[Plugin] ClothWorks v1.7.2 - 11 August 2019
Re: [Plugin] ClothWorks v1.7.0 - 19 July 2019
Postby Ahmed0007 » Wed Jul 24, 2019 9:51 am
Anton_S wrote:Void is used for excluding parts of the cloth mesh from simulation. If you have a large mesh and only want to simulate a part of it, you can use the Void shape. Simulating by parts improves simulation performance by a reasonable factor. If you use a pin to lock vertices in place, the locked portions of the mesh are still included in simulation and collide with other objects, hence no performance benefit.
Simulating by parts will be covered in the tents tutorial that I started making but came across a thing that needs improvement. The void shape will definitely be covered upon releasing version 1.8.
thank you so much for explanation.
Ahmed0007
Postby Ahmed0007 » Fri Jul 26, 2019 2:40 pm
Request.
Please add all context menu option in ClothWorks UI.
it would be great and time saving.
3
Ahmed0007
Postby 1852sketch » Wed Jul 31, 2019 11:37 am
Hello Anyone,
I was told to try hear to find out how to get my validation email sent to me. I did purchase Cloth Works on July 26th, 2019. I did receive my Pal Pay receipt but still waiting on the email from Sketchucation to complete the license.
I have tried to contact MikeL and Rich from their provided email message area`s from Contacts on this site. I have not heard anything from them and it is now the 31st. How can I get in touch with them to get the email. I have no choice but to have Pay Pal get my money back. I am lost and never have waited this long and to not hear anything, well sucks. I hope someone can help ...I just want to use the product.....
1852sketch
Postby Gábor » Wed Jul 31, 2019 5:56 pm
Hello 1852sketch,
I confirm that you've purchased ClothWorks. Our system sent out the license at time of the purchase by email. I've re-sent you your purchased ClothWorks license now. The email address you gave at the purchase and your email address what is registered here are different. Now I've sent the license to both email addresses. I hope you'll receive it this time.
Thank you for your purchase.
Gábor
SketchUcation IT
Postby jkeller3 » Wed Aug 07, 2019 8:46 pm
I've been using this extension for some time now but I currently have an issue. Clothworks is crashing when ever I go to drop a cloth over a 3d item. Single plane it has no issue, but if there are 2 or more angels outside of the one plane it crashes with no warning, or lag.
jkeller3
Premium Member
Premium Member
Postby Dave R » Wed Aug 07, 2019 11:36 pm
If you share the SKP file so we can see what you are trying to do, we can give you some help.
Global Moderator
Postby Anton_S » Thu Aug 08, 2019 12:55 am
jkeller3 wrote:I've been using this extension for some time now but I currently have an issue. Clothworks is crashing when ever I go to drop a cloth over a 3d item. Single plane it has no issue, but if there are 2 or more angels outside of the one plane it crashes with no warning, or lag.
Yes, please share a model or send me a private message of your model, that I could look into the issue. Also, are you using ClothWorks v1.7.0 or an older version?
Anton_S
PluginStore Author
PluginStore Author
Postby jkeller3 » Thu Aug 08, 2019 2:34 pm
Anton,
I DM'd you a skp file and screen capture of what happens. It happens with all SKP files no matter how complicated or simple. At first I thought maybe the geometry I was using was too complicated but you can see with that simple file simple draping does not work for me. This file used a quadrilateral grid at 3000 and default settings. I've uninstalled CW and reinstalled it. Versions of my software are:
OSX Mojave Version 10.14.5
sketchup Version 19.2.221
ClothWorks version 1.7.0a
jkeller3
Premium Member
Premium Member
Postby Anton_S » Fri Aug 09, 2019 6:08 am
Joe Keller,
I am able to reproduce the crash on my Mac OS X 10.14 but not on my Windows 10. I will look into fixing the issue as soon as possible. Thank you for the report!
Anton
Anton_S
PluginStore Author
PluginStore Author
Re: [Plugin] ClothWorks v1.7.1 - 10 August 2019
Postby Anton_S » Sun Aug 11, 2019 12:01 am
Announcing version 1.7.1:
  1. Fixed crash on Mac OS X. Thanks to jkeller3 for the report.
  2. Added Spanish language. Thanks to Oxer for the translations.
Anton_S
PluginStore Author
PluginStore Author
Postby summerson1990 » Sun Aug 11, 2019 12:16 am
Just bought this plugin and saw a new version released (1.7.1a) but when updated the toggle UI interface is not working anymore. It can't be opened. I use SU 2019 PRO on win 10.
summerson1990
Postby summerson1990 » Sun Aug 11, 2019 1:13 am
Anton_S wrote:Announcing version 1.7.1:
Hi! v1.7.1 and 1.7.0 toggle UI not working on SU 2019 PRO, Windows 10
summerson1990
Postby Anton_S » Sun Aug 11, 2019 5:14 am
summerson1990 wrote:Just bought this plugin and saw a new version released (1.7.1a) but when updated the toggle UI interface is not working anymore. It can't be opened. I use SU 2019 PRO on win 10.
The Toggle UI toolbar option works correctly on my system. Please do a clean installation of the plugin. Navigate to your plugins folder and delete ams_ClothWorks folder and ams_ClothWorks.rb file. Then do a clean installation of version 1.7.1.
There are two plugin folders. To navigate to the first plugins folder, open a file explorer window and paste the following into the address bar: %appdata%\sketchup\SketchUp 2019\SketchUp\Plugins
The second plugins folder is located at:
C:\ProgramData\SketchUp\SketchUp 2019\SketchUp\Plugins
Ensure that original version is deleted from both folders prior to installing the new version.
Anton_S
PluginStore Author
PluginStore Author
Postby summerson1990 » Sun Aug 11, 2019 11:34 am
Maybe you are using not a last release of SU (2019.2)? Because I did exactly you adviced and still the problem exists... I can make a gif screenshot in order to prove it.
summerson1990
Postby Dave R » Sun Aug 11, 2019 1:33 pm
This is what I see on 2019.2.
Global Moderator
Postby summerson1990 » Sun Aug 11, 2019 2:51 pm
Dave R wrote:This is what I see on 2019.2.
Ok, so what's the problem with mine? See an attached gif by link https://dropmefiles.com/gDreG.
summerson1990
Postby Dave R » Sun Aug 11, 2019 3:02 pm
When you installed 2019.2, did you do so correctly? That is, did you right click on the downloaded installer and choose Run as administrator while logged into Windows under your normal user ID? We've seen lots of weird problems related to incorrect installation of SketchUp when users haven't used Run as administrator.
Global Moderator
Re: [Plugin] ClothWorks v1.7.2 - 11 August 2019
Postby Anton_S » Sun Aug 11, 2019 3:06 pm
@summerson1990 I fixed the issue. Please update to 1.7.2. The problem had to do with non-ascii username. I originally relied on the ENV variable to get path to appdata. I see that the ENV variable has issues with non-ascii usernames. With 1.7.2, I updated to use Windows API to get the appdata path. Thank you for the report and my apologies for the inconvenience!
Anton_S
PluginStore Author
PluginStore Author
Postby summerson1990 » Sun Aug 11, 2019 3:23 pm
Anton_S wrote:@summerson1990 I fixed the issue. Please update to 1.7.2. The problem had to do with non-ascii username. I originally relied on the ENV variable to get path to appdata. I see that the ENV variable has issues with non-ascii usernames. With 1.7.2, I updated to use Windows API to get the appdata path. Thank you for the report and my apologies for the inconvenience!
Yes, now it works fine, thanks a lot!)
summerson1990
Postby jbf » Tue Aug 20, 2019 1:15 pm
Help needed...
I`m rather new to sketchup- I am playing around with Clothworks and I have ran in to a problem regards adding a pattern to the cloth. I have followed the instuctionvideo to the point- but the pattern breaks/cracks in the bendings (see pic.) what am I doing wrong? hoping someone can help me on the way- Thanks
jbf
Postby Anton_S » Thu Aug 22, 2019 1:34 am
@jbf You have to apply pattern (material) directly to the faces of the cloth. Do not apply material to the top level group. See one of the ClothWorks videos for applying material.
Anton_S
PluginStore Author
PluginStore Author
Postby jbf » Thu Aug 22, 2019 7:57 am
Anton_S wrote:@jbf You have to apply pattern (material) directly to the faces of the cloth. Do not apply material to the top level group. See one of the ClothWorks videos for applying material.
Thank you so much Anton- I can´t belive I overlooked that small detail. everything is working as it should :thumb:
jbf
Postby kelly13 » Mon Sep 23, 2019 6:00 am
В скетчапе ссылка на лицензию предлагает купить только через PayPal - а пейпел заблокировал мой счет и потребовал предоставить скан документа, удостоверяющего личность с фото и прописку, адрес по месту жительства. Я живу в строящемся доме, который принадлежит мне, но у него все еще нет официального адреса и поэтому у меня нет в паспорте прописки.
Я предоставила сервису Paypal квитанцию об оплате электроэнергии с моей фамилией и адресом, но счет мне до сих пор не разблокирован.
Очень хочу купить вашу лицензию, неужели нельзя по-другому, НЕ через PayPal ?
translated from Russian by Google translator
In the sketchup, the link to the license offers to be bought only through PayPal - and the paper blocked my account and demanded to provide a scan of an identity document with a photo and registration, address at the place of residence. I live in a house under construction, which belongs to me, but it still does not have an official address and therefore I do not have a residence permit in my passport.
I provided Paypal with a receipt for payment of electricity with my name and address, but my account has not yet been unblocked.
I really want to buy your license, is there really no other way, NOT through PayPal?
kelly13
Postby Anton_S » Mon Sep 23, 2019 7:18 pm
Здравствуйте Евгения! Вам не нужен PayPal для покупки ClothWorks. Нажмите на кнопку "Check Out", чтобы купить, используя другой метод. Смотрите прикрепленные скриншоты.
Anton_S
PluginStore Author
PluginStore Author
Postby chjblack1234 » Thu Oct 17, 2019 8:21 am
ruby name is clothworks
I bought a ruby. by the way, I wrote my email address wrong. What should I do? Who should I talk to?
I'm so annoying now T.T
chjblack1234
Postby Gus R » Thu Oct 17, 2019 5:56 pm
Anton,
Upgraded to the recent release and I don't have the licensing problems I had last year.
I am having difficulty reading the UI which appears to be a problem with other extensions on Sketchup. It appears to be using MSIE on my system.
Is there a way to increase the size of the UI since I find it difficult to read? Zooming in doesn't work. I imagine it would require some tweaking of the UI.css or the html.
This is what it looks like.
Gus R
Postby Gus R » Thu Oct 17, 2019 6:10 pm
Looks like I already answered my own question.
I changed the "font family" line to "Arial" on the ui.css as such:
font-family: "Arial", Helvetica, Arial, sans-serif;
Then I increased the font sizes from 12px to 14px. It worked with 12px as well.
Now it looks like this.
Gus R
Postby Anton_S » Fri Oct 18, 2019 12:52 am
Thanks for the report and the solution, Gus R. I have only tested this with Windows 10 but I see that Windows 7, with an older version of IE, needs some CSS adjustments. Once again, thank you.
Anton_S
PluginStore Author
PluginStore Author
Postby Gus R » Sat Oct 19, 2019 9:58 pm
Anton_S wrote:Thanks for the report and the solution, Gus R. I have only tested this with Windows 10 but I see that Windows 7, with an older version of IE, needs some CSS adjustments. Once again, thank you.
You're welcome Anton.
It looks like it's un-validating itself again when I empty out my directory located at "C:\Users\Asus P8P67 Deluxe\AppData\Local\Temp."
I'm able to validate the license again without losing any seats. I can keep Sketchup open and clear out the contents of the temp directory and I lose the validation. I re-validate and it creates a random directory with a .tmp file located there.
Maybe the attached screenshot provides a hint?
Gus R
Postby Anton_S » Sat Oct 19, 2019 10:33 pm
Are you using the latest version of SketchUcationTools? By the way, I reset your seat count. It was full.
Anton_S
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: alexmartinez, Erikvanderbilts, Sekar24 and 8 guests
