[Plugin] SketchyFFD (Updated 20130203)
Re: [Plugin] SketchyFFD (Updated Aug 22, 2009)
Postby cokea » Fri Sep 04, 2009 3:51 pm
can't it be used on su5? it formed a group containing just one construction point at 0,0,0 instead of the 2x2 or 3x3 or nxn points :bounce:
cokea
Postby fransoiski » Fri Sep 11, 2009 1:36 am
this script seems to be great, but actually it does'nt work with me, i can move the choosen points but nothing happens (i never have the choice "uptade FFD")
what's wrong ? if someone can help me it would be great. Thanks (sketchup 6, windows XP)
fransoiski
Postby teya » Thu Sep 17, 2009 8:31 pm
I have the same problem! the UPDATE FFD does not apear. It seemn pretty easy to use this plugin, I really got the idea in 10 seconds. But it doesn'n work at me. Did i do something wrong? Also, no erors in the Ruby console.
teya
Re: SketchyFFD (Free Form Deformation)
Postby myrto » Mon Oct 19, 2009 11:26 am
Pilou wrote:
That is the new group created by the FFD. You can simply delete or hide it when done with it.
THX: very simple indeed ! :enlight:
hello, i need a bit of help. I downloaded the ruby and copied it in the plugin directory but the ffd tool doesnt show up when i restart sketchup. Any ideas?
myrto
Postby myrto » Mon Oct 19, 2009 11:30 am
myrto
Postby myrto » Mon Oct 19, 2009 11:31 am
myrto
Postby massimo » Mon Oct 19, 2009 12:28 pm
Hi myrto, as far as i know, FFD works on groups. So you have to group your object then right click and you will find FFD in your context menu. Add how many control points you want and use the tool.
Read the very first post of this thread for detailed explanations.
massimo
Postby avya » Fri Oct 30, 2009 6:54 pm
thanks...
i'm gonna make make a try for this one.
avya
Postby majid » Sat Oct 31, 2009 12:06 pm
it seems that doesn't work on my SU7.1 free version :( anyone ealse has fronted with such problem too?
majid
Top SketchUcator
Postby xrok1 » Sat Oct 31, 2009 7:03 pm
worked for me in 7.1 pro?
BTW, i just used this script for first time for an actual purpose instead of just playing! :ecstatic: awsome thanks again. there was no other way i could think of to achieve the same result. i'm sure i could have tweaked and tweaked manually until i gave up. :? put its not my style. :lol:
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby chango70 » Sun Nov 01, 2009 5:49 pm
Doesn't appear to work anymore... (The May Version works fine)
chango70
Postby xrok1 » Sun Nov 01, 2009 6:31 pm
yeah, i think i made have the older version.
xrok1
Postby BlueScreen » Tue Nov 03, 2009 10:02 am
Hello my name paan,
can you find or make sketchup plugin that can detect the edge of the texture and turn into that shape . It's more like make the rectangle turn into the shape of the texture that have transparent background .
sorry for my bad English and i hope you understand what i meant
and if you find it don't forgate to send an email to me at:
fan_mustar@yahoo.com.my
BlueScreen
Postby plot-paris » Tue Nov 03, 2009 12:07 pm
hi paan,
I think that is quite difficult, because SketchUp isn't ment to do such operations with textures. I am not a ruby coder though.
if you have got Adobe Illustrator there may be a workaround by importing the image, tracing it and then exporting as dwg. file. then you can import the dwg into SketchUp... haven't done it myself though.
oh, and in future it might be better to open up a new thread for such enquiries. that is a completely different topic after all. having it as a separate discussion would help others too, when they are looking to solve similar problems ;)
plot-paris
Postby thomthom » Tue Nov 03, 2009 12:21 pm
BlueScreen wrote:Hello my name paan,
viewtopic.php?f=180&t=2564
PluginStore Author
PluginStore Author
Postby majid » Tue Nov 03, 2009 4:01 pm
I am confusing...FFD works for me occasionally!!!
majid
Top SketchUcator
Postby plot-paris » Tue Nov 03, 2009 4:05 pm
same for me. sometimes it works with 3x3 control points. sometimes it doesn't. sometimes it just needs a restart. sometimes it needs a whole new file. and sometimes it doesn't work at all, no matter what I do (custom control point numbers don't seem to work at all anymore).
so I am afraid this script needs to be rewritten for SU 7.1
what a pity :(
plot-paris
Postby CPhillips » Wed Nov 04, 2009 4:14 am
Sorry, I wasnt keeping up on this thread.
There is a problem with the script under 7.1 or just 7.0? Can you give me some idea how to reproduce the bug? If it starts misbehaving open up the ruby console and see if it is printing any errors.
CPhillips
PluginStore Author
PluginStore Author
Postby majid » Sat Nov 07, 2009 11:30 am
now I have only 7.1, and no idea , how it works/or not!!!!
majid
Top SketchUcator
Postby mariocha » Sat Nov 14, 2009 8:58 pm
CPhillips wrote:There is a problem with the script under 7.1 or just 7.0? Can you give me some idea how to reproduce the bug? If it starts misbehaving open up the ruby console and see if it is printing any errors.
Well, here, under 7.1 Mac, it still works but not as well as before. No matter where the group is located, the FFD dot matrix appears at the origin.
The console does provide a warning:
onSelectionBulkChange1
Webdialog set to#<Sketchup::Group:0x1ce30424>
WARNING: make_unique is a deprecated method of Sketchup:Group
onSelectionCleared
Hope this helps.
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
mariocha
Premium Member
Premium Member
Postby krash88 » Mon Nov 16, 2009 4:55 pm
Here's what I get in the console on 7.1 running on XP Home...
Error: #<NoMethodError: undefined method `*' for nil:NilClass>
krash88
Postby starship » Sun Dec 13, 2009 11:38 pm
I registered just to say thank you for this BRILLIANT plugin! :berserk:
As a side note, I have Windows Vista and SU 7. No problems at all. The plugin is working fine for me. ;)
starship
Postby mariocha » Tue Dec 22, 2009 4:58 pm
Good news, I guess the last update of SU corrected something related cause FDD now works just fine again.
No matrix offset anymore :ecstatic: :thumb:
Mario C.
mariocha
Premium Member
Premium Member
Postby bmscmoreira » Tue Jan 05, 2010 10:07 pm
First, thanks to the author for this great plugin! Unfortunately Im not getting it to work right with the latest sketchup release (SketchUp 7 (7.1.5803) and OSX.
The live update does not work, and only the 3x3 FFD works (with no live update).
My console reports this:
When creating the 3x3 FFD control points:
"WARNING: make_unique is a deprecated method of Sketchup:Group"
When creating the NxN FFD control points:
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:453:in `calcBernstein'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:210:in `initFFD'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:209:in `upto'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:209:in `initFFD'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:200:in `each'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:200:in `initFFD'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:151:in `startFFD'
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyFFD.rb:20"
Hope to fix this soon... the plugin is a really must-have :cry:
bmscmoreira
Postby Agisen » Fri Jan 15, 2010 9:05 am
thank you
Agisen
Postby voodyneo » Fri Jan 15, 2010 9:38 am
thankyou
voodyneo
Postby lepiredesochs » Thu Jan 21, 2010 12:06 pm
Hi All,
I just installed this ruby, everything is fine except that I cant update the FFD ( I actually have no "update FFD" choice in the menu).
Anybody can help?
Cheers,
Ben
lepiredesochs
Postby sus4 » Sun Jan 31, 2010 2:25 pm
mmm ..me to
wheres UpdateFFD ?
sus4
Postby Burkhard » Sun Jan 31, 2010 6:44 pm
First page!
Burkhard
Premium Member
Premium Member
Postby plot-paris » Mon Feb 01, 2010 6:55 pm
since switching to SketchUp 7 I can only use the default 3x3 lattice. any user defined deformation matrix doesn't work (the lattice is created, but moving the points doesn't have any effect)... :?
plot-paris
PreviousNext
Return to Plugins
Users browsing this forum: defatoosh, Google Bot, jamilleponte and 10 guests
