[Plugin] SketchyFFD (Updated 20130203)Re: [Plugin] SketchyFFD (Updated May 9 2008)Chris,
I can't get it to work. I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu. I've posted the model so you can have a look and tell what i'm doing wrong. Thanks in advance. Toby
Philippians 4:13 I can do everything through him who gives me strength. Re: [Plugin] SketchyFFD (Updated May 9 2008)Hi Tobobo
It's due to the hidden geometry. Look at this one, it's different with the hidden geometry, you can easilly deform it where you want. Just create the group and choose your FFD setting. cheers Edit After some FFD cheers Re: [Plugin] SketchyFFD (Updated May 9 2008)Thanks REGIS
I'll have to think of another way to deform the netting. Toby
Philippians 4:13 I can do everything through him who gives me strength. Re: [Plugin] SketchyFFD (Updated May 9 2008)Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
Cheers Re: [Plugin] SketchyFFD (Updated May 9 2008)I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
Thanks, -Tony Re: [Plugin] SketchyFFD (Updated May 9 2008)One possibility
Draw a rectangle Pull it with Ctrl any time you want Select all (triple click) Move it one time + CTRL = Copy Type "10*" (or more) = Multiple Select all (triple click) Group it Select group Right Click / FFD Edit the goup "FFD" Move points Et voilà ![]()
Re: [Plugin] SketchyFFD (Updated May 9 2008)Hi Chris, I've to say your work for this amazing RB is really great help for me! Thanks for your great job and sharing with us!!
Michael Xie Re: [Plugin] SketchyFFD (Updated May 9 2008)
There's a subdivide feature in the script.right click> FFD> NxN> set subdivide to true.
Yes but will be any effect on the subdivide of a simple rectangle!!! Nothing will arrive when you will move a point of the FFD! Seems the only easy methode is draw a rectangle with the Sandbox ![]()
Re: [Plugin] SketchyFFD (Updated May 9 2008)Hi..
I think there might be a problem with FFD an ASGVIS V-ray for scetchup.. FFD did not work while i had V-ray installed but now that i have uninstalled V-ray FFD works fine again.. Same problem as with subdivide and smooth script.. can anyone else confirm this ?? Btw, FFD is a brilliant script. ![]()
Re: [Plugin] SketchyFFD (Updated May 9 2008)woooaaaa
amazing plugin just what I needed thanx a lot ![]() Re: [Plugin] SketchyFFD (Updated May 9 2008)Works nice! But "transformations reset" needs sometimes before FFD starts.
Re: [Plugin] SketchyFFD (Updated May 9 2008)this looks like a wonderful ruby!!!
too bad it's not working for me, it doesn't do anything, and when I try undoing it beaks my geometry apart! would have loved to use it ![]() Re: [Plugin] SketchyFFD (Updated May 9 2008)Its not over yet. If its not working, then its installed wrong or your using it wrong. Or you have version 4 of SU
![]() Could you provide a better description of what its doing wrong? Perhaps screenshots, maybe a video. Just give us some more detail and we'll get it working for you. Chris
Re: [Plugin] SketchyFFD (Updated May 9 2008)I'm running Sketchup 7 and just added your FFD tool. I can move points but there is no 'update FFD' option when I'm finished. Is FFD not compatible with Sketchup 7?
Thanks! Re: [Plugin] SketchyFFD (Updated May 9 2008)The shape should update automatically, you might have to give it a bit of time, though.
If that doesnt work delete the control points, explode the group, regroup and try again. Re: [Plugin] SketchyFFD (Updated May 9 2008)After waiting on a 2.4 GHz dual core XP system, nothing changed. I've just installed FFD on my computer (2.1 GHz dual core) and created a circle so I could elongate one point. Nothing. This is disappointing.
Re: [Plugin] SketchyFFD (Updated May 9 2008)Have you tried it on 3d geometry? i think it can work on 2d things, but ive never gotten the hang of it.
Re: SketchyFFD (Free Form Deformation)
Re: [Plugin] SketchyFFD (Updated May 9 2008)Hi Chriss,
it really makes fun to work with FFD! I looked at your code and found the factorial function where you mentioned to encrease performance by adding a table for factorials. I made it dynamic and it boosts your code! Just replace the section with:
Ciao, Stefan Re: [Plugin] SketchyFFD (Updated May 9 2008)Thanks Stefan! Its a nice idea. I updated the plugin with an adaption of the code and applied it to the Bernstein Polynomial as well. It sped up the initial weighting of a big model from 75 seconds to 15 seconds.
I also figured out a way (in theory) to speed up the actual deformation by like 50x. The only problem is I would have to handle moving the control points without using any of Sketchups tools like select, move and rotate. Ugh!
Re: [Plugin] SketchyFFD (Updated Aug 22, 2009)Thank you for the update. It really is an effective modeling tool.
Re: [Plugin] SketchyFFD (Updated Aug 22, 2009)I found another way to speed the updates. A model with 11300 verts takes about 90 seconds to update in this version and about 6 seconds with the new method.
But it order to get it ready for release I would almost have to rewrite it. Because it would be a significant amount of work I am thinking I might make the new one a "Pro" version. Question: How many would be willing to pay for a version with some significant updates? And what would be a fair price to charge?
Re: [Plugin] SketchyFFD (Updated Aug 22, 2009)Sounds like a significant speed improvement. I would pay for a Pro version with a few new features. I think in the range of $15 is fair.
Guide Tool at Winning With Sketchup Content Creator at Skapeup
Re: [Plugin] SketchyFFD (Updated Aug 22, 2009)By the way, about 10 € ( 15$) seem to be a fair sum, as far as this version is also
available for SU ( not the Pro version )... MALAISE ![]() La Connaissance n'a de valeur que partagée
Re: [Plugin] SketchyFFD (Updated Aug 22, 2009)I would pay for it too. $15 seems reasonable.
FFD isn't working on my computer aswell, so i've read the whole topic to see for an answer. Unfortunately there are no answers yet. I've downloaded the curtain.skp-file so I could try to FFD it with the sketchup version I am using. That worked fine! Other objects drawn in the curtain.skp-file transformed aswell by using the FFD plugin. However, copying the curtain into a new file: no result, no transformation. I'll just try some other options and hopefully I or someone else will come up with an answer on why the FFD-plugin not always work... EDIT: In a new file I've created an 10x10 patch to transform. The transformation is succesful with an NxN FFD with default settings (4x4x4 false) and moving all 4 guidepoints. Other tried and failed setting: 4x4x1 false, 4x4x2 false, 4x4x3 false, 4x4x5 false, 4x4x4 true, 5x5x4 false.... Seems like only the default setting work at my computer. |
Users browsing this forum: Calcifer, carlos17, Darkness84, frisdianata, leon2525, ygoro and 13 guests
