[Plugin][$] FredoCorner - v2.4a - 28 May 21
Re: [Plugin][$] FredoCorner - v2.3a - 27 Jan 21
Postby kelly13 » Sat Feb 20, 2021 1:25 pm
fredo6 wrote:In the main post about Sketchucation License, there is a link to a PDF explaining the whole process (in English).
If you have been able to post here .......
7 - This is done.
thank you, I was able to buy and install
kelly13
Postby LEGOsketcher » Tue Feb 23, 2021 9:46 am
re: seat limit and licenses
God day, I am The LEGO companies Sketchup admin and wonder would like to include the latest Fredocorner release to our plugin collection.
The company scripts a SU package with plugins included, Sketchucation should not be part of the basic package as most users won't use the Sketchucation plugins and it adds a level of complexity. Some users might use FredoCorner, most not. (maybe 5 -15 users)
I wonder how to best approach the licensing issue as it will be hard administer individual seats / usage. Would that mean I need to install the SUcation plugin and seat license for the users that actually need Fredo corner? I'm also worried about budget for individual seats run up compared to the SU budget. They might ask me to find an alternative if the setup is too complex/time consuming.
Will there be something like a studio license so I can avoid individual seats or floating licenses?
Feel free to PM me, looking forward to hearing from you
LEGOsketcher
Postby mwkinley » Sun Mar 07, 2021 10:00 pm
Loving this plugin but my trial has expired and I can't buy the license...any tips?
I have tried uninstalling , restarting , downloading again but of course it remembers the trial version had expired...all I get is this when I click on 'manage license'.
Any help greatly appreciated.
Matt
mwkinley
Premium Member
Premium Member
Postby fredo6 » Sun Mar 07, 2021 10:04 pm
Could you reinstall the Sketchucation Tools v4.0.0.e.
There must be something wrong in its current installation (most likely out of date).
Please advise if it does not solve the problem.
fredo6
PluginStore Author
PluginStore Author
Postby mwkinley » Tue Mar 09, 2021 3:46 pm
Fixed, thankyou Fredo.
I will buy the license now!
Regards
Matt
mwkinley
Premium Member
Premium Member
Postby Buckyman » Mon Mar 15, 2021 1:52 pm
I am getting Ruby error when I try to round corners.
Can you review the files attached and tell me if it is possible?
The JPG shows the parameters that I need
Buckyman
Postby fredo6 » Mon Mar 15, 2021 2:04 pm
The errors comes from the rounding of the upper part and the large offset.
Currently FredoCorner does not round edges when one of the edge has a length smaller than the offset.
So, it works with an offset of 2'', but not beyond.
I am planning to evolve the algorithm to overcome this limitation, but this is quite complex. So, not for an immediate release...
Fredo
PS: RoundCorner does not do a better job
fredo6
PluginStore Author
PluginStore Author
Postby bsfranza » Mon Mar 15, 2021 2:57 pm
hey there,
i have a problem, the fredo corner toolbar does not show up?!
in the extension manager its shown, also in sketchucatino licence manager etc, plugin manager, .. its tehre everywhere but i cant get the "toolbar" or menue items to show up?! also removing the plugina and reinstalling from rbz dos not help :I
im running the latest su 2021..
any help much appreciated,
best, bsfranz
bsfranza
Postby fredo6 » Mon Mar 15, 2021 3:02 pm
bsfranza wrote:i have a problem, the fredo corner toolbar does not show up?!
Did you install the companion library LibFredo6?
fredo6
PluginStore Author
PluginStore Author
Postby bsfranza » Mon Mar 15, 2021 3:20 pm
oh silly me :I .. sorry for stealing your time - i have installed the library now it works as expected...
thx
bsfranza
Postby Buckyman » Mon Mar 15, 2021 11:28 pm
fredo6 wrote:The errors comes from the rounding of the upper part and the large offset.
Yes I did see success with 2", and I did try RoundCorner
Thanks for your quick response and all your great plugins :-)
Buckyman
Postby NJDesign » Fri Mar 19, 2021 10:43 pm
I am getting a Ruby console error when I try to round these corners. Can you tell me what is wrong?
-Never mind. I found a way around it.
Ce qui mérite d'être fait mérite d'être bien fait.
NJDesign
Postby NJDesign » Sat Mar 20, 2021 7:02 pm
Since I purchased the license I keep getting Ruby code errors. I have not managed to use the plugin successfully. Here is an example of the errors I get:
Date: 20-Mar-21 13:51:43
An error occurred in FredoCorner
An error occured in the Ruby code
undefined method `[]' for nil:NilClass
fredocorneralgo.rbe:: 2618 -- chemin_analyze_crossing
fredocorneralgo.rbe:: 2421 -- brane_intersect_chemins
fredocorneralgo.rbe:: 2060 -- block in catena_process_branes_protected
fredocorneralgo.rbe:: 2047 -- each
fredocorneralgo.rbe:: 2047 -- catena_process_branes_protected
fredocorneralgo.rbe:: 2009 -- block in catena_process_branes
fredocorneralgo.rbe:: 2008 -- catch
fredocorneralgo.rbe:: 2008 -- catena_process_branes
fredocorneralgo.rbe:: 965 -- block in solid_construct_branes
fredocorneralgo.rbe:: 964 -- each
fredocorneralgo.rbe:: 964 -- solid_construct_branes
fredocorneralgo.rbe:: 919 -- block in solid_reconstruction
fredocorneralgo.rbe:: 918 -- each
fredocorneralgo.rbe:: 918 -- solid_reconstruction
fredocorneralgo.rbe:: 883 -- solid_add_remove_edges
fredocornertool.rbe:: 1845 -- selection_change
fredocornertool.rbe:: 1833 -- selection_add_remove_edges
fredocornertool.rbe:: 1856 -- selection_set
fredocornertool.rbe:: 1538 -- block in preselection_instantiate
fredocornertool.rbe:: 1535 -- each
fredocornertool.rbe:: 1535 -- preselection_instantiate
fredocornertool.rbe:: 1530 -- preselection_analyze
fredocornertool.rbe:: 766 -- true_activate
fredocornertool.rbe:: 751 -- block in activate
lib6plugin.rbe:: 1568 -- tem_context
fredocornertool.rbe:: 751 -- activate
fredocornertool.rbe:: 194 -- select_tool
fredocornertool.rbe:: 194 -- launch
fredocornertool.rbe:: 176 -- action__mapping
lib6plugin.rbe:: 129 -- call
lib6plugin.rbe:: 129 -- launch_action
lib6plugin.rbe:: 227 -- launch_action
bootstrap_fredocorner.rbe:: 103 -- launch_action
bootstrap_fredocorner.rbe:: 118 -- block in startup
lib6plugin.rbe:: 1347 -- command_invoke
lib6plugin.rbe:: 1328 -- block (2 levels) in build_config_commands
lib6traductor.rbe:: 1377 -- block in add_command
NJDesign
Postby fredo6 » Sat Mar 20, 2021 7:09 pm
NJDesign wrote:Since I purchased the license I keep getting Ruby code errors. I have not managed to use the plugin successfully.
Depending on the model, FredoCorner may get into error.
So the best would be to PM me or post the model so that I have a look.
Fredo
PS: This has nothing to do with the license. The error is in the algorithm.
fredo6
PluginStore Author
PluginStore Author
Postby Brickokermis » Thu Apr 01, 2021 10:43 am
Like many people around the world, I was surprised that Fredo plugins went from free to paid. This is absurd!
Having plugins that have been free for decades and that are quietly going from free to paid, I don't know what quality could I give to this maneuver ...
Yesterday evening I saw, in an instant, the error message indicating "trial version finished", I thought it was April Fool's Day a little too fresh, but not when I got to the download page that it was not my astonishment when I saw that it was paying, whereas it was free just before. it's a very, very stupid operating system!
I have absolutely nothing against people who are looking for a return on investment. But the way to do it is not possible!
Inform people, take opinions, etc.
Especially that, 15 days ago when I updated I did not see that it was paid, since it is not displayed on the list of the plug-in store.
Another thing, buying it will not be a problem for me, if I have to I would buy it. But not individually, at 22 € / plug-in it's very, if not too expensive.
Make a pack of all plugins, or in this case lower the price from 10 to ~ 12 € / plug-in
22 € x (number of plugins) = too expensive.
Sketchup is starting to take the path of software that is losing value, already that the license is very expensive, if even the plug-ins are not affordable, Sketchup is losing more and more credibility, and that I have read on hundreds of forums around the world about the Fredo plug-in which switched to the Pay system
Do not forget, behind there is Blender much more efficient, Open Source, with a more family interface that allows you to learn faster than before. At this speed it's soon the end of Sketchup
Brickokermis
Premium Member
Premium Member
Postby Dave R » Thu Apr 01, 2021 5:35 pm
Fredo didn't just quietly spring this change on the world yesterday. It was announced months ago that some of his extensions would be changing to requiring paid licenses. It's a one time license fee for each extension and includes the updates as they come along. You aren't being forced to purchase the license for FredoCorner. You can choose to use RoundCorner instead. There's still no charge for that one.
Global Moderator
Postby rv1974 » Thu Apr 01, 2021 8:34 pm
@Brickokermis: 22€ per plugin is not too cheap, but lets suppose you used some of (now commercial) Fredeo plugins for 10 years in the past and will continue to use it for additional 10 years in the future; this is approx 1€/year. Just think about it.
P.S. I'd agree though that bundle would be much more user-friendly format.
rv1974
Postby grigorescustelian » Mon Apr 05, 2021 6:13 am
:thumbd: It used to be free... At least let us use our old versions, why do you have to make them expire?
grigorescustelian
Postby Dave R » Mon Apr 05, 2021 12:39 pm
grigorescustelian wrote:At least let us use our old versions...
You can still use RoundCorner without paying for it.
Global Moderator
Postby Aroundthebend » Tue Apr 06, 2021 8:36 pm
Hi, I'm having trouble validating the licence. I keep getting this message:
Sorry - An error occured in the communication with Sketchucation
I've checked I've got the up-to-date Plug-in:
ExtensionStore v4.0.0
FredoCorner 3.2
LibFredo 11.6a
Screen Shot:
Aroundthebend
Postby fredo6 » Tue Apr 06, 2021 9:07 pm
Are you connected to the Internet when doing the validation?
fredo6
PluginStore Author
PluginStore Author
Postby Aroundthebend » Wed Apr 07, 2021 1:23 am
fredo6 wrote:Are you connected to the Internet when doing the validation?
I am, still no luck!
Aroundthebend
Postby Dave R » Wed Apr 07, 2021 2:36 am
Are you still using SketchUp 2017 as indicated in your profile? What version of the Mac OS?
Global Moderator
Postby GoatmanZ » Fri Apr 09, 2021 9:04 pm
Two things. One the plug in is GREAT. Second, mine seems to have expired. I have NO problem with paying for a perpetual license but there is NO way I can find, to pay! I NEED the plugin but it won't install. Or at least appear for me to use. The sketchUcation extension manager says it's installed but I keep getting errors and it doesn't appear for me to use. Help!!! I have the latest version of the Fredo6 library installed.
GoatmanZ
Postby fredo6 » Fri Apr 09, 2021 11:59 pm
@GoatmanZ
When FredoCorner expires, it displays a dialog.
Just click on the button Manage License. You get this dialog (accessible also from the menu Tools > Fredo6 Collection > FredoCorner > License....
The just click on Obtain License to get to the Purchase page.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Aroundthebend » Sun Apr 11, 2021 1:10 pm
Dave R wrote:Are you still using SketchUp 2017 as indicated in your profile? What version of the Mac OS?
Yes; still using SU pro 2017 on Mac OS X 10.11.6
Aroundthebend
Postby elfis » Sun Apr 18, 2021 1:45 pm
There is tax in the checkout, in my country we use vat so I should be charged with no tax for sale outside US or be able to claim vat. For now price is more the 30$. Can you advice. Thanks
elfis
Postby AdrianV » Thu Apr 29, 2021 10:35 am
Hi Fredo, I've been using FredoCorner for quite a while, and it is indispensable!
I would like to buy a perpetual licence, but is it possible to buy only 1 seat? I use it for my 3D printing hobby, and have no need for 3 seats. Also, I'm quite poor :o
Thank you for all you have done for the SketchUp community!
Adrian
AdrianV
Re: [Plugin][$] FredoCorner - v2.4a - 28 May 21
Postby fredo6 » Fri May 28, 2021 8:18 pm
NEW RELEASE: FredoCorner v2.4a - 28 May 21
Requirement: LibFredo6 11.6a
Requirement: Sketchucation ExtensionStore 4.1.0
FredoCorner v2.4a is a maintenance release for technical adjustments and extension of validity.
Please note that, in the current version of FredoCorner:
- there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
- there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
- Terminal corners (that is ending on a single edge) may present issues and bugs
- No documentation yet, so watch the videos that I will publish.
Please report issues, questions and any feedback in the present thread
Home Page of FredoCorner for information and Download.
Main post of this FredoCorner thread.
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Thu Jun 10, 2021 10:22 am
I thought for a moment of Fredo UN-corner:
https://www.youtube.com/watch?v=IDZn25EVKfQ
rv1974
PreviousNext
Return to Plugins
Users browsing this forum: Faceless Void, JaxW, jminlm, Merleau, rohanvb and 19 guests
