[Plugin] FredoTools::AutoReverseFaces - v1.0a - 25 Feb 15
Postby fredo6 » Wed Feb 25, 2015 10:49 pm
AutoReverseFaces is a standalone script which is part of FredoTools.
It automatically perform the alignment of face orientations as well as their proper orientation on shapes that looks like a solid, that is, where visually you could tell where is the inside and where is the outside.
AutoReverseFaces operates on top level geometry and groups / components at any level.
IMPORTANT: AutoReverseFaces is primarily useful when you have a patchwork of faces with good and bad orientation. The reason is that the algorithm tries first to identify the ‘good’ orientation, and then propagate it to the other faces by adjacency.
AutoReverseFaces is installed as part of FredoTools 2.6 and above.
See the main post for this plugin for Installation of FredoTools
(see also section Quick Start and Video below)
Quickcard AutoReverseFaces - English - v1.0.pdf
  • SU Versions: SU6, SU7, SU8, SU13, SU14, SU15 – works better with SU8 M1 and above
  • Platforms: Windows and Mac
  • Languages: English, French
  • Menus: by default, AutoReverseFaces is installed in Tools > FredoTools. There is also an entry in the Contextual menu.
  • Icon toolbar: Fredo6 Tools. There is only a single icon. By default, it is not shown. You need to go to the Default Parameters… dialog of FredoTools to enable the icon.
  • The plugin is free, for private and commercial usage.
AutoReverseFaces Overview
Launching AutoReverseFaces
Just launch AutoReverseFaces on a selection. If there is no selection, AutoReverseFaces proposes to apply the operation to the whole active model.
Note that in general AutoReverseFaces does the work in one pass. It won't change the orientation again if it considers it is fine.
AutoReverseFaces 1.0a – 25 Feb 15: Initial public release in FredoTools 2.6a
7
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools::AutoReverseFaces - v1.0a - 25 Feb 1
Postby cotty » Wed Feb 25, 2015 11:45 pm
Excellent! Thank you!
User avatar
cotty
Top SketchUcator
Postby srx » Thu Feb 26, 2015 8:02 am
Fredo is fixing SketchUp "bugs". :D Fantastic! Deserves new shortcut key ALT-R. Thank you.
www.saurus.rs
User avatar
srx
Postby cotty » Thu Feb 26, 2015 7:25 pm
srx wrote:Fredo is fixing SketchUp "bugs". :D Fantastic! Deserves new shortcut key ALT-R. Thank you.
You can't use Alt-R, it's already my shortcut ;)
User avatar
cotty
Top SketchUcator
Postby leaflett » Sun Nov 06, 2016 5:28 pm
most excllent kudos due
leaflett
Postby rafaelsabino » Sun Oct 20, 2019 4:17 am
Download not disponible
rafaelsabino
Postby TIG » Sun Oct 27, 2019 8:44 pm
As explained in the main post in this thread: it is part of FredoTools - which you can download from the PluginStore...
[for some reason Fredo's link in broken...]
https://sketchucation.com/pluginstore?pln=FredoTools
Como se explica en la publicación principal de este hilo: es parte de FredoTools, que puedes descargar desde PluginStore ...
[Por alguna razón, el enlace de Fredo está roto ...]
You'll also need to install the latest LibFredo.
También deberá instalar la última versión de LibFredo.
https://sketchucation.com/pluginstore?pln=LibFredo6
Restart after completing the two installations...
Reinicie después de completar las dos instalaciones ...
I guessed Spanish rather than Portuguese ?
¿Adiviné español en lugar de portugués?
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: CreaVivaCity, darpit, man_with_an, milena_spasova, perlita20, Playinq, silviosegala, xlexdead and 12 guests
Visit our sponsors:
