[Plugin] ClothWorks v1.7.2 - 11 August 2019
Re: [Plugin] ClothWorks v1.5.2 - 18 Dec 2018
Postby Edson » Thu Jun 27, 2019 12:24 pm
I wonder if you could help me with a problem I am having. Clothworks is running very slowly and I do not know what to change for it to behave as one sees in the tutorials. Both Outliner and Components dialogues are closed.
By the way, I am trying to create a curtain.
I am attaching a pair of screenshots of the UI for you to see the parameters I have set.
I hope you can help me. Thanks in advance.
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby Anton_S » Fri Jun 28, 2019 6:33 am
Edson,
Try reducing thickness, to 2 mm. This may improve performance. When simulating curtains, you need to apply an equilateral grid and have self-collision turned on.
Also, it looks like gravity is too high. Same could apply to viscosity.
I will create a tutorial for curtains with never CW upon releasing the next version.
Anton
Anton_S
PluginStore Author
PluginStore Author
Postby Edson » Fri Jun 28, 2019 11:07 am
Thanks, Anton. All of it helps but I still wish it would move a little faster. Which is the property that controls it?
Best regards.
Edson
Edson
Global Moderator
Postby efrey1991 » Fri Jun 28, 2019 12:41 pm
hola amigo de ante mano agradezco por tal herramienta que pues le da a nuestros proyectos un mejora extra un realismo impresionante.
tengo un pequeño inconveniente cuando APPLY EQULATERAL GRID. BUENO ESTO ME PIDE QUE por favor active su licencia de clothworks para desbloquear la rejilla adaptable, apreciaría este favor
efrey1991
Postby Edson » Fri Jun 28, 2019 6:48 pm
efrey1991 wrote:hola amigo de ante mano agradezco por tal herramienta que pues le da a nuestros proyectos un mejora extra un realismo impresionante.
hola efrey,
si no escribes en inglés no te van a contestar. son pocos los que hablan castellano en este forum y es cierto que los que lo dirigen no lo hacen. creo que anton tampoco lo hablará.
saludos.
edson
Edson
Global Moderator
Postby Anton_S » Mon Jul 01, 2019 6:50 pm
Edson wrote:Thanks, Anton. All of it helps but I still wish it would move a little faster. Which is the property that controls it?
Best regards.
Edson
Edson, you may be experiencing a performance issue, which can't be fixed due to the limitation of the plugin itself. If you send me private message of your model, I will take a look and see if anything could be done to improve performance.
Anton_S
PluginStore Author
PluginStore Author
Postby Edson » Mon Jul 01, 2019 7:01 pm
Thanks. I will do that shortly.
Edson
Global Moderator
Postby Anton_S » Mon Jul 01, 2019 7:03 pm
Equilateral and quadrilateral grids work without licensing. The adjustable grid only works with licensing. If you desire to use equilateral grid, you do not need to license the plugin.
Anton_S
PluginStore Author
PluginStore Author
Postby jo-ke » Wed Jul 03, 2019 3:01 pm
Anton_S wrote:@jo-ke Did you use the extension manager to install ClothWorks? If not, install ClothWorks RBZ via the Extension Manager (and also SketchUcationTools if desired for licensing):
  1. Open SketchUp 2019
  2. Select (Menu) Window -> Extension Manager
  3. Click Install Extension button
  4. Select the downloaded RBZ file
  5. Restart SketchUp
Let me know if this works.
Still not able to reinstall.
Installing via Scetchucationtool I am getting the error: "UnZIP error: Could not unzip archive"
Strange...
jo-ke
Premium Member
Premium Member
Postby jo-ke » Wed Jul 03, 2019 3:33 pm
Now I used a different library to save the extension.
I relicensed the product and it worked well.
After restarting SU everything disappered. :-(
What did I wrong?
jo-ke
Premium Member
Premium Member
Postby Dave R » Wed Jul 03, 2019 3:46 pm
This sounds like a problem typical of incorrect installation of SketchUp. When you installed SketchUp 2018 (I assume that's the version you are using as indicated in your profile), did you right click on the downloaded installer file and select Run as administrator from the context menu?
Global Moderator
Postby jo-ke » Thu Jul 04, 2019 12:55 pm
Oh since a few months I am using SU2019.
I just started the exe file and installed SU and followed the instructions.
jo-ke
Premium Member
Premium Member
Postby Dave R » Thu Jul 04, 2019 1:29 pm
So does that mean that you did not install SketchUp 2019 by right clicking and selecting Run as administrator? If you didn't, close SketchUp and repair the installation. Find the downloaded installer file, right click on it. Choose Run as administrator and when presented with the options, select Repair.
Global Moderator
Postby jo-ke » Fri Jul 05, 2019 11:32 am
OK Thank you. I will try it and report....
jo-ke
Premium Member
Premium Member
Postby jo-ke » Fri Jul 05, 2019 11:37 am
I hate it... Where can I find the current download of SU2019pro.
Can't find it at the homepage of SU....
jo-ke
Premium Member
Premium Member
Postby juju » Fri Jul 05, 2019 11:46 am
jo-ke wrote:I hate it... Where can I find the current download of SU2019pro.
https://www.sketchup.com/download/all
juju
Premium Member
Premium Member
Postby jo-ke » Fri Jul 05, 2019 1:06 pm
Thank you juju. OK, found the installation file, downloaded it, ran as admin, repaired su and restarted my pc. Started su and: clothworks dissappeared again. :-(
jo-ke
Premium Member
Premium Member
Postby Anton_S » Sat Jul 06, 2019 12:32 am
jo-ke wrote:Thank you juju. OK, found the installation file, downloaded it, ran as admin, repaired su and restarted my pc. Started su and: clothworks dissappeared again. :-(
Does this occur to all your plugins or just ClothWorks?
Anton_S
PluginStore Author
PluginStore Author
Postby jo-ke » Sun Jul 07, 2019 10:40 am
It affects only clothworks
jo-ke
Premium Member
Premium Member
Postby jo-ke » Wed Jul 10, 2019 3:42 pm
somebody any idea?
jo-ke
Premium Member
Premium Member
Postby Dave R » Wed Jul 10, 2019 4:22 pm
jo-ke wrote:Started su and: clothworks dissappeared again. :-(
What exactly does "dissappeared" mean? Is it only that the toolbar doesn't show? Does it show in the Extensions menu? Does it show in Extension Manager? If it does, does it show as Enabled?
Global Moderator
Postby jo-ke » Thu Jul 11, 2019 8:31 am
first session:
starting SU installing clothworks. everything OK.
clothing SU
second session:
starting SU, clothworks dissappeared completely.
jo-ke
Premium Member
Premium Member
Postby Anton_S » Fri Jul 12, 2019 7:40 am
@jo-ke In your second screenshot, you have ams_ClothWorks at line 2. I am totally not sure where that is coming from.
Paste the following into your file explorer address bar and send a screenshot of the plugins: %appdata%\sketchup\SketchUp 2019\SketchUp\Plugins
Then navigate into the ams_ClothWorks folder (if any) and send a screenshot.
Then, paste the following into your file explorer, and send a screenshot, if the Plugins folder exists:
C:\ProgramData\SketchUp\SketchUp 2019\SketchUp\Plugins
Anton_S
PluginStore Author
PluginStore Author
Postby jo-ke » Fri Jul 12, 2019 11:49 am
OK, theses are the two screenshots:
jo-ke
Premium Member
Premium Member
Postby Anton_S » Sat Jul 13, 2019 1:36 am
As you can see, you have the same plugin installed in both locations. Delete the plugin from one of the installed locations. To delete the plugin, delete ams_ClothWorks folder and ams_ClothWorks.rb file from either program data or roaming. I see that the one located in roaming is newer.
Anton_S
PluginStore Author
PluginStore Author
Postby jo-ke » Sun Jul 14, 2019 11:54 am
Thats it!
I deleted all folders in both directories and the rb files and reinstalled the plugin.
restarted su and: it was still there!
Thank you
jo-ke
Premium Member
Premium Member
Postby Dave R » Sun Jul 14, 2019 12:43 pm
This begs the question, how did you install Clothworks in the first place? With the normal installation methods, you shouldn't have been able to get it installed in the two directories. It should have only been installed in User/App Data/Roaming...
Global Moderator
Re: [Plugin] ClothWorks v1.7.0 - 19 July 2019
Postby Anton_S » Fri Jul 19, 2019 9:39 am
Announcing version 1.7.0.
Changes include:
  1. Added Russian translation. Desired language is accessible from ClothWorks menu.
  2. Added thickness generator for both cloth and strings. Cloth with thickness can be subdivided and draped/undraped, just like cloth without thickness. It is, however, not recommended to simulate cloth after generated thickness. Generating thikness, just like applying loop subdivision or laplacian smoothing, is for finalizing results.
  3. Added a feature to simulate by parts. When simulation starts, objects assigned Void state subtract cloth and collider vertices overlapping their axes-aligned bounding boxes. Subtracted vertices are not included in simulation.
  4. Added an option to draw cloth using SketchUp OpenGL API. Drawing cloth rather than transforming vertices guarantees a better performance, especially when simulating by parts. If Adaptive Remeshing is turned on, mesh resolution changes are drawn dynamically. When simulation is stopped, the original mesh is transformed/generated as necessary.
  5. Reworked gizmo. The new gizmo allows for translating, rotating, converging, and diverging selected pin(s).
  6. Fixed drag for strings.
  7. Fixed freezing issue when applying loop subdivision to undraped cloth.
  8. Completed the multi-threaded solver. If multi-threaded solver is turned on, most simulation tasks are distributed across all the available CPUs.
  9. Completed adaptive remeshing. Now, both cloth and strings are both refined and coarsened. Additionally, simulation can now be stopped and resumed from an adaptively refined mesh. Note that an adaptively refined mesh cannot be recorded.
  10. Updated manual
5
Anton_S
PluginStore Author
PluginStore Author
Postby Ahmed0007 » Tue Jul 23, 2019 7:04 pm
Thank you so much for this amazing Update
i have a question.
i can use custom pin (cube) as a Void object and get same results so what is the main use of Void group?
Ahmed0007
Postby Anton_S » Wed Jul 24, 2019 2:05 am
Void is used for excluding parts of the cloth mesh from simulation. If you have a large mesh and only want to simulate a part of it, you can use the Void shape. Simulating by parts improves simulation performance by a reasonable factor. If you use a pin to lock vertices in place, the locked portions of the mesh are still included in simulation and collide with other objects, hence no performance benefit.
Simulating by parts will be covered in the tents tutorial that I started making but came across a thing that needs improvement. The void shape will definitely be covered upon releasing version 1.8.
Anton_S
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: Hidezkoga, Sekar24 and 7 guests
