[Plugin] ClothWorks v1.7.2 - 11 Aug 2019
Re: [Plugin] ClothWorks - 28 March 2018
Postby Anton_S » Thu Mar 29, 2018 9:32 am
marvsweden wrote:Purchased. It's going to be exciting using it.
I'm on Mac/SU2018 and the toggle UI window/button doesn't work. It shows up once but if I toggle it by hitting the button it never shows up again until i shut down and restart SU.
Thanks for an important report! I will fix this by as soon as tomorrow (if possible).
4
Anton_S
PluginStore Author
PluginStore Author
Postby marvsweden » Thu Mar 29, 2018 9:54 am
Sure, no problem. Looking forward to using it.
marvsweden
Postby Pepetrucci » Thu Mar 29, 2018 12:03 pm
Awesome!! This is indeed one of the best plugins for sketch i've seen so far. It's incredible how much has my workflow changed (and i think everyone's) in the last couple of years with subd, qftools, skatter, vertextools, wrapr.... and now this!!
Thanks so much for making sketchup even more fun!
Here my first attempt with clothworks, the export frames option is veeery cool!
5
Pepetrucci
Postby juju » Thu Mar 29, 2018 12:57 pm
Pepetrucci wrote:Awesome!! This is indeed one of the best plugins for sketch i've seen so far. It's incredible how much has my workflow changed (and i think everyone's) in the last couple of years with subd, qftools, skatter, vertextools, wrapr.... and now this!!
I know this is OT, but don't forget SKALP!
21 Sept. 2020. Please support this thread on the SketchUp forum to resolve Extension Warehouse problems. Faults being ignored is not an option.
juju
Premium Member
Premium Member
Postby Pepetrucci » Thu Mar 29, 2018 2:01 pm
Of course of course! So many great plugins out there :lol:
Pepetrucci
Postby kenancakir » Thu Mar 29, 2018 2:37 pm
It took about a minute to calculate because of the hedgehog model, but works..
3
kenancakir
Postby Box » Thu Mar 29, 2018 3:28 pm
Love the fact it is compatible with JPP and SUbD.
5
Postby Rich O Brien » Thu Mar 29, 2018 5:12 pm
And FFD
Rich O Brien
Administrator
Postby Armeios » Thu Mar 29, 2018 5:30 pm
Hello Anton, thanks for your great work.
Do you plan the possibility of assigning internal pressure to an object?
For example to simulate an inflatable?
Armeios
Postby urgen » Thu Mar 29, 2018 7:10 pm
...MARVELOUS designer in sketchup? :fro: ...brilliant! :thumb:
--pupil forever...------
urgen
Postby HornOxx » Thu Mar 29, 2018 10:25 pm
...I’m afraid this is going to be Another Addiction Thing again :lol:
6
never trust a skinny cook
HornOxx
Postby Anton_S » Thu Mar 29, 2018 10:27 pm
Armeios wrote:Hello Anton, thanks for your great work.
Currently, you can apply fake pressure by controlling the scale slider in ClothWorks UI.
Anton_S
PluginStore Author
PluginStore Author
Postby solo » Thu Mar 29, 2018 11:34 pm
In the future, will it be possible to integrate this with MS physics? Say I want to fill a bag with objects or drop items onto a net kinda thing?
3
http://www.solos-art.com
solo
Global Moderator
Postby faust07 » Fri Mar 30, 2018 12:42 am
Enthusiastic Yes... :fro:
5
faust07
Postby Anton_S » Fri Mar 30, 2018 1:50 am
I wrote my own physics engine for ClothWorks works. MSPhysics uses NewtonDynamics, which doesn't support cloth or soft bodies at the moment. Though, I will definitely include rigid dynamic bodies into this.
3
Anton_S
PluginStore Author
PluginStore Author
Postby cowboyathome » Fri Mar 30, 2018 4:08 am
This plugin is amazing and easy to use!
5
cowboyathome
Postby Anton_S » Fri Mar 30, 2018 4:12 am
cowboyathome wrote:This plugin is amazing and easy to use!
Amazing results!
Anton_S
PluginStore Author
PluginStore Author
Postby Box » Fri Mar 30, 2018 4:25 am
Ooops, I think I made my cargo net just a bit too flexible!
3
Postby solo » Fri Mar 30, 2018 4:54 am
Box wrote:Ooops, I think I made my cargo net just a bit too flexible!
Using a png based image on a subdivided plane or pure geometry?
solo
Global Moderator
Postby Box » Fri Mar 30, 2018 5:41 am
It's pure geometry Pete, I think if it was a png on a plane the ball wouldn't be able to slip through.
Edit: Here you can see the chainlink fence texture on a plane doesn't let the ball slip through.
Postby HornOxx » Fri Mar 30, 2018 9:28 am
Box wrote:It's pure geometry Pete,...
...this is so awsome again :thumb: :o :thumb:
HornOxx
Postby Hieru » Fri Mar 30, 2018 12:20 pm
Does anyone know why there is a huge difference in results when applying SubD vs Artisan to ClothWorks generated geometry?
I can't seem to get smooth results with SubD as it generates extra geometry and everything appears tessellated. Notice all the dimples with hidden lines turned off.
Hieru
Premium Member
Premium Member
Postby Rich O Brien » Fri Mar 30, 2018 12:22 pm
Hieru wrote:Does anyone know why there is a huge difference in results when applying SubD vs Artisan to ClothWorks generated geometry?
ClothWorks is not generating QFT quads. Convert the Clothworks mesh to Quads.
Rich O Brien
Administrator
Postby Hieru » Fri Mar 30, 2018 12:33 pm
QFT doesn't like that at all...tons of duplicate and reverse faces plus surface weirdness.
Hieru
Premium Member
Premium Member
Postby Rich O Brien » Fri Mar 30, 2018 12:37 pm
How are you converting from ClothWorks to QFT?
Rich O Brien
Administrator
Postby Hieru » Fri Mar 30, 2018 12:41 pm
I was using Convert Wireframe To Quads....that was my mistake. Convert Triangulated Mesh To Quads does the trick. I got there in the end - thanks for pointing me in the right direction Rich.
Hieru
Premium Member
Premium Member
Postby Rich O Brien » Fri Mar 30, 2018 12:47 pm
An easier way to use SUbD to subdivide the plane and explode to apply SUbD. Then convert that QFT compliant mesh to a cloth.
Make sure Boundary Corners is set to Sharp in the SUbD dialog.
Rich O Brien
Administrator
Postby Hieru » Fri Mar 30, 2018 1:10 pm
I'll give that a go, thanks.
Looking good so far, but I need to dig into the manual so that I can appreciate the full potential.
3
Hieru
Premium Member
Premium Member
Postby jo-ke » Fri Mar 30, 2018 4:26 pm
thank you for that beautyfull plugin
5
jo-ke
Premium Member
Premium Member
Postby solo » Fri Mar 30, 2018 4:52 pm
I want to create chains following a path, I use copy along path normally to get chain links to follow a line, I used to use 'Rope fall' to create the path line but that is too slow and the author is AWOL does not answer his emails. So, will there be a way to drape a line? (I do not need a mesh, just a line so I can either copy along or use follow me if I want a rope.).
solo
Global Moderator
PreviousNext
Return to Plugins
Users browsing this forum: DavidDC, j_forrester and 14 guests
