[Plugin] GKWare Cabinet Maker
Re: [Plugin] GKWare Cabinet Maker
Postby Garry K » Mon Feb 27, 2017 6:26 pm
I found an error in the insertion point for full and partial frames. Fixed
Tall cabinet tops can have 3 modifiers:
1) Default(no change)
2) Treat As Base (Tall cabinet takes on top style used for base cabinets)
3) Treat As Upper (Top and top edge of sides take on the same finish as the top of upper cabinets)
Tall - Treat as Upper.
Tall - Treat as Base. Top section is turned off (height = 0), Cabinet Height is 768 and Mid Section is 640 leaving 128 mm for a bottom drawer. You set the number of drawers. I used mid section because you can adjust the position of the handle.
Garry K
Premium Member
Premium Member
Postby Garry K » Mon Feb 27, 2017 7:55 pm
Cab Maker can now produce doors and drawer fronts with or without frames.
Treats Doors and Frames like any other cabinet. Reports include doors and frames.
Batch editing works with these as well as regular editing.
Framleess overlay
Set Cabinet Depth = 0
Inset Full Frame
Set Cabinet Depth = Frame Thickness for correct insertion point.
3
Garry K
Premium Member
Premium Member
Postby Garry K » Mon Feb 27, 2017 11:00 pm
Version 2.0.72 is now available for download.
1. Modified Beaded frames so that they are now Sketchup solids.
2. Fixed Insertion point for Full and Partial Frame construction.
3. Added Tall Top parameter. You can have Default (as before) or Treat As Base or Treat As Upper. Provides more consistency and flexibility.
4. You can now set Frameless Cabinet Depth to 0 to get Doors and Drawer fronts only. You can set Full and Partial Framed Cabinet Depth to the same thickness as the frames to get Frames, Doors and Drawer fronts only.
5. You can use the new cabinet parameter Pullout when 0 Depth.
Garry K
Premium Member
Premium Member
Postby Garry K » Sat Mar 11, 2017 8:50 pm
Working on 2.0.73
Anyone interested in a sliding door option for inset doors.
I'm guessing we would need an overlap parameter and the sliding door option would require a pair of doors.
Garry K
Premium Member
Premium Member
Postby Garry K » Mon Mar 20, 2017 3:59 pm
CabMaker 2 Version 2.0.73 is now available.
1) The beaded frames had some reversed faces. Fixed.
2) Fixed stretcher placement for blind cabinets with integrated kicks.
3) Fixed insertion point for face frame cabinets Blind inset.
4) Modified Reports to synchronize with CutMaster.
Garry K
Premium Member
Premium Member
Postby Garry K » Fri Mar 24, 2017 3:32 pm
CutMaster 2.0.1.39 is now available.
1) Tall cabinets now have shelf supports in top 2 sections.
2) With inches the DXF files had illegal characters in their names. Fixed
3) Modified labels for A4 printer.
Garry K
Premium Member
Premium Member
Postby Garry K » Sun Mar 26, 2017 6:37 pm
I have added a Fridge cabinet to this next version for all construction types.
Garry K
Premium Member
Premium Member
Postby Garry K » Tue Mar 28, 2017 3:42 pm
Version 2.0.74 is now available.
1) Added Fridge cabinet
2) Fixed a bug with Frames
Garry K
Premium Member
Premium Member
Postby juju » Wed Mar 29, 2017 8:29 am
Garry, steaming ahead
juju
Premium Member
Premium Member
Postby Garry K » Fri Mar 31, 2017 4:23 pm
CabMaker2 Version 2.0.76 is now available
1) Small change to Reporting for Fridge cabinet
CutMaster Version 2.0.1.40 is now available
1) Added support for Fridge cabinet
2) Modified Dxf files Now compatible with acad
3) Dxf Files optionally 2D or 3D.
Garry K
Premium Member
Premium Member
Postby utiler » Thu Apr 06, 2017 12:52 am
Hi Garry, was Cabinet Maker dynamic at some stage???
I'm sure I could open and close doors and drawers somtime ago? :shock:
utiler
Top SketchUcator
Postby Garry K » Thu Apr 06, 2017 1:01 am
You still can - however you have to turn it on.
From the Sketchup menu choose
Extensions \ GKWare CabMaker 2 \ Cab Maker 2 - Edit Config
Set Animate Doors to true.
Any new cabinets or edited cabinets will now have the proper attributes.
I had to do it this way because the Extension Warehouse kept failing CabMaker during automatic testing. Pretty crazy - because Dynamic Components would also fail (if they let it)
Garry K
Premium Member
Premium Member
Postby utiler » Mon Apr 10, 2017 12:03 am
No worries, thanks mate.
utiler
Top SketchUcator
Postby Garry K » Thu Apr 13, 2017 7:03 pm
CabMaker 2 Version 2.0.77 and CutMaster Version 2.0.1.42 are now available
1. Fixed Label report for A4 printer.
2. Reorganized Dxf Options tabs. Rules and Miscellaneous are now on General tab and Shelf Supports are now on Holes tab.
3. Added context sensitive help to options. Not complete but a good start.
4. Fixed top hinge placement for doors.
5. Fixed bug when using partial sheets.
1. Modified Dxf inport to handle changes to the DXF format.
Garry K
Premium Member
Premium Member
Postby Garry K » Tue Apr 25, 2017 5:53 pm
CabMaker 2 Version 2.0.78 and CutMaster Version 2.0.1.43 are now available
1. Completed the context sensitive help.
2. Added Dado Sides Only for cabinet backs.
3. Added Last Front Overhang. You now can have the slide holes in the sides positioned the same for cabinet bottoms and for stretchers.
4. Fixed bug for middle doors of tall cabinets when Tight Gap was 0.
5. Fixed bug for shelf support placement on Middle and Top sections of Tall cabinet when using integrated kicks and Overlay doors on Frameless cabinets.
1. Added Dado Side Only for backs.
2. Added Last Front Overhang for the bottom most drawer.
3. Fixed situation that could cause Sketchup to crash when using Sketchup 2017. This was when dadoing side panels for backs and for tops and bottoms where the dado depths are different.
Garry K
Premium Member
Premium Member
Postby db11 » Thu Apr 27, 2017 3:17 pm
Hi Gary --
I just downloaded the CabMaker trial and was about to download the CutMaster trial, then saw it was Windows only... I don't suppose that you have any plans to port it to MacOS?
I realize that it the effort/reward ratio may make it a losing proposition... but no harm in asking :)
db11
Postby Garry K » Thu Apr 27, 2017 3:30 pm
Sorry Doug -
I do have a C++ compiler that supports both Mac and Windows and I started porting my code over but there were just too many bugs in the compiler. So I went back to Windows only.
I do have a number of Mac users that use bootcamp or parallels or vmware.
Garry K
Premium Member
Premium Member
Postby Garry K » Thu Apr 27, 2017 3:58 pm
CabMaker 2 now supports stretcher dados and kick dados (integrated kicks). Users the same Side Dado parameter.
CutMaster now has context sensitive help images for DXF Configuration.
Garry K
Premium Member
Premium Member
Postby Garry K » Thu Apr 27, 2017 4:12 pm
I am now considering working on using doors as finished panels. The only problems that I see are with extra wide back panels for narrow islands and peninsulas.
Anyone care to comment on how they would like to see this done?
Garry K
Premium Member
Premium Member
Postby db11 » Thu Apr 27, 2017 11:15 pm
OK. Thanks for the quick reply Gary.
At the moment I don't have a direct need for CutMaster... but if it becomes must, then BootCamp here we come!
db11
Postby Garry K » Tue May 02, 2017 7:19 pm
CabMaker Version 2.0.79 is now available for download from my website
1. Drawer Height overrides not working for Tall Cabinets. Fixed
2. Added Drawer Depth overrides for 6 drawers.
3. Added pullout Height overrides for 4 pullouts.
4. Added pullout Depth overrides for 4 pullouts.
5. Added shelf spacing override for 4th shelf.
CutMaster Version 2.0.1.44 is now available for download
1. Added Blind dadoing for Backs where the back is the same thickness as the sides.
Garry K
Premium Member
Premium Member
Postby Garry K » Sat May 06, 2017 7:08 pm
Version 2.0.80 of CabMaker 2 now available. Also CutMaster 2.0.1.45 is available.
CabMaker 2
1) You can now specify a different Top Drawer Style.
2) Stretchers not position correctly for tall Frameless Overlay cabinets with drawers and stretchers. Fixed.
3) Adjusted List_Parts_2 reports.
CutMaster
1) Side Panels now only have hinge holes where necessary. So for a cabinet with 1 door hinged right would not have hinge holes on left side.
2) DXF files for CNC can be created 1 per part for CNC operators with pod style CNC.
Garry K
Premium Member
Premium Member
Postby Garry K » Tue May 23, 2017 5:09 pm
CabMaker 2.0.82 and CutMaster 2.0.1.47 are now available.
CabMaker
1) Doors now have a horizontal grain option.
2) Materials for skinned parts in the parts listing now have "_F1S" appended to the name.
3) Sketchup followme has issues with certain Extruded handle profiles such as the new mondern one. Added an option to use Solid tools "Subtract" where Sketchup is Pro.
4) Modified CabMaker DXF import to understand CutMasters new DXF options.
CutMaster
1) Options now work properly with inches. Requires " mark
2) Lists now can have last argument as c1 or c2 forcing CutMaster to divide the space by 2 or by 3
3) Slides table in Database no longer restricted to 30 characters for holes.
4) Options in red (mostly depths) can receive fractional inches.
5) Added additional optional configuration for dxf files
6) Added more layer names
7) Added horizontal boring for dxf where 3D and where one part per dxf.
Garry K
Premium Member
Premium Member
Postby Garry K » Thu May 25, 2017 11:22 pm
Adding the ability to adjust the height of the middle rail. This way you can have the middle rail for tall doors line up with your regular doors.
I'm also adding the ability to override the placement of and extruded handle. So you can set up a top drawer and have the handle at the bottom and have the handle for the rest of your drawers on the top.
Garry K
Premium Member
Premium Member
Postby Garry K » Fri May 26, 2017 6:36 pm
CabMaker 2.0.83 is now available
1. Tested all the door types and modified routines to complete the horizontal door options.
2. Added door parameter so you can now set the mid rail height.
3. Added override for extruded handle placement.
Garry K
Premium Member
Premium Member
Postby Garry K » Thu Jun 01, 2017 4:28 pm
New version available
Version 2.0.84 – Jun 1, 2017
1. Upper top edging wasn't working – fixed.
2. Cabmaker was not honoring last drawer offset for some cabinet construction types –
fixed.
3. Panel material was not being honored – fixed.
4. Editor was not showing the library template that produced the cabinet – fixed.
You can now create cabinets with a different inside panel
Garry K
Premium Member
Premium Member
Postby abdalmalki » Thu Jun 01, 2017 6:57 pm
Awesome :thumb:
abdalmalki
Postby Garry K » Sat Jun 10, 2017 7:42 pm
CabMaker Version 2.0.85 is now available.
Version 2.0.85 – Jun 10, 2017
1. Added main menu item “Edit Cabinet 2”. You can now create a shortcut for editing
cabinets.
2. Fixed some translation issues.
3. Top and bottom eding for Finished Panels, Finished Backs, Blind Panels and Fillers
now working.
Garry K
Premium Member
Premium Member
Postby Garry K » Mon Jun 19, 2017 4:28 pm
CabMaker Version 2.0.86 is now available
1. Added “Fixed Shelves”. You can now have up to 4 fixed shelves.
2. Added pullout information and Drawer Depth information to the parts report.
CutMaster Version 2.0.1.49 is now available
1. Added optional drilling for pullouts.
2. Depth for Pullouts and Drawers are now used in determining slides and drilling pattern.
3. Fixed Labels for Avery 06498 (1” X 2 5/8”)
Garry K
Premium Member
Premium Member
Postby Garry K » Sun Jul 02, 2017 4:26 pm
Version 2.0.88 of CabMaker is now available.
1. You now have a PROJECT rule for Base and a different one for Uppers.
2. You now have a PROJECT setting for the insertion height for upper cabinets. You also
have a second insertion height if you hold down the ALT key while inserting a cabinet.
3. Added a renumber feature during a batch edit to PROJECT tab.
4. Added a 'Template Defaults' section to PROJECT tab. There are 6 new parameters
where you can override cabinet heights and depths separately for Base, Upper and Tall
cabinets.
5. Added a Lock Section to PROJECT tab.
6. Skinning Modifer couldn't be blank. Fixed.
7. Now passing Adjustable Shelf information over to CutMaster.
Version 2.0.1.51 of CutMaster is now available
1. Added Note Column to Parts Data.
2. Parts Report now shows Note column.
3. Import now has Note column and Shelf info.
4. Added options for shelf supports. You set the center hole of the cluster from adjustable
shelf position in CabMaker.
5. You no longer have to restart after changing Edging thickness.
6. Changed Match button on import to map several fields.
7. Added more info to DXF file naming for 1 part per dxf.
8. Fixed Third Hinge mounting bracket.
9. Construction holes now honor edging thickness.
10.Added scoring option for Fixed shelves and Stretchers
Garry K
Premium Member
Premium Member
PreviousNext
Return to Plugins
Users browsing this forum: Google Bot, JGA, NjarCom and 17 guests
