[Plugin] ClothWorks v1.7.2 - 11 Aug 2019
Re: [Plugin] ClothWorks - 28 March 2018
Postby Rich O Brien » Fri Mar 30, 2018 4:59 pm
solo wrote:I want to create chains following a path, I use copy along path normally to get chain links to follow a line, I used to use 'Rope fall' to create the path line but that is too slow and the author is AWOL does not answer his emails. So, will there be a way to drape a line? (I do not need a mesh, just a line so I can either copy along or use follow me if I want a rope.).
It alreadt support draping lines. Read the tutorial in the manual.
Rich O Brien
Administrator
Postby jo-ke » Fri Mar 30, 2018 5:03 pm
I have problems with textures. what did I wrong?
jo-ke
Premium Member
Premium Member
Postby Box » Fri Mar 30, 2018 5:07 pm
Make sure the texture is applied to the faces not the group.
Postby juju » Fri Mar 30, 2018 5:11 pm
solo wrote:I used to use 'Rope fall' to create the path line but that is too slow and the author is AWOL does not answer his emails.
I saw that "Rope Fall" is also subscription these days, very inspiring...
21 Sept. 2020. Please support this thread on the SketchUp forum to resolve Extension Warehouse problems. Faults being ignored is not an option.
juju
Premium Member
Premium Member
Postby boofredlay » Fri Mar 30, 2018 5:26 pm
Yep.
Draw a line, divide it and drape.
5
boofredlay
Global Moderator
Postby solo » Fri Mar 30, 2018 5:55 pm
boofredlay wrote:Yep.
Divide works on a simple line, but what about a more complex line, divide is not an option, is there a plugin to divide multiple attached lines?
http://www.solos-art.com
solo
Global Moderator
Postby Box » Fri Mar 30, 2018 6:05 pm
Either Fredo's Bezier Spline or Fredo Tools will give you suitable options for dividing or segmenting.
3
Postby juju » Fri Mar 30, 2018 6:10 pm
solo wrote:Divide works on a simple line, but what about a more complex line, divide is not an option, is there a plugin to divide multiple attached lines?
Have you tried welding the complex line?
juju
Premium Member
Premium Member
Postby solo » Fri Mar 30, 2018 6:15 pm
Box wrote:Either Fredo's Bezier Spline or Fredo Tools will give you suitable options for dividing or segmenting.
bezier spline worked like a charm.
Too bad there is no plugin that can divide a welded line into equal segments.
solo
Global Moderator
Postby Box » Fri Mar 30, 2018 6:18 pm
Both will, particularly Fredo Tools, Divide Edges.
Unless I'm not understanding what you want. But after 4am need sleep now.
Postby derei » Fri Mar 30, 2018 6:37 pm
@Box
Box wrote:Ooops, I think I made my cargo net just a bit too flexible!
I didn't really understand all controls for Cloth, how do you control the elasticity of a material without making the cloth stiffer?
For example, in your case, for the ball to not slip through the holes in the net, but the net to fall naturally?
DESIGNER AND ARTIST DEREI.UK
derei
Postby jo-ke » Fri Mar 30, 2018 7:47 pm
that's it. Thank you
jo-ke
Premium Member
Premium Member
Postby HornOxx » Fri Mar 30, 2018 8:15 pm
... with ClothWorks you can catch a lot of animals - but not a fish - a bug? :D :D :D
never trust a skinny cook
HornOxx
Postby smashor » Fri Mar 30, 2018 10:03 pm
Dave R wrote:This is with one of the SUC fabrics.
How did you do those wrinkles? Looks very cool!
smashor
Postby Anton_S » Sat Mar 31, 2018 5:21 am
HornOxx wrote:... with ClothWorks you can catch a lot of animals - but not a fish - a bug? :D :D :D
Haven't checked but fish can be one of Known Limits and Limitations. And of course, I'm going to improve contact generation in a major release, which could fix the issue. We'll see.
Anton_S
PluginStore Author
PluginStore Author
Postby Anton_S » Sat Mar 31, 2018 5:25 am
I may have to add this as a workflow feature. Should be very simple.
Anton_S
PluginStore Author
PluginStore Author
Postby Anton_S » Sat Mar 31, 2018 5:37 am
jo-ke wrote:I have problems with textures. what did I wrong?
Box wrote:Make sure the texture is applied to the faces not the group.
In addition to Box's response, to apply a texture to a simulated cloth, follow the step below:
  1. Select the simulated cloth
  2. Click on the undrape icon. This should reset the layout of the cloth
  3. Enter the context of the cloth
  4. Apply a desired texture directly to the front and/or back faces
  5. Exit the context of the cloth
  6. Click on the toggle draped icon again to renew the layout of the cloth
Here is the part of the Draping Sphere video performing these steps (starts at 1:25):
https://youtu.be/u-DZ17Nls9k?t=1m25s
Anton_S
PluginStore Author
PluginStore Author
Postby Anton_S » Sat Mar 31, 2018 5:45 am
Yep.
And if you apply Loop Subdivision to the simulated edges group, the edges would subdivide just like cloth.
Anton_S
PluginStore Author
PluginStore Author
Postby imabzeous » Sat Mar 31, 2018 6:43 am
I tried to buy the plugin but unfortunately i can only buy it via paypal which isn't supported in my country. only master cards visa cards works. so if author or sketchucation admins can help me out?
imabzeous
Postby Pixero » Sat Mar 31, 2018 8:29 am
solo wrote:[Too bad there is no plugin that can divide a welded line into equal segments.
Doesn't Bezier spline Polyline divider for Animation do what you want?
Draw any curve or use the Freehand tool or weld lines. Right click. Convert to Polyline divider for animation and set max length.
(That was once made on my request when I was making advanced animation paths in SketchUp.)
Sometimes, if the curve doesn't fit with the Max length, there can be one edge with different length at the end.
Pixero
Postby Frederik » Sat Mar 31, 2018 8:35 am
Pixero wrote:Doesn't Bezier spline Polyline divider for Animation do what you want?
solo wrote:bezier spline worked like a charm.
Perhaps you should read all posts before posting a reply...
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby Box » Sat Mar 31, 2018 8:37 am
Actually Frederik, Pixero was answering the question/statement that Solo made after he said it worked like a charm.
Postby Box » Sat Mar 31, 2018 8:44 am
Here's a bit of a summer print skirt made by dropping a cloth with a hole in it over a rudimentary waist. A sphere with a pulled top and scaled to an oval.
4
Postby Pixero » Sat Mar 31, 2018 8:45 am
@Frederik:
In his reply he asked for a way of dividing lines into equal segments and my reply answered that.
Pixero
Postby sofie9536 » Sat Mar 31, 2018 9:13 am
clothwork is a great tool to create models in sketchup and to use in iclone. Here is a little example:
3
sofie9536
Postby HornOxx » Sat Mar 31, 2018 9:28 am
sofie9536 wrote:...Here is a little example
:thumb: this upper Collider is a good isea !
HornOxx
Postby Frederik » Sat Mar 31, 2018 10:08 am
Pixero wrote:In his reply he asked for a way of dividing lines into equal segments and my reply answered that.
All good...
I interpreted it as if you hadn't read all posts...
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Re: [Plugin] ClothWorks v1.1.0 - 31 March 2018
Postby Anton_S » Sat Mar 31, 2018 10:51 am
Announcing version 1.1.0: https://sketchucation.com/pluginstore?pln=ClothWorks
  1. Fixed toolbar and dialogs on Mac OS X. Now dialogs are no longer displayed as modal dialogs and toolbars can be updated.
  2. Improved UI slider performance when simulation is active.
  3. Added a feature to split edges. Now in addition to Weld Edges option there is a Split Edges option, allowing you to assign maximum spacing.
4
Anton_S
PluginStore Author
PluginStore Author
Postby alsomar » Sat Mar 31, 2018 12:43 pm
I really love this extension. Thank you so much Anton! :)
Here's my last test using ClothWorks and Thea Render. The statue I've used is "Le Transi de Rene de Chalon" from Three D Scans
6
alsomar
Premium Member
Premium Member
Postby Box » Sat Mar 31, 2018 1:38 pm
Somewhat reminiscent of Priscilla queen of the desert......
PreviousNext
Return to Plugins
Users browsing this forum: Anh TaI Le, waiyanag and 13 guests
