by Hogwarts » Wed Apr 18, 2012 10:05 pm
Rich O'Brien wrote:FFD won't allow you to create a N x N cage if it's raw geometry or a component
So how do you create the cage? I am just starting at Sketchup. I've been using it for 1-2 months now. Here is what I'm trying to make. The snow cap on top of this window.
I already made a cylinder. Radial bended it around the top. Now i need to deform it like snow How do you suggest I do this. Thank you.
Hogwarts
by Rich O Brien » Wed Apr 18, 2012 10:40 pm
Have you read the description in the first post?
Make your cylinder a group. Right click and choose N x N. Input values for height, depth and width. These will be the points that weight your cylinder.
Edit the point group and adjust points accordingly.
It's best if you attempt to do this then ask when things become difficult.
Rich O Brien
- Administrator
- Name: Rich O'Brien
- Operating system: Windows
- SketchUp version: 2017
- License type: Pro
- SketchUp use: engineering and mechanical design
- Level of SketchUp: Advanced
by Hogwarts » Wed Apr 18, 2012 11:04 pm
Rich O'Brien wrote:Have you read the description in the first post?
Ok I've completed your steps up to "edit point group" I'm not quite sure how, could you explain it? Thanks for the patience.
Hogwarts
by Rich O Brien » Wed Apr 18, 2012 11:42 pm
Now you've 2 groups. The cylinder and the points. Edit the points group the manipulate the cylinder group. The points can be moved individually or in multiples. Pick a row and move them. The mesh should update when the move is committed. Just practice
Rich O Brien
- Administrator
- License type: Pro
by Hogwarts » Thu Apr 19, 2012 3:18 am
Rich O'Brien wrote:Now you've 2 groups. The cylinder and the points. Edit the points group the manipulate the cylinder group. The points can be moved individually or in multiples. Pick a row and move them. The mesh should update when the move is committed. Just practice
Thanks for the help. I'm starting to make it look like the image. It's going to take practice you're right. This is cool!
Hogwarts
by chadlharris2000 » Tue Oct 02, 2012 12:45 pm
I have a very novice question. I'm trying to download the SketchyFFD plug in but I can't see where the link is to download it. please tell me how to find it on this website. Thanks
chadlharris2000
- Name: Chad Harris
- Operating system: Mac
- SketchUp version: 8
- License type: Free/Make
- SketchUp use: interior design
- Level of SketchUp: Beginner
by Tobobo » Sat Oct 06, 2012 11:17 am
chadlharris2000 wrote:I have a very novice question. I'm trying to download the SketchyFFD plug in but I can't see where the link is to download it. please tell me how to find it on this website. Thanks
it is at the bottom of the first post, just click on it and save it to your plugins folder.
Toby
Philippians 4:13
Tobobo
- Name: Toby Joyce
- SketchUp version: 2014
- License type: Pro
- SketchUp use: landscape architecture
by shri » Fri Nov 30, 2012 12:46 pm
very cool stuff..thanks alot..makes very easier working with organic shapes FFD..rocks...
shri
- Name: shrijan
by Lana » Sat Dec 08, 2012 7:36 am
just have the best here . thank you .
Lana
- Name: Lana
- SketchUp use: product design
by itscabbage » Wed Dec 19, 2012 2:45 pm
Erm, i'm new here. i have sketchup 8 and i've put this ruby into the plugins folder with all the other rubys, but i can't find out how to use this in sketchup?
itscabbage
- Name: Claude
by mitcorb » Wed Dec 19, 2012 8:37 pm
Hi, itscabbage: I would highly recommend reading through the entire series of pages in this thread. Among the pages are animations, visuals etc. that can provide information on how to use the tool. If you are unable to activate it, perhaps you should check to see if it is in the proper folder. This is dependent on whether you are using Windows or Mac. FFD does take a little practice. And, if you haven't already done so, update your profile. This will enable helpers to determine specific solutions, especially with regard to operating systems.
mitcorb
- Top SketchUcator
- Name: mitcorb
- SketchUp version: 2016
- License type: Pro
- SketchUp use: architecture
by gilles » Sun Feb 03, 2013 12:25 pm
For some reason, only the first version works for me. I set NxN width=11 depth=11 height=1 subdivise=false First version everything is OK, scale move rotate... Second version, nothing moves (see ruby report) Tig's version, trying to move the original group just disappear?  no console report. Any idea? WARNING: make_unique is a deprecated methodof Sketchup:Group Error: #<NoMethodError: undefined method `*' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:453:in `calcBernstein' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:214:in `initFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:213:in `upto' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:213:in `initFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:211:in `upto' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:211:in `initFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:209:in `upto' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:209:in `initFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:200:in `each' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:200:in `initFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:151:in `startFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:20 Error: #<NoMethodError: undefined method `[]' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:253:in `applyMultipleFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:252:in `each' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:252:in `applyMultipleFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:242:in `each' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:242:in `applyMultipleFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:423:in `analizeLattice' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:163:in `updateFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:84:in `onChangeEntity' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:453 Error: #<NoMethodError: undefined method `[]' for nil:NilClass> /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:253:in `applyMultipleFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:252:in `each' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:252:in `applyMultipleFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:242:in `each' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:242:in `applyMultipleFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:423:in `analizeLattice' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:163:in `updateFFD' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:84:in `onChangeEntity' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyFFD.rb:253
gilles
- Top SketchUcator
- SketchUp version: 2015
- SketchUp use: other
by TIG » Sun Feb 03, 2013 12:48 pm
I made the adjusted version because the older versions were all causing issues, clashes with other scripts etc, the observer was very flaky... My version works fine for me when tested using your settings, although I don't fully understand the 'moving the group...disappear' issue  what disappears ? If you move the group away from the guides it will deform differently... You can only have one set of FFD guide-points at a time, so is this your issue ? The 'second' version had the most fails so I'd expect the litany of error messages...
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
by gilles » Sun Feb 03, 2013 1:36 pm
I set NxN parameters and clicking ok the group disappears, it is still in the outliner but nowhere in the model.
gilles
- Top SketchUcator
by gilles » Sun Feb 03, 2013 1:50 pm
I also try with only SketchyFFD.rb in plugins folder, same result.
SU 8.0.14345
gilles
- Top SketchUcator
by TIG » Sun Feb 03, 2013 1:53 pm
It works fine for me with z=1 set, provided that the geometry has some 3d-ness. If I draw a grid 10x10 as a flat 2d group it does then fail !? Not having written the original code [I just fixed some known issues] I am unclear why... Adding a short vertical line to the grouped mesh fixes it... Capture.PNG I'll check though the code and see if I can trap for this...
- Global Moderator
- Name: TIG
- License type: Pro
by gilles » Sun Feb 03, 2013 2:06 pm
If I add a vertical line in the group it works. Good to know.
gilles
- Top SketchUcator
by TIG » Sun Feb 03, 2013 3:02 pm
Here's my update viewtopic.php?p=36127#p36127The recently reported NxN issues with NaN [0.0/0.0] & Infinity [1.0/0.0] fixed, these occurred when the selected group was 2d & NxN height=1... Also the NxN dialog now remembers the last used values that session for the NxN lattice [width, depth, height, subdivide]...
- Global Moderator
- Name: TIG
- License type: Pro
by gilles » Sun Feb 03, 2013 3:09 pm
Works great, thanks a lot TIG, have a sunny day.
gilles
- Top SketchUcator
by matt.gordon320 » Sat Feb 09, 2013 1:01 am
Thanks! This is awesome!
matt.gordon320
- Premium Member
- Name: matt.gordon320
- License type: Pro
by litounba » Mon Feb 25, 2013 4:42 am
Thanks Chris,Thanks Chris.
litounba
- Name: oiiuou
by guanjin » Mon Feb 25, 2013 1:39 pm
TIG wrote:Here's my update viewtopic.php?p=36127#p36127The recently reported NxN issues with NaN [0.0/0.0] & Infinity [1.0/0.0] fixed, these occurred when the selected group was 2d & NxN height=1... Also the NxN dialog now remembers the last used values that session for the NxN lattice [width, depth, height, subdivide]...
New version, can not be achieved on the sphere deformation
I come from China, is to learn
guanjin
- Name: XIAOLONG
by TIG » Mon Feb 25, 2013 3:28 pm
guanjin wrote:TIG wrote:Here's my update viewtopic.php?p=36127#p36127The recently reported NxN issues with NaN [0.0/0.0] & Infinity [1.0/0.0] fixed, these occurred when the selected group was 2d & NxN height=1... Also the NxN dialog now remembers the last used values that session for the NxN lattice [width, depth, height, subdivide]...
But did the old version ? There is little difference with this update ! How are you trying to deform a sphere ??
- Global Moderator
- Name: TIG
- License type: Pro
by guanjin » Mon Feb 25, 2013 4:07 pm
TIG wrote:guanjin wrote:TIG wrote:Here's my update viewtopic.php?p=36127#p36127The recently reported NxN issues with NaN [0.0/0.0] & Infinity [1.0/0.0] fixed, these occurred when the selected group was 2d & NxN height=1... Also the NxN dialog now remembers the last used values that session for the NxN lattice [width, depth, height, subdivide]...
Sorry, operational errors, thank TIG
guanjin
- Name: XIAOLONG
by eshertoding » Mon Apr 15, 2013 1:17 pm
i can't find the "update ffd" after i move the point and close grup can't anyone explain me?
eshertoding
- Name: esher
by libinhui » Sat Apr 27, 2013 10:19 am
thank you!
libinhui
- Name: bin.li
by tootsiejo » Wed Jul 24, 2013 9:44 am
Hi i can't see the SketchyFFD in my SKP8. it doesnt appear. how do you really install it? is there a tool? it doesnt install when i put it in the plugins folder
tootsiejo
- Name: Jozef Atento
- License type: Pro
by TIG » Wed Jul 24, 2013 11:35 am
tootsiejo wrote:Hi i can't see the SketchyFFD in my SKP8. it doesnt appear. how do you really install it? is there a tool? it doesnt install when i put it in the plugins folder
Assuming you have indeed installed the .rb file into the Plugins folder and restarted SketchUp the tool runs from items in the right-click context-menu 'FFD...' if you have a suitable selection [group etc]... Please read the tool's instructions in the first page...
- Global Moderator
- Name: TIG
- License type: Pro
by DaddyDDesign » Fri Aug 16, 2013 8:42 pm
Hello I am somewhat new to sketchup and am having a bit of trouble with the "open control points group " step of the process. After the object has the control points around it I cant seem to snap to any of them, when I click the cursor just starts to create a selection box. I'm sure I'm missing something trivial, any help would be appreciated.
Thanks, Dave
DaddyDDesign
- Name: Dave Curoe
- SketchUp use: hobby
by TIG » Sun Aug 18, 2013 2:13 pm
You need to open the group to move the guide-points [aka cpoints] etc. You should be able to double lick on one of them to open the group. Failing that, use the Outliner to find it and double-click on the named entry in the Outliner dialog, it will then open to edit. To close an edit of a group [or component] click away from it in empty space, or use the right-click context-menu item to close it [or the equivalent Edit menu item]...
- Global Moderator
- Name: TIG
- License type: Pro
- Robot
Return to Plugins
