[Plugin][$] Grabby (1.0.3)
Postby renderiza » Mon Mar 26, 2018 1:21 am
Welcome, SketchUp Heroes!
Give your SketchUp Super Powers with Extensions / Plugins!
➜ Join SketchUp Heroes Mailing List!
Grabby v1.0.3 by Rafael Rivera
Grabby is a set of tools that help you select entities in more precise ways.
 Buy on Extension Warehouse 
or
 Buy on Sellfy 
Tools Overview:
EdgeGrab uses your mouse as a brush to select edges.
  • Click & hold the mouse button.
  • Hover over the edge entity you want to add to the selection.
  • If you hold SHIFT key it will deselect edge.
  • Press Esc key to exit tool once you're happy with your selection.
FaceGrab uses your mouse as a brush to select faces.
  • Hover over the face entity you want to add to the selection.
  • If you hold SHIFT key it will deselect face.
ExpandGrab expands the selection by one more polygon.
ShrinkGrab shrinks the selection by one more polygon.
LoopGrab selects edges that form a loop.
  • First, select a single edge for connecting loop.
  • Make sure the edge is part of a quad face.
  • Activate the tool...
  • And, if all went according to plan the loop should be selected.
More Extensions by RafaelRivera…
ColorHexGrabbyCompoSceneiSelect
renderiza
Premium Member
Premium Member
Re: [Plugin][$] Grabby
Postby renderiza » Wed Mar 28, 2018 6:00 am
Extension Update Grabby v1.0.1!
What is New...
  • Changed the Extension Name from EdgeGrab to Grabby
  • Apart from the EdgeGrab tool we now have FaceGrab and LoopGrab.
  • Shift Key will deselect edges or faces depending on the tool.
  • Fixed a bunch of bugs too big to list here
I hope this is a step in the right direction. If you have any recommendations let me know.
Cheers!
renderiza
Premium Member
Premium Member
Re: [Plugin][$] Grabby (1.0.2)
Postby renderiza » Fri Mar 30, 2018 1:19 am
Extension Update Grabby v1.0.2!
What is New...
  • Added two new tools named ExpandGrab and ShrinkGrab.
  • Now we have Animated Gifs showing how the tool works.
  • And other small upgrades to the code.
Hope you guys enjoy the new changes!
renderiza
Premium Member
Premium Member
Postby pilou » Fri Mar 30, 2018 8:13 am
Select! :fro:
Speedy Galerie
Top SketchUcator
Re: [Plugin][$] Grabby (1.0.3)
Postby renderiza » Sun Apr 01, 2018 1:47 am
Extension Update Grabby (1.0.3)
What is New…
  • Added cursor to FaceGrab and EdgeGrab.
  • Changed some toolbar icons.
  • Fixed bug that prevents activating another tool with just one click.
  • Fixed ShrinkGrab bug that left selected edges behind.
Example of ShrinkGrab working properly now...
Before...
After...
renderiza
Premium Member
Premium Member
Return to Plugins
Users browsing this forum: thalesbellucci and 224 guests
