[Plugin][$] TopoShaper - v2.6a - 24 Apr 21Re: [Plugin] TopoShaper - v2.5c - 29 Oct 19 - IsoContour & CI was able to copy my linework into a new sketchup file and get it to work - not sure what the issue was before - I have been getting similar cleansing errors for some time, but never created a log, so not sure how similar they are...
What version of SketchUp are you using? Please complete your profile. Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] TopoShaper - v2.5c - 29 Oct 19 - IsoContour & CSketchup Pro 2021 on Windows 10.
Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & CHey guys,
Is there a way to make changes to the terrain after it as been generated? Like making an undergound level. Also, is there a way to make a step and not join two lines with a slope? Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & CHello,
TopoShaper just started giving me problems. I've used for years without any hickups..no idea why I'm getting errors now. When I select contours and run TopoShaper, I get 'cannot hide layer that is a part of the active path' Error. This is happening on both office and home pc. Sketchup Pro 21.1.299, Windows 10 pro. error log attached, one from office, one from home office. If anyone has any ideas or has time to check this out, I'd sure appreciate it. Thanks! Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & CUpdate:
I got it to work. exploded, copied to new drawing, etc. All good now. ![]() Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & CTopoSahper has to play with layer visibility to have the 2D/3D view. So, if you are not at the top level of the model, there may be problems.
Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & CI just installed Libfredo6, restarted sketchup, and then installed the toposhaper plugin, then rebooted again and the plugin is nowhere to be found. In the window menu if the LibFredo6 options menu appears. I have SK2019
Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & CTopoShaper appears in a Fredo... submenu under Tools.
There is also a Toolbar option... TIG
Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & CInstalled Toposhaper (sketchup pro 2021) and when I start out with "cleansing contours it goes to a yellow square with the contours to the side and no toolbar to select the parameters from. seem to be able to work through it by right clicking and selecting "create preview". Ultimately what I'm hoping to do is to adjust the level of smoothing so that I get things like the sidewalks showing up in the examples below. Attaching below terrain done with native sandbox tools, and then done with toposhaper. hoping I can get something between the two in terms of terrain detail and most importantly eliminating the jagged geometry created with sandbox.
Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & CCould you send me the model with the isocontours. There may be a bug somewhere.
Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & CHi
I work with the plugin toposhaper in terrains I don’t understand why it doesn’t let the grid value change The plugin set limits min and max I wont a grid with 2 meters I did the same with the plugin Sandbox bonus tool and allowed can someone help me Thanks Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & CSorry for that. TopoShaper manages a grid by number of rows and columns at the moment. So you have to figure out the right number to get close to your 2 meter.
I'll probably improve that in the future. Fredo
Re: [Plugin][$] TopoShaper - v2.6a - 24 Apr 21Hi,
I'm trying to use TS v2.6a. It is installed and the toolbar is showing. However, when I try to use the plugin nothing happens. Both icons can be selected, but no action takes place. I have un-installed the plugin, then re-installed it. The got the following error message; "TopoShaper 2.6a: Error starting up pi ugin (creating menus and icons) undefined method ''add_item' for nii:NiiCiass [in lib6traductor.rbe - #'add_command(): line 1391] c:jusers/mwds/appdatajroaming/sketchup/sketchup 2022/sketchup/plug ins/fredo6_! I ibfredo6/li b6core.rbe:1 072:in 'rescue in block in effective_load_part2'" Any ideas? Re: [Plugin][$] TopoShaper - v2.6a - 24 Apr 21Have you installed the newest LibFredo available from the PluginStore ??
Re: [Plugin][$] TopoShaper - v2.6a - 24 Apr 21This fixed the "cannot hide layer that is a part of the active path" for me:
Make sure the selected contours or points are not in another group. Bring them out of all groups (except for the groups each contour may be in). Re: [Plugin][$] TopoShaper - v2.6a - 24 Apr 21Bon Jour Fredo and TopoShaper users
![]() I am new. I only downloaded TopoShaper yesterday. I found it while looking for solutions for a DMG file with LiDAR contour lines for our 20 acre land. The DMG once opened in SketchUp shows almost 2 million edges ![]() ![]() At first when I tried working with it on Sketchup, either exploding it, or once in Edit Component trying to use the SketchUp From Contours tool. Sketchup crashed. I learned that if I isolated/selected small areas of a maximum 10,000 edges then I could work with the Sketchup tools, but that would take me too long. So, looking for solutions, I found this great tool! That said, I have a couple of questions, I hope you can help me with. ![]() First, TopoShaper seems to have successfully exploded the DMG. It took a long time but it didn't crash! QUESTIONS: Since what I need is a terrain as precise as possible (hence the LiDAR) ![]() In the SELECTION Stage: Using Iso-Contours, I tried to "select", all the Contour lines in my Original but that crashed the program. So I am generating the terrain in "sections/groups" that I created from my original, far larger than what I could do with the native sketchup tools. - How does the Maximum Edge Angle for Follow Mode work? - because I am sectioning the whole terrain in chunks, should I Stop Prolongation at Edge Crossings? Or should I keep the Prolongation? At present, In the CLEANSING stage: - I am not excluding contours - I am accepting all simplification of the contours. The PDF says that TopoShaper uses an 8 degree angle automatically. Is this the same angle referred to in the SELECTION Stage - Maximum Edge Angle for Follow Mode in degree? - I am not accepting the junctions, (My file does not have labels, so the few proposed junctions are on the perimeter of each section I am converting. - I am not using Edit Altitude. If left untouched will TopoShaper keep the altitude for each point that was in the original DWG? For the CALCULATING OF CONTOURS stage: - Is there a way to edit out the extrapolation that takes place between a single contour and the hull border? Since I am doing this in sections, this creates flat surfaces in between SOME sections, not always. (I always choose the hilltop option FYI) - I am using a grid of 100 for the X value and let TopoShaper calculate the Y. Will this give me enough "precision" or should I increase the value to 200? In the GENERATION screen, There is a section for Altitude Labels. I have tried, the ALL option, and also the Filtering, but they never show. What should I do? Once TopoShaper is active, is there a way to pan and or orbit the view? Every time I try, I am taken out of TopoShaper, so I cannot see, if the result is what I want before I generate it. I know these are a lot of questions. Apologies. But I really need to understand how to use this great tool to produce the results I need. Thanks for your time, energy and ingenious mind! ![]() Helena Re: [Plugin][$] TopoShaper - v2.6a - 24 Apr 21@varioushemrog
It seems you are pushing TopoShaper beyond natural limits. I would suggest that you simplify the model. With IsoContours, it does not matter to have very close contours, because TopoShaper interpolates anyway between contours.
Re: [Plugin][$] TopoShaper - v2.6a - 24 Apr 21Merci, Fredo.
![]() ![]() I am looking for other ways to open the dmg file (I don't have autocad) and try to reduce the edges. I even installed GRASS GIS in my Mac and it reduces the edges by 63% but it is not keeping the 3D. I am trying to find ways to fix that. I really want to understand more how your extension works ![]() 1. How does the Maximum Edge Angle for Follow Mode work? 2. Because I am sectioning the whole terrain in chunks, should I Stop Prolongation at Edge Crossings? Or should I keep the Prolongation? 3. If left untouched will TopoShaper keep the altitude for each point that was in the original DWG? 4. Is there a way to edit out the extrapolation that takes place between a single contour and the hull border? 5. Will a Grid of 200 X give me a MORE precise Terrain than a grid with 100 X ? 6.Is there a way to pan and or orbit the view? Every time I try to use the Orbit or Pan tools I am taken OUT of TopoShaper I hope you don't mind my questions. I love your extension, and I would like to use it properly ![]() Have an excellent weekend! Helena |
Users browsing this forum: kapiljha471, kizo, laowang, Rafaelj, rainer26, Rougeee, rstasdmr22, usernamehj and 15 guests
