[Plugin] ClothWorks v1.7.2 - 11 Aug 2019
Re: [Plugin] ClothWorks - 28 March 2018
Postby Box » Wed Mar 28, 2018 5:40 pm
Let me know Rich if you need me to scribble a valentines or anniversary card for you.
3
Postby Pixero » Wed Mar 28, 2018 5:53 pm
Possible BUG: In the Time step drop down there are two 1/840.
Pixero
Postby cowboyathome » Wed Mar 28, 2018 6:32 pm
I'm trying to do some curtains and am not seeing the grab handles to converge the pins.
Is that a licensed option?
cowboyathome
Postby Dave R » Wed Mar 28, 2018 6:35 pm
cowboyathome wrote:I'm trying to do some curtains and am not seeing the grab handles to converge the pins.
Read the instructions PDF. You'll see what is not enabled if you haven't licensed it yet.
Pins require a license.
Global Moderator
Postby cowboyathome » Wed Mar 28, 2018 6:39 pm
Ok. Thanks.
cowboyathome
Postby alvis » Wed Mar 28, 2018 7:03 pm
Wow. Impressive. Big thanks.
7
alvis
Premium Member
Premium Member
Postby Frederik » Wed Mar 28, 2018 7:12 pm
Rich O Brien wrote:
Box wrote:I look forward to the day when I can drop my balls into soft leather.
:o You should write romantic novels
Box wrote:Let me know Rich if you need me to scribble a valentines or anniversary card for you.
:roflmao:
You two love birds...! :roflmao:
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby Oxer » Wed Mar 28, 2018 7:27 pm
Incredible plugin!! :thumb:
I'll test it on Mac, if it works, I'll never come back to Blender to make clothes simulation.
http://www.oxervision.blogspot.com/
Oxer
Postby Rich O Brien » Wed Mar 28, 2018 7:32 pm
Oxer wrote:Incredible plugin!! :thumb:
The only issue on Mac is the on reboot the license needs validating each time. We'll issue a fix for that next week.
Rich O Brien
Administrator
Postby Oxer » Wed Mar 28, 2018 7:36 pm
Thanks for the info Rich.
Oxer
Postby HornOxx » Wed Mar 28, 2018 8:28 pm
:oops: :oops:
OMG it is so embarrassing for me to post this question in the forum - I can not understand how an activation or a license purchase work, more precisely neither how nor where. My lack of English does not allow me to understand what is explained in the manual PDF :oops:
Since this tool is again such a milestone obviously I also want to try and use it and can hardly wait - please help me (btw - the plugin installation worked perfectly)
never trust a skinny cook
HornOxx
Postby Rich O Brien » Wed Mar 28, 2018 9:00 pm
Use Extensions > ClothWorks > License...
Click Obtain License...
Sign in to your SketchUcation account and purchase with PayPal.
License unlocks all the features mentioned in the manual.
Rich O Brien
Administrator
Postby fredo6 » Wed Mar 28, 2018 9:05 pm
HornOxx wrote::oops: :oops:
You can test the license workflow with my Plugin Souvenir, which uses the same SCF License, but is completely FREE. So you can try as many times as you wish.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby derei » Wed Mar 28, 2018 10:25 pm
I played a bit with ClothWorks and I can say it blew my panties off :mrgreen:
Anyway, I would have some suggestions:
- quick reset button for sliders (for example, to quickly reset gravity to default, or wind to zero, etc). This is because while simulation is running, sliders may be have a lag in response time, but one click button would be much faster.
- some sliders (drag, viscosity, etc) could use a non-linear variation, because as they are now, the slightest move of the cursor can jump the value a lot. Probably at the left end of the slider, the increase should be slower and increase the value following a exponential curve (or other function, should be tested)
- like Fredo's Animator, this plugin could make use of automatic video exporting, using FFMPEG, for example.
Thanks for a wonderful plugin!
the clip speed had to be increased 5x, because the animation was incredibly slow in SketchUp
6
DESIGNER AND ARTIST DEREI.UK
derei
Postby Bob James » Wed Mar 28, 2018 11:45 pm
An amazing tool!!
Is it possible to adapt it to drape a flag vertically at rest on a pole? For example, a flag standing on pole inside a room.
Bob James
Premium Member
Premium Member
Postby boofredlay » Thu Mar 29, 2018 12:03 am
Yep
boofredlay
Global Moderator
Postby alpro » Thu Mar 29, 2018 12:37 am
Looks awesome.....off to get it now
alpro
Premium Member
Premium Member
Postby Anton_S » Thu Mar 29, 2018 12:44 am
Here is a higher resolution simulation of an American Flag.
A roughly 100cm X 170cm rectangle was drawn for the flag and applied a grid with spacing of 4cm.
The pole was assigned a collider state. Pins were attached at upper and lower right corners of the flag.
Using ClothWorks UI, flag thickness was increased to 20mm to prevent self-overlaps.
After simulation, I applied loop subdivision and followed with 2 Laplacian smoothing iteration to eliminate rounded corners formed by loop subdivision.
A texture was assigned at the end, utilizing the Toggle Draped option.
UnitedStatesFlag.skp
Anton_S
PluginStore Author
PluginStore Author
Postby Dave R » Thu Mar 29, 2018 12:52 am
More play
5
Global Moderator
Postby pilou » Thu Mar 29, 2018 1:06 am
Beautiful drapé! :fro:
Speedy Galerie
Top SketchUcator
Postby alpro » Thu Mar 29, 2018 1:11 am
Just purchased....great plugin
alpro
Premium Member
Premium Member
Postby Dave R » Thu Mar 29, 2018 1:31 am
This is with one of the SUC fabrics.
5
Global Moderator
Postby l_breault » Thu Mar 29, 2018 2:06 am
Looking forward to trying this out! Too much work going on for awhile is going to put a damper on this. Where's the examples of comforters?
Thanks,
Leo Breault
www.breaultdesignstudio.com
l_breault
Premium Member
Premium Member
Postby solo » Thu Mar 29, 2018 2:35 am
l_breault wrote:Looking forward to trying this out! Too much work going on for awhile is going to put a damper on this. Where's the examples of comforters?
I hear ya, I too bought this but too much work right now to play, I have been anticipating this for a while.
http://www.solos-art.com
solo
Global Moderator
Postby Arc » Thu Mar 29, 2018 5:13 am
Is this license a permanent license? How many computers with one license support?
Arc
Postby HornOxx » Thu Mar 29, 2018 5:56 am
Rich O Brien wrote:Use Extensions > ClothWorks > License...
:thumb:
Thanks Rich and Fredo - I didn´t had installed SketchUcation Tools so this required window for licensing was not available - Well, now I got it :D
HornOxx
Postby Pixero » Thu Mar 29, 2018 7:11 am
Arc wrote:Is this license a permanent license? How many computers with one license support?
It's 3 computers.
Pixero
Postby Anton_S » Thu Mar 29, 2018 8:24 am
Pixero wrote:Possible BUG: In the Time step drop down there are two 1/840.
Yes, that's just a typo in the dialog. When you use the second 1/840 option, the actual timestep set is 1/960. Already fixed and will be updated in next release.
It's 3 computers.
Additionally, the way SCFLicense works is that if you release (deactivate) a licence you can use the licence on another device or reactivate it on the same device. So, there is no limit to the number of times the licence can be activated/deactivated, as long as it is on up to 3 devices.
Anton_S
PluginStore Author
PluginStore Author
Postby Bob James » Thu Mar 29, 2018 8:40 am
Anton_S wrote:Here is a higher resolution simulation of an American Flag.
Sold :!:
Bob James
Premium Member
Premium Member
Postby marvsweden » Thu Mar 29, 2018 9:29 am
Purchased. It's going to be exciting using it.
I'm on Mac/SU2018 and the toggle UI window/button doesn't work. It shows up once but if I toggle it by hitting the button it never shows up again until i shut down and restart SU.
marvsweden
PreviousNext
Return to Plugins
Users browsing this forum: bramkibi, kaiomichiru, m_habibi and 9 guests
