[Plugin] ClothWorks v1.7.4 - 15 Dec 2020
Re: [Plugin] ClothWorks v1.7.4 - 15 Dec 2020
Postby Dave R » Wed Jun 23, 2021 8:05 pm
MarcoGuidetti wrote:I'm attempting to model lateen sails and want creases in the corners where the ropes attach.
I just did this as a quickie. The mast is set up as a collider and I put pins along the spars at the luff and foot.
A little bit of wind set in the UI.
3
Global Moderator
Postby MarcoGuidetti » Thu Jun 24, 2021 11:24 am
[3dwh] https://app.sketchup.com/viewer/3dw?War ... 96c0f77e34 [/3dwh]
This is where I've managed to get it to. I'm pretty happy with it but all comments and suggestions will be much appreciated.
MarcoGuidetti
Postby Dave R » Thu Jun 24, 2021 1:26 pm
Looks reasonable to me. You put a whole lot more time into yours than I did into mine. ;)
Global Moderator
Postby faust07 » Thu Jun 24, 2021 4:50 pm
These examples remind me of experiments with MSPhysics from 2017.
Here I had the sail aninated by means of randomly switched on and off subgroups.
The individual phases of the sail were previously modeled as a group.
A dream would be an integration of ClothWorks in MSPhysics.
A little bit of wind would of course not be bad ... ;)
faust07
Postby Aris » Fri Aug 13, 2021 7:23 pm
Hey guys, I have a problem with the license (you can see in the image)
I don't know who to contact about this
Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
Aris
Premium Member
Premium Member
Postby fredo6 » Fri Aug 13, 2021 9:33 pm
Aris wrote:Hey guys, I have a problem with the license (you can see in the image)
Could you first upgrade to the latest version of ExtensionStore and see if you still have the problem.
fredo6
PluginStore Author
PluginStore Author
Postby Anton_S » Mon Aug 16, 2021 6:23 am
As Fredo pointed out, please update to the latest version of SketchUcationTools. If the problem still persists with activation, try deleting your licensing cache and then activating again as described in ClothWorks licensing manual, Known Issue section, #3: https://antonsynytsia.github.io/manuals ... l_v174.pdf
Anton_S
PluginStore Author
PluginStore Author
Postby hydboxhydbox » Fri Oct 01, 2021 12:49 pm
Hello Anton,
I purchased the license the day before. But I am having some problems validating the license.
Please help.
system: OS X 10.11.6
SketchUp: SketchUp 2017 pro
Cloth works: ClothWorks_v1.7.4
SketchUcationTools_v4.1.1
I have been trying since yesterday. No any luck.
By the way, I am not able to load the SketchUcation Plugin store in the extension, either.
hydboxhydbox
Postby Anton_S » Fri Oct 01, 2021 7:30 pm
@hydboxhydbox Your Mac OS is 10.11. Is it possible for you to upgrade to 10.13? I presume that could be conflicting with SketchUcation extension. Alternatively, it could be thata SCF 4.0 is not compatible with SU2017 but he details indicate that it is compatible with SU2017 and later.
Anton_S
PluginStore Author
PluginStore Author
Postby 13thRebel » Fri Oct 01, 2021 11:07 pm
Привет. А есть ли иные способы оплатить лицензию, кроме PayPal?
Hi. Are there any other ways to pay for the license besides PayPal?
13thRebel
Postby hydboxhydbox » Sat Oct 02, 2021 11:42 am
Anton_S wrote:@hydboxhydbox Your Mac OS is 10.11. Is it possible for you to upgrade to 10.13? I presume that could be conflicting with SketchUcation extension. Alternatively, it could be thata SCF 4.0 is not compatible with SU2017 but he details indicate that it is compatible with SU2017 and later.
Hi Anton,
It's sorted.
I updated my system to MacOS 10.13. and tried again. The validating message went through.
Maybe there should be some reminder on the download page for those who still using the older macOS system.
Thanks again.
hydboxhydbox
Postby Anton_S » Sun Oct 03, 2021 9:16 pm
13thRebel wrote:Привет. А есть ли иные способы оплатить лицензию, кроме PayPal?
When you purchase, PayPal is not required. You can pay with your credit/debit card directly. As far as additional payment alternatives, that is for SketchUcation to decide upon and integrate. What payment option do you have in mind?
Anton_S
PluginStore Author
PluginStore Author
Postby Anton_S » Sun Oct 03, 2021 9:19 pm
Hi Anton,
It's sorted.
Thanks again.
Interesting case. I will inform SketUcation team about this incompatibility issue. Thank you for your test and patience!
Anton_S
PluginStore Author
PluginStore Author
Postby 13thRebel » Sun Oct 03, 2021 9:50 pm
Anton_S wrote:When you purchase, PayPal is not required. You can pay with your credit/debit card directly. As far as additional payment alternatives, that is for SketchUcation to decide upon and integrate. What payment option do you have in mind?
Hi. Yes, I meant a credit / debit card. When I check out, I end up always being redirected to PayPal. How exactly can I pay by card without using PayPal in any form?
13thRebel
Postby Anton_S » Sun Oct 03, 2021 9:52 pm
Have you seen this option? See attached screenshot.
Anton_S
PluginStore Author
PluginStore Author
Postby 13thRebel » Sun Oct 03, 2021 10:03 pm
Anton_S wrote:Have you seen this option? See attached screenshot.
Yes. I attached a few screenshots.
As a result, payment by card, but through the PayPal service =(
13thRebel
Postby hydboxhydbox » Wed Oct 06, 2021 11:32 am
Hi Anton,
It's sorted.
Thanks again.[/quote]
Interesting case. I will inform SketUcation team about this incompatibility issue. Thank you for your test and patience![/quote]
NO problem. Thanks for the great extension.
I am now following the menu to give it a try and I got this exposed table edge.
The parameter setting is exactly the same as the ones on the example in the menu.
hydboxhydbox
Postby Dave R » Wed Oct 06, 2021 11:57 am
hydboxhydbox wrote:I am now following the menu to give it a try and I got this exposed table edge.
Try the settings shown here.
Correct the face orientation first, though. Make sure the front faces are up.
Global Moderator
Postby hydboxhydbox » Thu Oct 07, 2021 10:25 am
Thanks, it fixed it.
Is that because I use Quadrilateral Grid + adaptive remeshing? But that is what is said in the menu. Or in simpler cases, the Quadrilateral Grid will be enough?
hydboxhydbox
Postby Dave R » Thu Oct 07, 2021 12:13 pm
I doubt it. At least I don't get the same result you show when I use those settings.
Global Moderator
Postby s870887s » Fri Oct 15, 2021 10:54 am
已購買ClothWorks的授權,但始終沒有收到許可信件
Translated by Google:
I have purchased a license for ClothWorks, but never received a license letter
s870887s
Postby s870887s » Sat Oct 16, 2021 12:02 pm
已購買ClothWorks 的授權,但始終沒有收到授權信件,
我的收件信箱是hengzuan168@gmail.com,
請看到回覆後,寄授權檔給我,謝謝,
因為已經超過24小時了 :cry:
s870887s
Postby gazzato70 » Sat Oct 16, 2021 3:19 pm
Hi, I have a licensing problem with ClothWorks. I had to format the pc without being able to release the license. After the new installation I entered the licenses of the paid plugins and ClothWorks tells me that I am using 3 licenses while in fact I only use 1 license. I don't have other PCs where I use ClothWorks. I need help resetting the licensing situation. Thank you very much
gazzato70
Postby Rich O Brien » Sat Oct 16, 2021 4:47 pm
s870887s wrote:已購買ClothWorks 的授權,但始終沒有收到授權信件,
請看到回覆後,寄授權檔給我,謝謝,
因為已經超過24小時了 :cry:
Check inbox for email from support@sketchucation.com
Rich O Brien
Administrator
Postby Rich O Brien » Sat Oct 16, 2021 4:53 pm
gazzato70 wrote:Hi, I have a licensing problem with ClothWorks. I had to format the pc without being able to release the license. After the new installation I entered the licenses of the paid plugins and ClothWorks tells me that I am using 3 licenses while in fact I only use 1 license. I don't have other PCs where I use ClothWorks. I need help resetting the licensing situation. Thank you very much
The license logs show 3 devices in use with the most recent validation occurring 8 days ago...
Rich O Brien
Administrator
Postby Rich O Brien » Sat Oct 16, 2021 6:39 pm
請看到回覆後,寄授權檔給我,謝謝,
因為已經超過24小時了 :cry:
Rich O Brien
Administrator
Postby rodman100 » Sat Oct 16, 2021 10:27 pm
rodman100
Postby Rich O Brien » Sat Oct 16, 2021 10:58 pm
@rodman
Looks like it. The logs show this as what the user requested as address to send license to. Explains why it wasn't received.... :|
Rich O Brien
Administrator
Postby hydboxhydbox » Sun Oct 17, 2021 9:35 am
Hi there,
I have another technical question.
If I want to draw a model of an inflated object without air ( only small bulbs left inside), like the ones in the picture. It’s much thinner comparing to the pillow example in instruction.
So which ones of the parameters do I have to adjust?
the Thickness of the object (Cloth tab —Thickness)
the bubble inside (?)
the slightly puffy edge (?)
I have only used SketchUp for 3 months. And I was recommended Clothworks for this particular purpose. Or maybe it is not the best solution?
Please help.
Much appreciated.
Yida
hydboxhydbox
Postby hydboxhydbox » Sun Oct 17, 2021 10:09 am
hydboxhydbox wrote:Hi there,
Please help.
Much appreciated.
Yida
This is what I get...never be able to get it quite even
Or should I do the other way around, like draw a rectangle with thickness and then make the bubles separately? Use sandbox? But I tried sandbox, it can only create rectangle face not some puffy effect. I still want the most part of the object to look slightly puffy so it can be recognized as a flattened inflated object.
hydboxhydbox
PreviousNext
Return to Plugins
Users browsing this forum: aak_anyaa, chc3826, ericwang1111, Parkour and 20 guests
