[Obsolete] Component Spray Tool
Postby Didier Bur » Tue Jan 15, 2008 3:34 pm
--- PLEASE SEE LATEST VERSION BELOW ---
Hi all,
Here is the spray toy.
compo_spray.rb is for english users, version 1.12 (22.07.08)
fr_compo_spray.rb is for french users only, version 1.12 (22.07.08)
Enjoy :D
22.07.08: Latest version 1.12. Replace your old version in your Plugins folder.
New: accepts 2D components, bug fixes.
Obsolete version. Get the latest version here: viewtopic.php?f=323&t=11746
Reason: Removing old files. Redireting to new version.
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
[Plugin] Component Spray Tool v 1.1
Hi all,
Here is the new toy.
Enjoy :D
04.11.08
Hi there,
Here is a release of the spray tool, including a layer mask option, and some bug fixes (very high models with sky domes, active_layer automatically put in the dialog box, etc).
French version coming soon.
Enjoy,
Reason: Removed old download
Didier Bur
Didier Bur
Re: Component Spray Tool
Postby JGA » Sat Jan 19, 2008 12:14 am
Thanks very much, I'm sure it'll come in handy once I've had a go.
Regards,
JGA
JGA
Postby CadFather » Sun Jan 20, 2008 12:20 am
doesn't seem to work with me
when spraying i always get the circle (whatever my settings) - click centre, radius and nothing happens.. just once i managed point, only after setting both default and dialog the same.
also tried it on a clean install.. is it just me?
CadFather
PluginStore Author
PluginStore Author
Postby Didier Bur » Sun Jan 20, 2008 10:01 am
Hi CadFather,
Please post an example SKP so I can see if the problem is script-related or not.
Regards,
Didier Bur
Didier Bur
Postby CadFather » Sun Jan 20, 2008 11:27 am
well there's no skp really - all i did was put a rectangular ground plane, and then tried the spray on it. also tried on a small sandbox mesh.
i tried again after posting yesterday and got the spray by point to work. the others though, will recognise the first click (centre of shape) but not the second so that i am in a sort of loop and the shape does not set.
i noticed at times if i drew the radius (second click), way beyond the mesh a message would pop up warning me that a huge number of comps would be sprayed, when i reduced the radius to be inside the boundaries of the mesh, nothing happened..
i will keep lookng into it - i seem to be the only one with this
by the way great ruby, even by point it is great.
CadFather
PluginStore Author
PluginStore Author
Postby kobus » Mon Jan 21, 2008 9:14 am
nice tool ! respect.
you should be interested in the future. you will spend the rest of your life there
kobus
Postby Didier Bur » Mon Jan 21, 2008 11:43 am
Hi CadFather,
i think I've found what's wrong. It is bug-like but not really.
Watch the "Layer" list and select a layer, don't let this field blank the first time you use the script.
Am I right ?
Didier Bur
Didier Bur
Postby JAP » Mon Jan 21, 2008 11:47 am
Really nice tool, have used already quite a lot, very handy. Thanx Didier!
JAP
Postby CadFather » Mon Jan 21, 2008 6:02 pm
thanks for looking into it Didier - you are right, it works very well now and wow, really a must have tool, thanks!
so now i also know the intruding 2d bryce man in the 3d template has been drawn on 2 different layers!
CadFather
PluginStore Author
PluginStore Author
Postby marne » Tue Jan 22, 2008 9:24 am
Incredible!
I can't believe that this for free, you know that you gave away a "super-randor.rb" to us?
Thank you very much for the hours(?) you were spending for the devolpment. I agree with CadFather: A must have.
Thank you.
marne
Postby Didier Bur » Tue Jan 22, 2008 10:02 pm
Call me stupid, but what's a "super-randor.rb" ???
Didier Bur
Didier Bur
Postby CadFather » Wed Jan 23, 2008 8:59 am
it's a smustard plugin to randomise rotation and scale of selected objects by TBD
CadFather
PluginStore Author
PluginStore Author
Postby gorec » Thu Jan 24, 2008 1:22 pm
At me problem as well as at CadFather. Second click does not work.
I so did not understand that it is there needed to do with layers.
gorec
Postby CadFather » Thu Jan 24, 2008 1:49 pm
in the dialog box there is a layer field which has to be chosen
CadFather
PluginStore Author
PluginStore Author
Postby marne » Fri Jan 25, 2008 1:50 pm
Thanks CadFather. It's all said :)
marne
Postby rv1974 » Wed Jan 30, 2008 12:56 pm
Hi Didier!
May be it was discussed earlier ..
1.There are 2 bugs: the plug-in limits drop-down list of components (for example 290 in model is reduced to 10 in dialog).
2.drop-down list is not stable: drop-down list of components is visible only if down arrow
is continually pressed.
Thanks for attention.
rv1974
Postby dmytty » Sat Feb 16, 2008 8:00 pm
Didier Bur wrote:Hi all,
The last file is for french users only.
Enjoy :D
How about including the ability to use a layer as a mask for including/excluding selected areas for component placement? Or how about being able to select a material type to include/exclude? Thus, if I had a street layout on a layer, I could click on 'Streets' layer and use it as an exclude mask for vegetation. Or I could click on a 'Soils' layer and 'include' this for component placement. The material option would allow me to select a material named 'dirt' as receiving all vegetation components.
dmytty
Postby Didier Bur » Sat Feb 16, 2008 8:44 pm
Doable. It's on the wish_list ;)
Ruby API is guilty here...
Didier Bur
Didier Bur
Postby juju » Fri Apr 11, 2008 12:14 pm
rv1974 wrote:Hi Didier!
For the some or other reason the grass component I want isn't showing up in the drop-down list for components to spray. I've renamed the component so the name starts with a "#" as well as with a "01" in an attempt to get it to surface to the top of the list, but it still isn't showing up.
Does anybody have any idea how to get components onto the list that isn't showing up?
Please lend your support in this thread on the SketchUp forum to resolve problems with Extension Warehouse. This being ignored is not an option.
juju
Premium Member
Premium Member
Postby juju » Fri Apr 11, 2008 12:24 pm
OK, just tried the tool in a blank skippy. If you have a sky dome the spray tool doesn't work as expected - stuff ends up on top of the sky dome.
Didier, is it possible for you to sort this out?
juju
Premium Member
Premium Member
Postby remus » Fri Apr 11, 2008 12:31 pm
Couldnt you just spray the components and then place the sky dome?
remus
Postby juju » Fri Apr 11, 2008 12:56 pm
I've moved the surface on which I want to spray above the sky dome, but it is still not working as expected.
The surface is in a group, the group is active and I am able to select the surface and make changes to it. The spray tool keeps on returning an error about there not being a surface onto which to spray (not so, there is) tried up to 3000 tries.
Still trying to get the component of choice onto the list to pick from (which component to spray).
I'm working through the manual again to see if there is anything I missed.
juju
Premium Member
Premium Member
Postby Didier Bur » Fri Apr 11, 2008 7:48 pm
Oh oh,
It seems that I have missed some particular situations (sky dome).
I have totweak the script, and implement the layer mask feature.
Next release coming...today.
@Juju: you didn't miss anything... me yes.
Didier Bur
Didier Bur
Re: [Plugin] Component Spray Tool v 1.1
Postby juju » Sat Apr 12, 2008 11:51 am
Merci le bureau principal. Vous êtes l'homme !
(Thank you master Bur. You are the man!) - thanks to Babelfish translation.
juju
Premium Member
Premium Member
Postby juju » Sat Apr 19, 2008 3:56 pm
Didier Bur wrote:Oh oh,
Didier, any news on this?
+++ EDIT +++
No bother, found the updated script. THANKS!
juju
Premium Member
Premium Member
Postby Didier Bur » Sun Apr 20, 2008 6:17 pm
Hi Juju,
Did you d/l last version from 04.11.08 ? Perhaps you missed it.
(2nd post of page 1 of this thread).
I thought it would work :roll:
Didier Bur
Didier Bur
Postby a4chitect » Sun Apr 20, 2008 7:07 pm
missed that one too! eager to try it out, thanks didier! :fecstatic:
a4chitect
PluginStore Author
PluginStore Author
Postby juju » Sun Apr 20, 2008 7:52 pm
Didier Bur wrote:Hi Juju,
Juju wrote:+++ EDIT +++
Didier, thanks for the follow-up. Yup, found it shortly after posting the comment, thus I edited it as above.
I have not tried it again, will do so later on and report back (obviously) if I experience any difficulties.
juju
Premium Member
Premium Member
Postby Jorgensen » Sun Apr 20, 2008 8:06 pm
Any plans on creating a toolbar for this nice script ?
sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
Jorgensen
Next
Return to Plugins
Users browsing this forum: vanyouhandleit and 6 guests
