3D Truss ModelsRe: 3D Truss ModelsI've got the asymmetric options added to the edit menu and the common rafters and fascia are calculating correctly:
Note that all four pitches are different values, however the fascia lines up all the way around the roof as it should (in this case I have the overhangs auto calculating). Next I will work on the hip rafters and jack rafters. As we can see in this example, all symmetry is broken, each hip rafter will be unique (x4) as well as each set of jack rafters (x8). Luckily we can program this sort of thing, drawing this type of roof manually would be a real headache.
Re: 3D Truss ModelsHip and Ridge Cap is now working:
This chunk of code is just for the ridge cap geometry:
Re: 3D Truss ModelsWOW.
I hope you never see a roof like this, but kudos for handling the situations where we may have a couple different pitches anyway. MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Re: 3D Truss ModelsGutters and Downspouts are now functional for the Asymmetric Hip Rafter Roof:
Even with the different overhangs and top plate heights the gutter height (fascia) is the same height all the way around. However the downspouts on opposite sides of the roof are customized per the overhang on each respective side. Tomorrow I will jump back into the hip and jack rafters and see if we can wrap this one up. The good news is that the required code for the asymmetric hip and jacks already exists. I will be borrowing from the roof return module where I handled dissimilar pitches. The bad news is that after a cursory review of this block of code I have absolutely no idea how it actually works anymore (I haven't looked at it in about 2 years). It's just a matter of reverse engineering my own code for about an hour and it will all come back to me.
Re: 3D Truss ModelsI'm actually still working on the hip rafters. The complexity of a multi-pitch roof took another unexpected turn with the realization that when roof planes A and B are different pitches it causes an offset in the rafters at the peak which requires some additional logic to account for this fact with the placement of the hip rafters and their geometry.
I'm also still a bit conflicted on how to best handle the birdsmouth cut of the hip rafters when they walls have different top plate heights. In some cases the hip rafter misses the corner entirely and is askew on one of the walls, this is the simple case. In other cases the hip rafter technically rests at the "corner" but since there are two different wall heights possible it is not clear how the birdsmouth cut should be constructed exactly. I'm assuming that the higher plate height will govern. Does anyone have any photos or details of actual construction where a hip rafter bisects a corner where the top plate heights vary?
Re: 3D Truss ModelsGot me looking for examples. I've created (or passed on) far more problems like this for others, than I ever had to deal with in the field. You might look at this guys webpage. https://deskgram.net/explore/tags/bastardhip
Re: 3D Truss ModelsNote how this hip rafter sits askew, only on one wall:
https://scontent-atl3-1.cdninstagram.co ... tagram.com
Re: 3D Truss ModelsYes. I once did a little roof framing, using old school framing square methods from a book. Sometimes I just had to work it out in the field.
Re: 3D Truss ModelsWhen the hip roof is asymmetric across the ridge you end up with a situation like what is shown below:
The common rafter in the upper right is a 7:12 pitch and the common rafter in the lower left is a 10:12 pitch. Normally with a symmetric hip or gable roof the common rafters would be flush with the top of the ridge board. However in the asymmetric case the steeper pitched side is flush and the lesser pitched side overshoots the ridge board just slightly as shown. This additional asymmetry causes further complications in the calculations of the hip rafter that is adjacent to the overshooting common. Also note that the seams in the sheathing (edges of the roof planes) do not center up on the ridge board or hip rafters. This is not a flaw or an error it is just the way the asymmetric roof goes together. It appears that I have the hips correctly calculating now (after nearly two days of intense debugging and about 10 sheets of engineering pad) however tomorrow I will continue with further testing, to see if I can break anything, and then begin attacking the jack rafters. A further look at the bird mouth cut question in shown in the example below: So in reality I am still missing the birds mouth cut for the hip rafters and the implementation of the soffit cut for trimming the tails of the hip rafters. Always too much to do and never enough time to get it all done. I'm really hoping that the jack rafter piece is a lot less trouble than the hip rafters, I would really like to get this roof type wrapped up by the end of the weekend.
Re: 3D Truss ModelsSince each hip rafter is potentially unique each one requires the following calculations (for those that are interested):
Term1 of the Abar equation is really interesting. If I took the time I could probably condense down some of the variables and reduce the amount of algebra but then in the future it would be harder for me to follow, so it is best left as verbose as possible for myself and future generations. The terms Abar, Bbar, EBar and Fbar specify the compound bevel cuts at the peak and eave of the hip rafter.
Re: 3D Truss ModelsActually I stand corrected. The sheathing does center up on the ridge board provided that you do vertically offset the opposing common rafters as shown in the previous images. A top down view shows the result:
If you don't vertically offset the commons and the pitch on plane A and B differ then the ridge board will not center up on the sheathing. For now I have it centering and a vertical offset, for future work I may provide an option to toggle between these two possible configurations. Here is a view of the other side of the roof, note the different top plate heights and where the hip rafters land on them and the corners: Better yet, go ahead and download my test model that was most recently generated by the new asymmetric module: https://3dwarehouse.sketchup.com/model/ ... -Test-Roof
Re: 3D Truss ModelsFirst look at the jack rafters:
Next I will look at the birds mouth cut of the hip rafters and the soffit cut for both hip and jack rafters, then a bit more testing to see if anything can be broken when the degenerate case (symmetric roof) is calculated. These is also the case where you might end up with a negative overhang (which doesn't make sense). I should probably include some logic to try and detect this condition and alert the user that the roof configuration is not physically possible.
Re: 3D Truss ModelsThe birds mouth cut algorithm (and code) is now functional however I can't say I'm completely satisfied with it yet.
For example take a look at this scenario: You have a 8:12 and 7:12 meeting almost at the corner of the building (skew is minimal) however the plate height is 2" higher on the 7:12 side and my algorithm cuts the birds mouth per the highest plate height at the corner. In this particular case it would seem to make more sense to cut the birds mouth at the lower plate height otherwise not enough meat is left in the hip rafter. This algorithm may need further refinement to really make it meaningful and useful to the designer. The other option of course is to simply not cut the birds mouth in the hips rafters and leave it to the user to determine what or how they want to handle the intersection at this critical junction. The soffit cut in the case of a hip roof is actually quite simple (surprisingly). Since the fascia lines up all the way around the roof the soffit cut will also be the same height for all jacks, commons and hip rafters.
Re: 3D Truss ModelsThe soffit cut function is now active for hips, jacks and commons:
Now I will see if I can break the module, I'm sure there is some state or configuration that I haven't considered that may throw some errors.
Re: 3D Truss ModelsVersion 2.3.7 - 05.13.2019
- Enabled asymmetric hip rafter roofs (imperial and metric units). The most degenerate version of the asymmetric hip roof would be a pyramid roof. The roof shown below is a pyramid roof that is actually an asymmetric roof, as you can see the algorithms degenerate gracefully as they should: Items for future work include the ability to toggle the configuration where the sheathing centers up on the ridge board or not. Another outstanding item is ceiling joists. I'm not even sure what do with ceiling joists yet for an asymmetric hip as there could possibly be four different ceiling joist heights. I would also like to switch everything to HTML menus. The initial draw menu is still using the default SU GUI. Due to its limitations you can only initially create symmetric hip roofs but then you can edit them to switch them to an asymmetric configuration. I will explain this further in an upcoming tutorial video. Once I switch to an HTML draw menu this limitation will be resolved.
Re: 3D Truss ModelsDownload or view a sample of an asymmetric hip roof here:
https://3dwarehouse.sketchup.com/model/ ... est-Roof-3
Re: 3D Truss ModelsI've fixed a few small bugs with the jack rafters near the corners and re-released the plugin.
When the jack rafters approaches a corner and then the overhang portion of the roof the various permutations in the way the jack rafter is beveled or cut becomes quite interesting. With a regular symmetric hip roof the possible configurations is more limited and predictable however the asymmetry lends itself to additional cases, so more conditionals are required in the code to account for them. I've ran some additional checks to try and ferret out these additional configurations and then provide the appropriate logic to handle them, however there may still be a few that may have eluded my best efforts. This module is new so there may still be a few fires yet.
Re: 3D Truss ModelsTutorial 15 - Asymmetric Hip Roofs:
In this video I try to explain how each roof plane can be adjusted and the details of toggling between auto calculating the overhang or the top plate height. View model here: https://3dwarehouse.sketchup.com/model/ ... oof-Test-4 Looking at hip roof again this afternoon it occurred to me that it probably would be useful to have the ability to specify the depth of each hip rafter individually and for a symmetric roof the ability to specify the hip rafter depth independent of the common rafter depth. Yet another item to add to this modules todo list. I also need to update the estimating module for this roof type (symmetric and asymmetric), the quantity and length of each jack rafter would be useful information.
Re: 3D Truss ModelsTrying to come up with an intuitive method for specifying a secondary roof. My idea is for the user to select the wall corners (1) and (2) that the projecting (secondary) roof will be bearing on and then to select the roof plane of the primary roof that the secondary roof should intersect. Essentially three points/picks will specify the secondary roof.
When a secondary is created it will store the primary roof name it is intersecting with as well as the roof plane. Either of these can then be modified in the secondary roof menu in the case that the user wants to switch to a different primary roof or a different roof plane of a given primary roof. When a secondary roof is edited or regenerated it will then re-analyze the entire geometry with the specified primary roof and roof plane in order to generate the secondary roof geometry. This will allow the user maximum flexibility (ie. moving primary and secondary relative to each other {x, y, or in z} as well as changing the primary). Orthogonal intersections are nice but we can't count on them so from the get go the secondary tool will be designed with any arbitrary intersection angle in mind as well as intersections with a roof planes or gable ends of a gable roof (wall). Additionally, the secondary roof may be symmetric or asymmetric so it makes sense to also allow for this possibility as well. One could even go so far as to allow for intersection with more exotic primary roofs (eg. gambrel, arched, polynesian etc...) however at this point I think I will limit myself to just a single pitched roof plane or wall plane. There will be a separate tool for secondary hips and one for secondary gables, the reason being the vast number of different parameters required for each type of roof and the different algorithms required as far as calculating the actual roof rafter geometry. At this point I am mostly conceptualizing and trying to see if there are any major holes or flaws in this system or method of secondary roofs. I would be interested to hear your feedback on the matter and especially if you can see any major problems with my methodology, or have suggestions for something that may work even better. As can be seen on my previous notes page (May 14), there are a few special cases that will also need to be dealt with: 1.) Secondary roof is non-orthogonal to the primary roof and its ridge coincides or meets a primary hip. In this case the secondary really should intersect the two planes on each side of the primary's hip. 2.) A hip roof secondary meets a gable wall such that the aspect ratio of the secondary precludes it from having a ridge board perpendicular to the gable wall. There is also potentially the non-orthogonal possibility but this would not be very common. 3.) Typical L-shaped hip roof where the valley and hip theoretically merge into a common roof. If I can somehow pull this one off, it will be a bit of a game changer for the Truss plugin since it will then allow for much more complicated rafter roofs.
Re: 3D Truss ModelsBefore I fully dive into the secondary roof module I thought it might be interesting to return to the soffit and fascia discussion I was having back in 2017. It would be nice to have soffit and fascia added to the hip rafter roof modules.
However as I am reviewing my notes and previous posts I came upon one unresolved question. Should the roof sheathing extend out over the fascia board or should it terminate at the sub-fascia as shown in this detail: The reason this becomes an issue is that the calculations of an asymmetric hip roof factor in the width of the sub-fascia in order to line them up around the roof. If the sheathing extends pasts the sub-fascia to the fascia then the gutter line will drop a different amount for each roof plane depending on the pitch. However if the sheathing only extends to the extent of the sub-fascia then the calculations for the roof do not need to take into account fascia width. I can have it work either way but I would like to focus on the most common configuration.
Re: 3D Truss ModelsVersion 2.3.8 - 05.16.2019
- Fixed a bug with the pitch and area callouts for asymmetric gable rafter roofs. - Fixed a bug with the back/rear outlooker length for gable rafter roofs which now allows for a building or roof length that is a non-integer multiple of the rafter spacing. - Added the option in the gable rafter roof edit menu to specify a separate front and back overhang length. The issue with the rear outlooker length will also need to be addressed for truss assemblies. I should also make the option for the separate front and back overhang length available for trusses as well. Lots of little things as well as big things to do. The consensus seems to be that the sheathing should terminate at the sub-fascia and not extend over the fascia, especially if the rafter tail is a plumb cut (fascia is vertical). However, this preference also seems to be highly dependent on the particular application and type of fascia used. Here is another interesting detail:
Re: 3D Truss ModelsA few other things to note with regards to fascia and soffit:
1.) In order to enable soffit and fascia the advanced options must be turned on and the sub-fascia option must also be turned on. 2.) The consensus appears to put the fascia top flush with the sub-fascia top with the sheathing terminating at the outside edge of the sub-fascia. 3.) Gutter placement will then be unaffected by the fascia other than be offset by its thickness. 4.) The soffit will be placed level to the horizontal and extend to the outside edge of the sub-fascia meeting the fascia and to the wall sheathing. Since the plugin is not keeping track of what walls are being used (Medeek, Framer, or a simple solid), there will be a wall sheathing offset parameter that will allow the user to control this offset. I've noticed some details showing the soffit extending to the framing, others to the sheathing and still others to a brick or stucco layer. 5.) The soffit top surface will abut the underside of the sub-fascia. 6.) Materials for soffit and fascia will both be user driven/customizable. 7.) Parameters to include: Soffit thickness, Fascia thickness, Fascia depth. 8.) I will also be adding in an additional parameter for the roof cladding which allows the user to extend it beyond the sheathing a specified amount (Roof Cladding Extension). This will naturally extend the ridge or hip caps the appropriate amounts as well. I realize there are other soffit variations but I will be starting with the flat soffit first and then consider the angled soffit in future developments.
Re: 3D Truss ModelsVersion 2.3.9 - 05.17.2019
- Enabled a roof cladding extension parameter for all hip rafter roofs. The extension is measured inline with the roof plane (not with the horizontal).
Re: 3D Truss ModelsFirst look at the soffit and fascia (hip roof):
Also note the roof cladding extension (3/4") with a 6:12 pitch.
Re: 3D Truss ModelsVersion 2.4.0 - 05.19.2019
- Enabled soffit and fascia for all hip rafter roofs. - Fixed a minor bug with the ridge cap extension for asymmetric hip roofs. - Enabled custom materials for roof sheathing and roof cladding in the HTML edit menu for all hip rafter roofs. Custom materials is also enabled for both the soffit and the fascia. Soffit and fascia can only be specified in the edit menu once the roof is created. The current draw menu presents the user with far less parameters and will be updated to a more advanced HTML menu in the future. Once I am satisfied with the soffit and fascia with the hip roofs I can then extend it to gable, shed and dutch gable roofs and all other truss roofs. View example model here: https://3dwarehouse.sketchup.com/model/ ... scia-Test1
Re: 3D Truss ModelsI'm considering adding in drip edge but then again it may be a step too far?
If gutter is enabled then the drip edge is barely visible. For estimating purposes I can just calc the perimeter of the roof to get the lineal feet of drip edge. Is it worth the effort?
Re: 3D Truss ModelsAfter some further testing of the roof cladding extension parameter I think it makes more sense to make the extension per the horizontal and not per the roof plane. The problems really only seem to arise when you have an asymmetric roof, in this case the higher pitched roof will project less than the lower pitched roof if the extension is parallel to the roof plane.
Thoughts?
Users browsing this forum: Builder54 and 14 guests
