Deep nest
Deep nest
Postby kachupp » Sat Jan 26, 2013 11:31 pm
Looking for a plugin that has a; ONE click exit from a deeply nested component preferably “right click context menu” Any tool exist?
User avatar
kachupp
Re: Deep nest
Postby Dave R » Sun Jan 27, 2013 1:40 am
Have you tried using the Outliner?
User avatar
Global Moderator
Re: Deep nest
Postby kachupp » Sun Jan 27, 2013 2:06 am
Dave R wrote:Have you tried using the Outliner?
Never thought of using it.. it works. I'd still prefer right click exit :thumb:
User avatar
kachupp
Re: Deep nest
Postby Jim » Sun Jan 27, 2013 4:55 am
Paste this into a file with the .rb extension in your plugins folder.
Code: Select all
UI.add_context_menu_handler {|menu|
  menu.add_item("Close All Contexts") {
    Sketchup.active_model.selection.clear
    while (Sketchup.active_model.close_active); end
Jim
Global Moderator
Re: Deep nest
Postby kachupp » Sun Jan 27, 2013 9:52 am
Perfect Jim thank you very much
User avatar
kachupp
Re: Deep nest
Postby irwanwr » Sun Jan 27, 2013 11:08 pm
[Plugin] Deep Nested Escape? :P
User avatar
irwanwr
Re: Deep nest
Postby halroach » Sun Jul 21, 2013 10:00 am
Nice!
I am unable to assign a keyboard shortcut to it. How can I do it?
User avatar
halroach
Re: Deep nest
Postby massimo » Sun Jul 21, 2013 10:05 am
You'll find it in the context menu: right click-->Close All Contexts
User avatar
massimo
Re: Deep nest
Postby Dave R » Sun Jul 21, 2013 10:18 am
Since it is in the Context menu, you need to have something selected such that there'd be a Context menu entry for the plugin. Open a component or group within a nest and select an edge or face. It'll then be available for setting the shortcut.
User avatar
Global Moderator
Re: Deep nest
Postby halroach » Sun Jul 21, 2013 10:42 am
Dave R wrote:Since it is in the Context menu, you need to have something selected such that there'd be a Context menu entry for the plugin. Open a component or group within a nest and select an edge or face. It'll then be available for setting the shortcut.
Right!! thanks!!!
Excellent!!! :thumb: :thumb:
User avatar
halroach
Re: Deep nest
Postby massimo » Sun Jul 21, 2013 10:49 am
Not so easy I'm afraid, but i might be wrong. It will work only depending on what you have selected when you assigned the shortcut and not in any situation and at any "level" of selection like the "normal" right click does.
User avatar
massimo
Re: Deep nest
Postby Dave R » Sun Jul 21, 2013 11:04 am
Massimo, you're right. However the plugin isn't available to select from the Function list unless an entity within a component is selected. It doesn't have to be a face within an inner component. It could be a component that is selected. Unless an entity is selected, though, the keyboard shortcut won't work. Weird.
User avatar
Global Moderator
Re: Deep nest
Postby Bob James » Sat Mar 22, 2014 11:25 am
Jim wrote:Paste this into a file with the .rb extension in your plugins folder.
Code: Select all
Called it BackOut.rb, assigned a shortcut to it, added it to a key on my P.I. Engineering x-keys keyboard and now I can back out from within any group/component with one key. Sure beats pecking at the Escape key :D
Thank you very much :thumb:
User avatar
Bob James
Premium Member
Premium Member
Re: Deep nest
Postby Jim » Sat Mar 22, 2014 11:42 am
You're welcome.
I will be adding 2 commands to Custom Toolbars named "CloseActive" and "CloseAllActive" for those who like toolbar buttons.
Jim
Global Moderator
Re: Deep nest
Postby Jim » Sat Mar 22, 2014 11:49 am
Bob, I could put "BackOut.rb" in the Plugin Store, if that would be alright with you.
Although I wonder if it's worth it for what is practically a one-liner; but I suppose code size isn't always related to usefulness.
Jim
Global Moderator
Re: Deep nest
Postby kaas » Sat Mar 22, 2014 12:56 pm
Code: Select all
Thanks a lot! Those few lines of code make working with more complex object trees much easier.
kaas
Re: Deep nest
Postby tt_su » Sat Mar 22, 2014 3:14 pm
kaas wrote:Thanks a lot! Those few lines of code make working with more complex object trees much easier.
The Outliner will let you jump directly in and out of the model hierarchy.
User avatar
tt_su
SketchUp Team
SketchUp Team
Re: Deep nest
Postby kaas » Sat Mar 22, 2014 3:34 pm
tt_su wrote:The Outliner will let you jump directly in and out of the model hierarchy.
I know, I use it all the time but using a keypress is a bit more quick than moving the pen to the outliner and back again.
kaas
Re: Deep nest
Postby Bob James » Sat Mar 22, 2014 11:10 pm
Jim wrote:Bob, I could put "BackOut.rb" in the Plugin Store, if that would be alright with you.
It's your plugin, all I did was give it a name :D
Jim wrote:Although I wonder if it's worth it for what is practically a one-liner; but I suppose code size isn't always related to usefulness.
This one is worth it
User avatar
Bob James
Premium Member
Premium Member
Re: Deep nest
Postby Krisidious » Thu Nov 06, 2014 10:43 am
looked for this in the plugin store... didn't find it. needs to be there. doesn't seem to work in 2015?
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Re: Deep nest
Postby Box » Thu Nov 06, 2014 11:10 am
Works fine for me in 2015
User avatar
Re: Deep nest
Postby Dave R » Thu Nov 06, 2014 11:20 am
It does for me, too.
User avatar
Global Moderator
Re: Deep nest
Postby Krisidious » Thu Nov 06, 2014 11:22 am
Hmmm...
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Re: Deep nest
Postby Krisidious » Thu Nov 06, 2014 11:23 am
Did you save the rb or make one yourself?
That was it... I made the rb last time and this time I downloaded it. it's called backout now instead of close all contexts as I'm used to.
Thanks guys.
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Re: Deep nest
Postby Dave R » Thu Nov 06, 2014 11:37 am
You could easily edit the text to say that again.
User avatar
Global Moderator
Re: Deep nest
Postby Krisidious » Thu Nov 06, 2014 11:39 am
I have... I named it GTFO!
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Re: Deep nest
Postby pbacot » Thu Nov 06, 2014 5:13 pm
Wow this is just what I was asking for just the other week, but no one who answered seemed to remember it. Maybe it is just my machine but backing out of components is a PITA. So slow sometimes.
Thanks guys for creating and posting this!
Now for the opposite (key command)+click on an entity inside a component to open (edit) that entity's component (/group) to raw geometry level.
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Google Bot, Jojosh7, quanghung1901 and 21 guests
