Medeek Wall Plugin
Re: Medeek Wall Plugin
Postby medeek » Sun Jan 24, 2021 9:30 am
First look at an exterior wall with the second layer of sheathing material installed. In this case I have chosen foam insulation as the material:
Nathaniel P. Wilkerson PE
Medeek Engineering Inc
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Jan 24, 2021 8:13 pm
Either layer can be any of the typical sheathing materials as well as custom materials from the Material Library.
You can use Zip Sheathing on Layer 2 and insulation on Layer 1 as shown:
*Cladding layer turned off for visibility.
** Each sheathing layer is set to "LAP" at the corners.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Jan 24, 2021 8:15 pm
A couple more possible permutations:
If you turn off layer 1 of the sheathing the 2nd layer will be installed as if the first layer existed which allows one to introduce an air gap (equal to the thickness of layer 1) between the sheathing and framing.
The second example shows an air gap between the framing and sheathing and an air gap between the sheathing and cladding (via the cladding air gap parameter).
Now I just need to do a whole ton of error checking to make sure all of the other routines for placing doors, windows, trim, quoins, and annotations all work seamlessly when this second layer of sheathing is invoked. It will be another 2-3 days of tedious checking and testing, at a minimum.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Jan 27, 2021 1:57 am
Version 1.8.2 - 01.26.2021
- Enabled a second layer of sheathing for exterior rectangular walls.
- Added four additional parameters to the Sheathing tab of the Global Settings.
!!! CAUTION !!!
Upgrading from all previous versions of the wall plugin to this version (1.8.2) will require that all rectangular wall presets be deleted and recreated. Please do not upgrade to this latest version until you understand the implications of this upgrade. Also note that the 2nd layer of sheathing has not been implemented for gable, shed or hip wall types, only for rectangular walls.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Jan 27, 2021 4:46 am
As I was wrapping things up today with the new release (Version 1.8.2) I got yet another email requesting steel studs be incorporated into the plugin.
With a bit of clever manipulations of some basic materials applied to certain faces you can create a fairly realistic looking steel stud (also one face is hidden):
View model here:
https://3dwarehouse.sketchup.com/model/ ... ds-Study-1
The problem I see with this is that the stud lengths are really not the correct lengths that the steel studs would be. The other major issue is that the around openings the configuration of steel studs with steel headers is a bit more complex than a standard wood framed wall.
So barring major changes to the code the best I can probably do right now is a "cosmetic" steel framed wall. To do this properly would require entirely new algorithms for bottom and top channels, steel headers and the proper configuration of the king stud to header connections.
5
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Jan 28, 2021 5:57 am
Version 1.8.2b - 01.27.2021
- Enabled a second layer of sheathing for exterior gable walls.
I only have the hip and shed walls left to update.
!!! CAUTION !!!
Installing this update will require that you delete and recreate any GABLE wall presets that you have previously configured. This update will not affect any rectangular, shed or hip wall presets.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Fri Jan 29, 2021 1:26 am
Version 1.8.2c - 01.28.2021
- Enabled a second layer of sheathing for exterior shed and hip walls.
!!! CAUTION !!!
Installing this update will require that you delete and recreate any HIP or SHED wall presets that you have previously configured. This update will not affect any rectangular or gable wall presets.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Fri Jan 29, 2021 4:38 pm
This completes all of the upgrades necessary to enable the 2nd sheathing layer for all wall types. A tedious but necessary process, over 30 files where updated in the code but only four actual parameters added to the wall types.
Some minor cosmetic updates to the draw and edit menus of all the wall types. Hopefully the advanced options section is a bit easier on the eyes now and a bit more organized. All of these parameters can get a bit overwhelming at times even for myself, however each one is necessary so we can’t just wash our hands of them.
I may take a bit of a break today from the code but at the same time I’m chomping at the bit to at least get some sort of “Wall Dropper” tool up and running since I don’t think it would be that hard to implement and I do think it would be very useful.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Jan 31, 2021 9:23 am
Version 1.8.3 - 01.31.2021
- Added pocket doors to the door module.
The pocket door algorithm is based on the 1500 series Johnson Hardware Pocket Door Frames:
https://johnsonhardware.com/pocket-door-hardware
I am not modeling all of the details of the door assembly such as the steel studs or the track and jamb brackets, however I am modeling the prefabricated (wood) frame header assembly.
View model here:
https://3dwarehouse.sketchup.com/model/ ... ket-Door-1
3
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Feb 01, 2021 10:16 am
First look at a 4 Panel Bifold (closet) Door:
View model here:
https://3dwarehouse.sketchup.com/model/ ... oset-Doors
I still need to come up with the 2D symbol at the base of the door and even a more interesting problem is the opening algorithm for this door type.
The two outer panels are simple, they are merely a rotation just like a standard swing door. The inner panels on the other hand not only rotate but they also translate in relation to the outer panels since a hinge constrains them at that point. I like these kinds of "hard" problems.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Feb 02, 2021 3:27 am
First look at a 4 panel bifold door being opened and closed:
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Feb 02, 2021 8:49 am
Version 1.8.4 - 02.02.2021
- Added bifold (4 panel - solid) doors to the door module.
You can also add a threshold if used as an exterior door however I don't have a lot of options yet for exterior applications (ie. full glass). For now these are primarily for closet doors.
You can also switch which side the doors face by choosing LH INT or LH EXT. For the four panel bifold it doesn't matter whether you choose LH or RH, it essentially ignores the handedness of the parameter.
I still need to add in the 2 panel variant and then I think we will have most of the basics covered as far as doors are concerned, at least for now. Really exotic stuff will be up to the user to add into a framed opening (which I can provide).
The door opening algorithm was a bit more challenging than everything encountered thus far but after a couple of hours tinkering it finally came together.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Feb 04, 2021 2:34 am
Version 1.8.4b - 02.03.2021
- Added bifold (2 panel - solid) doors to the door module.
There are four possibilities for a 2 panel bifold door:
LH OUT, LH IN, RH OUT, RH IN
Whereas there is only two possibilities for a 4 panel bifold door: OUT or IN
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Fri Feb 05, 2021 2:41 am
I think I'm going to the call the "eyedropper" tool the "Copy Wall" tool. One additional icon will be added to the "Medeek Wall Tools" toolbar:
I know, I will hear it from everyone about the proliferation of more icons. However, there is an extension out there that allows you to customize the actual toolbars if you feel the need to:
https://extensions.sketchup.com/extensi ... bar-editor
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Feb 08, 2021 4:40 am
Version 1.8.5 - 02.07.2021
- Enabled the "Wall Copy" tool within the Medeek Wall Tools toolbar.
Note I've only enabled this tool for rectangular walls. After I am fully confident that it is working well and I've addressed any bugs or issues I will set it up for all the other (gable,shed and hip) wall types.
Please try out this new tool and provide any feedback or comments directly to nathan@medeek.com
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Feb 08, 2021 10:22 pm
I think the new Copy Wall tool will prove to be quite useful. As I am thinking about it this morning I realized that a similar tool for Doors and Windows would also be quite useful.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Feb 09, 2021 1:59 am
Version 1.8.5b - 02.08.2021
- Fixed a bug with the top plate cut out algorithm when walls meet in a "cross" configuration.
Each wall teeing into the primary wall has had its corner offset set to 1/2 the thickness of the primary wall.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Feb 11, 2021 9:01 pm
Version 1.8.6 - 02.11.2021
- Added the following Simpson Strong-Tie hangers to the beam hanger library: LUS26-2Z, LUS28-2Z, LUS210-2Z.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Feb 16, 2021 6:53 am
Version 1.8.7 - 02.15.2021
- Added an option for the garage door track in the global settings.
Currently you cannot set this parameter per garage door, it can only be set globally (in the Garage Door tab).
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Feb 17, 2021 10:09 am
I've had a number of people recently ask me for the ability to apply a wood grain texture to the lumber (ie. studs, plates, blocking, etc...) This really isn't a big ask, so I am going to enable another couple parameters in the global settings (Material Tab) so that the user can apply a texture to lumber and pressure treated lumber. Here is a first look at what that will look like (compare the wood grain wall to the solid colored wall):
I've tried to be very subtle with the wood grain texture so that it approximates my default lumber color but as you can see it is a slightly darker shade. I'm not sure I am entirely happy with it yet but it is a start.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Feb 18, 2021 1:54 am
Comparison between the solid coloring and with the textures enabled (Lumber and PT Lumber):
I am quite happy with the way the pressure treated texture came out.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Feb 18, 2021 8:05 am
Version 1.8.8 - 02.17.2021
- Enabled options for wood grain texture for lumber and pressure treated lumber in the global settings.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Feb 23, 2021 3:29 am
Version 1.8.9 - 02.22.2021
- Added a "Cedar Siding" built-in material (vertical) into the material library.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Feb 25, 2021 4:24 am
Version 1.9.0 - 02.24.2021
- Fixed a bug with the end stud height for Shed Walls with an "Inset Outside Corner".
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Feb 27, 2021 12:09 pm
mdkBIM Introduction (Japanese - 日本語)
A brief introduction of the mdkBIM bundle in Japanese.
mdkBIMバンドルの日本語での簡単な紹介です。
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Feb 28, 2021 1:46 am
Version 1.9.1 - 02.27.2021
- Added one additional parameter to the "User Interface" section of the General tab of the global settings. This allows the customization (color) of the text of the HTML buttons.
This should also resolve the issue with the "white" text of the HTML buttons for MacOS.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Mar 01, 2021 9:48 am
First look at the new Custom Beam Library. This will allow the user to create custom sized lumber, SCL or Timber beams:
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Mar 02, 2021 7:46 am
Version 1.9.2 - 03.01.2021
- Added a Custom Beam Library/Manager in the Beams tab of the Global Settings.
- Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) beams.
This may seem like a rather minor update but there actually is quite a bit of code behind any of these custom libraries (within the global settings) and their menu systems, hence the three days of programming that was required.
Since glulam beams use a different sizing system I did not enable custom sizes for that beam type. Additionally, all of the steel profiles are also quite a bit more complicated than a simple width x depth profile (rectangle) so they were also not included in this update. If there are specific wide flange steel beam sizes etc... that you would like to see me add, please feel free to contact me.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby juju » Tue Mar 02, 2021 8:02 am
:: OFF TOPIC ::
Happy cake day Nathaniel.
juju
Premium Member
Premium Member
Postby medeek » Tue Mar 02, 2021 8:05 am
Yup, I'm 49 today, my kids say I'm oooold. I'll probably still be working on this plugin when I'm 60 at the rate I'm going. :)
4
design.medeek.com
medeek
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: arnaydn, pepito526 and 16 guests
