[Plugin] FaceSplit v1.0.3
Postby renderiza » Sat Oct 19, 2013 7:18 pm
Authors:: Anar | Dan Rathbun | Pilou | Renderiza | TIG
Plugin Name:: FaceSplit
Version:: 1.0.3
Date:: 11/4/2013
Cost:: Free
FaceSplit
Split faces up a variety of ways. This only works as expected on convex faces.
For plugin compatibility it is recommended to instal
Internet Explorer 9 or higher.
Available at
sketchUcation
plugin Store
click here
______________________________________________________________________
Web-Dialog
-2
renderiza
Premium Member
Premium Member
Re: [Plugin] FaceSplit v1.0.0
Postby cotty » Sat Oct 19, 2013 9:46 pm
Discussion which leads to this nice plugin...
Nice! Thank you. :thumb:
cotty
Top SketchUcator
Postby renderiza » Sun Oct 20, 2013 12:25 am
Thank you for giving a link to the Discussion that started it all. Also here is another that played a big part in optimizing the code.
Apart from dividing the face like in the second row of the image, was thinking to add additional options like the ones below that. The trick here is to provide an easy to understand user interface where you can change the options.
renderiza
Premium Member
Premium Member
Postby mitcorb » Sun Oct 20, 2013 4:54 am
Something like: split by angles to centroid, split by medians to centroid, split by angles to medians, split by angles, medians through centroid?
Or, split by bisect angles, bisect edges, ??
mitcorb
Top SketchUcator
Postby renderiza » Sun Oct 20, 2013 5:36 am
mitcorb wrote:Something like: split by angles to centroid, split by medians to centroid, split by angles to medians, split by angles, medians through centroid?
Correct! :thumb:
mitcorb wrote:Or, split by bisect angles, bisect edges, ??
Was not thinking of this option but, if I am not mistaken TIG's TriangulateAllFaces is accomplished this way.
renderiza
Premium Member
Premium Member
Postby glro » Sun Oct 20, 2013 1:36 pm
The purpose of such a plugin may be purely graphical, and all the options mentioned are interesting
There is another purpose possible
http://www.spatial.com/products/3d-mesh
"3D Mesh provides automatic mesh generation for curves, surfaces (triangle and quadrilateral) and volumes (tetrahedral)"
sketchup is not a real 3d software, since a volume is only a space closed by surfaces
Would it be possible to write a plugin that would do something similar to what 3d mesh does, by drawing lines on the surfaces and between the surfaces
3d mesh may follow different patterns
http://www.ansys.stuba.sk/html/guide_55/g-mod/GMOD7.htm
This mesh could be exported to a structural analysis software
Might be related to Voxelize
http://sketchucation.com/forums/viewtopic.php?t=36063
a lot of work, though...
glro
Postby iichiversii » Sun Oct 20, 2013 3:15 pm
excellent, ill be using that :D
Thanks for sharing :thumb:
Bring on the Rain...
iichiversii
Premium Member
Premium Member
Postby tomot » Sun Oct 20, 2013 8:01 pm
very nice! :thumb:
I was thinking of an added option also: We now have split from vertex, can we add split from midpoint?
tomot
PluginStore Author
PluginStore Author
Postby renderiza » Sun Oct 20, 2013 10:15 pm
Warning!
The examples shown below are not features the current version support. These are ideas for possible future updates so please don't be confused by it. ;)
From vertices to centeroid (Current function of plugin)
Currently the plugin has no problem when dealing with multiple faces because the existing edges are no sliced. We only add new vertex in center of geometry and reuse the existing face vertices after that.
From medians to centeroid
In this case we do split the existing edges in half and that cause effect we see in the 3rd row of the image. Each face will exponentially increase the number of edges in which the script will divide causing different results each time.
The example in the 2nd row of the image was able to maintain the same amount of edges per face because each color represent a group. Notice none of the same color groups can touch each other.
Conclusion
Will have to figure out a way to reproduce the results in the 2nd row of image without having to make multiple groups. Not sure how at the moment but maybe if I open this to discussion in the development forum it can get solved quickly.
When I saw the results on row number 3 of image I sort of like what I saw. Maybe this effect is what someone might want who knows. :?
glro: That would be ideal for the plugin to reach to that level but first I need to figure out simple stuff like the ones mentioned above. Thanks for your input really appreciate it! :thumb:
iichiversii: Hey long time no see!!! Glad you found a use for it. :thumb:
tomot: Yes above I tried demonstrated some of the issues to solve before adding the feature of splitting from medians to centroid.
renderiza
Premium Member
Premium Member
Postby TIG » Sun Oct 20, 2013 10:30 pm
No need to group ?
Collect all of the faces.
Then collect points for each of the faces - i.e. the 'center' point and the all of the perimeter points needed.
Iterate the points collection - get the 'center' point, then add the new edges from the other points...
Code: Select all
### pseudo-code...
faces=[face1, face2, etc]
points=[[face1_points_array], [face2_points_array], etc]
### NOW add edges from each fixed set of points
points.each{|pts|
  cpt=pts.shift ### gets/removes 1st point
  pts.each{|pt| ents.add_line(cpt, pt) }
Global Moderator
Postby renderiza » Sun Oct 20, 2013 10:58 pm
Thank you TIG will try that ASAP!!!
...TIG's suggestion works! Here is a code sample that you can copy & paste for testing...
The only function the code does is to split faces from medians to centroid.
Code: Select all
def csplit()
model = Sketchup.active_model
ents = model.active_entities
sel = model.selection
faces = sel.grep(Sketchup::Face)
edges = []
avg = []
cl = []
model.start_operation('csplit')
   faces.each do |face|
      edges << face.edges
      # Medians #
      lines = face.edges
      lines.each {|e|
      e1 = e.start.position
      e2 = e.end.position
      x = (e2.x + e1.x) / 2
      y = (e2.y + e1.y) / 2
      z = (e2.z + e1.z) / 2
      cl << Geom::Point3d.new( x, y, z )
      # Centroid #
      sum = Geom::Point3d.new(0,0,0)
      verts = face.vertices
      n = verts.size.to_f
      verts.each {|v| sum += ORIGIN.vector_to(v.position) }
      avg << Geom::Point3d.new( sum.x/n, sum.y/n, sum.z/n ) #/
   end # each face
   # From Centroid to Medians #
      centroid = avg.shift
      edges.shift.each {|e|
         lc = cl.shift
         ents.add_line( centroid, lc )
model.commit_operation
rescue => e
puts "Error <#{e.class.name}: #{e.message} >"
puts e.backtrace if $VERBOSE
model.abort_operation
else # when no errors:
sel.clear
end # csplit()
# Run #
csplit()
Always welcome suggestion to make code better...cheers! :thumb:
renderiza
Premium Member
Premium Member
Postby renderiza » Mon Oct 21, 2013 3:09 am
Look what happens if you test the code above with object similar to the one in image below. If the face has a hole in the middle and is not triangulated or quadrangular like in the 2nd row the result can be messy.
The second row show much better result because the first object had quad face before applying script.
Hope this helps.
renderiza
Premium Member
Premium Member
Postby TIG » Mon Oct 21, 2013 10:16 am
I was about to tell you of the issue with faces with holes or L shapes having a centroid 'off-face', but you have displayed it already...
Here is the 'fix'...
As you iterate each face check
face.classify point(cpt)
If it is not on the face, on a face-edge or on a face-vertex then do this:
tr=Geom::Transformation.new()
es=ents.intersect_with(false, tr, ents, tr, true, ents.to_a)
You could reduce the intersected array to say face.edges provided you have a reference to the face ?
Then if some edges collected into 'es' remain 'unfaced' use this to erase them? :
es.grep(Sketchup::Edge).each{|e|e.erase! unless e.faces[0]}
Global Moderator
Postby pilou » Mon Oct 21, 2013 10:19 am
Bravo! :fro:
Some testings in view and some track the bugs! ;)
Ps you are very friendly to have put my name but take attention that I have not made any code just a little moment of inspiration (given by a French guy anar! ;) :enlight:
Top SketchUcator
Postby anar » Mon Oct 21, 2013 10:44 am
Pilou wrote:Bravo! :fro:
Thanks Pilou for mentioning that I started that discussion with you here : http://www.polyloop.net/showthread.php/ ... /page7#133
And thanks also because without you that plugin would have never been made !
Anar
http://www.reppersdelight.spacymen.com
anar
Postby glro » Mon Oct 21, 2013 12:59 pm
renderiza wrote:Look what happens if you test the code above with object similar to the one in image below. If the face has a hole in the middle and is not triangulated or quadrangular like in the 2nd row the result can be messy.
Hope this helps.
i thought it was only for surfaces, but i see that it works on volumes also...
would it be possible to split the volume following the liness making like a 3d puzzle?
this would mean adding surfaces following the lines to make independant volumes
like "voxelize.rb", but not only cubes
glro
Postby pilou » Mon Oct 21, 2013 5:05 pm
Seems working fine :)
Top SketchUcator
Postby pilou » Mon Oct 21, 2013 5:16 pm
And all medians are present! :thumb:
I don't want imagine the possibilities in 3D! :mrgreen:
Top SketchUcator
Postby renderiza » Mon Oct 21, 2013 6:10 pm
TIG: Thank you TIG will test that out effective immediately! :bounce:
Pilou & Anar: People that bring ideas to the table deserve recognition as well. :thumb:
glro: That would be very cool indeed! I think there is a plugin that does something like this but don't remember it just now. If I find it will let you know. :thumb:
Pilou: Very cool! :thumb:
renderiza
Premium Member
Premium Member
Postby Pixero » Mon Oct 21, 2013 8:16 pm
Hi!
May I suggest an addition.
For people working in 3ds Max a imported SketchUp model is sometimes hard to work with because it doesn't consist of evenly sized quad faces. I have this idea to be able to split a face with inner loops like windows by projecting lines in the direction of the edges to the outer loop.
See this quick sketch.
Pixero
Postby glro » Mon Oct 21, 2013 8:18 pm
renderiza wrote:..
[b]glro:
Maybe you think also to voxelize.rb
but voxelize makes cubes only; it would be funny to split the volume in exact sub-volumes, and try to build the whole volume back again, using sketchup
i have a 3d connexion mouse, and there is a game like this, to learn how to use it
and in addition, splitting a volume in sub-volumes is equivalent to building a 3d mesh, for structural analysis...
glro
Postby renderiza » Mon Oct 21, 2013 9:11 pm
Pixero wrote:I have this idea to be able to split a face with inner loops like windows by projecting lines in the direction of the edges to the outer loop.
This is excellent idea! It will produce the cleanest geometry possible before dividing it even more. :thumb:
glro wrote:Maybe you think also to voxelize.rb
The plugin I had in my mind was not voxelize...it was one that only worked if you had SketchUp Pro.
Anyways making a plugin like this would be cool indeed. Not sure if I possess the knowledge to do it myself at the moment but will see if I can experiment with the idea in the future.
renderiza
Premium Member
Premium Member
Re: [Plugin] FaceSplit v1.0.1
Postby renderiza » Mon Oct 28, 2013 6:43 am
Version:: 1.0.1
Date:: 10/28/2013
Cost:: Free
FaceSplit v1.0.1 is now available for download.
Note: Will eventually make video explaining how to use plugin.
renderiza
Premium Member
Premium Member
Postby pilou » Mon Oct 28, 2013 11:54 am
Sure a video will give some ideas to users! :)
What are the natures of the up date ?
Top SketchUcator
Postby guanjin » Mon Oct 28, 2013 5:43 pm
我点击图标,没有任何反应!
I come from China, is to learn
guanjin
Postby cotty » Mon Oct 28, 2013 7:52 pm
guanjin wrote:我点击图标,没有任何反应!
You should click after you have selected one or more faces.
cotty
Top SketchUcator
Postby guanjin » Tue Oct 29, 2013 4:04 am
:roll:
I have tried。
Thank you
guanjin
Postby 120711014 » Tue Oct 29, 2013 9:26 am
thanks for sharing~~~~~~~~
Postby Ulimann » Wed Oct 30, 2013 8:38 pm
I have tried but no success,to get this plugin to work.I have reinstalled a few times!
Running SU 8 Pro on Windows 7.
Any suggestion to get it working?
Ulimann
Postby erikB » Wed Oct 30, 2013 10:01 pm
same here.
also SU8 pro and win 7 (64)
I also think I have all the administrator rights set on every subdirectory.
Strange, I can see the icon but can not click on it nor can I change the number.
erikB
erikB
Next
Return to Plugins
Users browsing this forum: a331216a, DianaGr266, mehmet kerim layık and 14 guests
