Is there a plugin to batch rename scenes?
Postby db11 » Thu Nov 24, 2016 3:13 pm
I have a SU model with dozens of scenes that I'd like to batch rename, in this case by replacing the "Scene" prefix (with a one or two letter appellation) and adding a sequential suffix from the current order.
Is anyone aware of a plugin with that function — maybe one of Renderiza's?
If not, would it be difficult/possible to write one?
Thanks,
Doug
db11
Re: Is there a plugin to batch rename scenes?
Postby TIG » Thu Nov 24, 2016 5:01 pm
Code: Select all
n=inputbox(["Prefix: "],["N"],"Scene_Rename");Sketchup.active_model.pages.each_with_index{|p,i|p.name="#{n[0]} #{i+1}"}if n;puts
Copy+paste+enter this Ruby one-liner into the Ruby Console - it renames all scene-tabs in order with the 'Prefix' - e.g. 'N 1', 'N 2' etc...
The dialog lets you type in any desired 'Prefix'...
User avatar
Global Moderator
Postby function » Fri Nov 25, 2016 10:09 am
Thanks again TIG :mrgreen:
function
Postby db11 » Fri Nov 25, 2016 3:39 pm
Thanks TIG.
When I had time last night I went back to look at Rederiza's ReScene and it does have a rename function.
It's very slow to load though (at least on a Mac), so your one-liner will be useful.
Is there a (simple) way to modify it to rename only selected scenes?
db11
Postby Ludolff » Mon Jun 11, 2018 8:51 pm
TIG wrote:
Code: Select all
Hi TIG, Many thanks for this code. Is there anyway of adding some code to this that will allow you to select the scenes to rename?
Ludolff
Ludolff
Premium Member
Premium Member
Postby TIG » Mon Jun 11, 2018 9:16 pm
You can only select scenes that have names matching a pattern...
Let's say you want to rename only prefixed scenes containing the text 'Plan', you need to enter an extra option...
Code: Select all
n = inputbox( ["Prefix: ", "Pattern: "], ["N", "Plan"], "Scene_Rename" ); Sketchup.active_model.pages.each_with_index{|p, i| (p.name = "#{n[0]} #{i+1}") if p.name =~ /#{n[1]}/ } if n; puts
BUT you need to decide on the 'pattern' !
User avatar
Global Moderator
Postby StarSketch » Sun May 10, 2020 11:49 pm
Thank you a lot TIG, you save my day !!! :thumb: :thumb:
StarSketch
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: No registered users and 9 guests
Visit our sponsors:
