometry)?
fredo6
- Name: Fredo6
- License type: Pro
by fredo6 » Wed Aug 19, 2020 9:44 pm
NEW RELEASE: FredoCorner v2.0a - 19 Aug 20Requirement: LibFredo6 11.0aFredoCorner 2.0a is a maintenance release - Improvement of Orbit/Pan on Windows for Preview mode
- Extension of validity
fredo6
- Name: Fredo6
- License type: Pro
by rv1974 » Wed Sep 30, 2020 8:37 am
Fredo, could you make the offset faces stay selected after command is executed please? Just like you did in JPP. It'd help tremendously to do some nice things with this separated selection. P.S. You are one step  from making long awaited Groove maker. All it takes is to add is to add 'ignore hard\open edges' option * in pre-selected geometry and integrate merge coplanar offset faces and JPP inwards. *- In his video, Ahmed solves this ignoring problem by drawing initial groove lines on separate tag.
rv1974
- Name: rv1974
- SketchUp version: 2017
- License type: Pro
by pilou » Wed Sep 30, 2020 2:31 pm
Or you have another trick  Make 2 same volumes at the same place ! Fractalize one then Exploded View it you have your grooves!
- Top SketchUcator
- Name: Pilou
by vbbartlett » Wed Nov 11, 2020 5:27 am
I have a file that breaks, I am attaching it in hopes that you can use it to improve the plugin, which is awesome btw. It is a tooth of a gear. I have removed the rest of the gear as it is just too many verts.
vbbartlett
- Name: Carl Bartlett
- License type: Pro
by fredo6 » Fri Nov 13, 2020 8:48 pm
I think you should first eliminate the very small edge to make it work. Currently the limitation is that the offset should be smaller that the shortest edge in the selection. This is true for RoundCorner and FredoCorner. FredoCorner - small edges.png
fredo6
- Name: Fredo6
- License type: Pro
by fredo6 » Fri Nov 20, 2020 9:23 am
NEW RELEASE: FredoCorner v2.1a - 19 Nov 20Requirement: LibFredo6 11.3aFredoCorner 2.1a is a maintenance release - Bug fixing for Orbit/Pan on Windows for Preview mode
fredo6
- Name: Fredo6
- License type: Pro
by fredo6 » Wed Dec 02, 2020 10:12 pm
NEW RELEASE: FredoCorner v2.1b - 02 Dec 20Requirement: LibFredo6 11.3aFredoCorner 2.1b is a maintenance release - Prevent to set the number of segments to 0
fredo6
- Name: Fredo6
- License type: Pro
by fredo6 » Wed Jan 06, 2021 9:03 am
NEW RELEASE: FredoCorner v2.2a - 06 Jan 21Requirement: LibFredo6 11.3aFredoCorner 2.2a is a maintenance release for extension of validity ----------------------------------------- Please note that, in the current version of FredoCorner: - there are issues with some shortcut modifiers (Ctrl, Alt) on Mac) - there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large. - Terminal corners (that is ending on a single edge) may present issues and bugs - No documentation yet, so watch the videos that I will publish. Please report issues, questions and any feedback in the present thread ----------------------------------------- Home Page of FredoCorner for information and Download. Main post of this FredoCorner thread.
fredo6
- Name: Fredo6
- License type: Pro
- Robot
Return to Plugins
