[Plugin] WireTool (Catenary) (1.4.1) – updated 06.03.2013
Re: [Plugin] WireTool (Catenary) — updated 03.06.2012
Postby Michaelv » Sun Jun 03, 2012 11:46 pm
Thanks!
A nice option (but I can do it when I get a minute) would be for the start to start either like you did (wire) or horizontal )like a cable that's more rigid, yet supported by posts.
Toggle with alt/option
I think all it takes is force the angle at point of attachment to be horizontal, and the equation would take care of the rest. But maybe not. :)
Never mind, I looked at it and the equation as it stands is for tension always parallel to the tangent of the curve, thus deflection equations (with rigidity, etc..) at the boundary would have to be used until that is the case. too complicated for the time being.
Danke Shoen!
Michaelv
Postby moluasa » Tue Jun 05, 2012 4:04 pm
Might also be cool to work with for line art!
moluasa
Premium Member
Premium Member
Re: [Plugin] WireTool (Catenary) (1.4.0) – updated 01.03.201
Postby Aerilius » Fri Mar 01, 2013 3:45 am
Minor update (1.4.0):
- converted it into a SketchUp Extension (that you can turn on/off)
- added icons and cursor
Please remove older version if you update.
Aerilius
PluginStore Author
PluginStore Author
Postby Oxer » Tue Mar 05, 2013 2:43 am
Thanks for the update!!
This is the spanish language:
"es" => {
"Draw Wires" => "Dibujar Cables",
"Catenary" => "Catenaria",
"Tool to draw catenary curves." => "Herramienta para dibujar curvas catenarias."
"Arc Length" => "Longitud Arco",
"Segments" => "Segmentos",
"Distance" => "Distancia",
"Select first end" => "Selecciona Primer Final",
"Select second end" => "Selecciona Segundo Final"
You can to include in the next version.
EDIT: On Mac the icon doesn't show but I have added the line below in the end of the WireTool.rb file and now it shows:
UI::Toolbar.new(@@translate["Draw Wires"]).add_item(cmd)
http://www.oxervision.blogspot.com/
Oxer
Postby Aerilius » Tue Mar 05, 2013 10:41 am
Thanks!
Aerilius
PluginStore Author
PluginStore Author
Postby gilles » Tue Mar 05, 2013 11:22 am
I notice that you specify a length you always got a approximation, not the desired length.
gilles
Top SketchUcator
Postby Aerilius » Tue Mar 05, 2013 12:11 pm
That has two reasons: SketchUp has no curves and like arcs, the length of these catenary curves isn't the sum of the segments.
The other reason is that the numerical algorithm needs many many more iterations to reduce the bulge if the curve is almost straight (100% should theoretically give a straight line). I'm working on improving this.
Aerilius
PluginStore Author
PluginStore Author
Postby gilles » Tue Mar 05, 2013 1:40 pm
Good work by the way, a useful one.
gilles
Top SketchUcator
Postby Aerilius » Tue Mar 05, 2013 8:47 pm
Just to give you an idea: I increased the number of iterations (at every mouse move) from 10 to 150 and the overlength is still half of what it was before (and 150 iterations is far too much). But at least I know which part to optimize.
Aerilius
PluginStore Author
PluginStore Author
Postby Bob James » Tue Mar 05, 2013 10:40 pm
Aerilius wrote:Minor update (1.4.0):- added icons and cursor
I don't see "draw wires" in my toolbar list
Bob James
Premium Member
Premium Member
Postby TIG » Tue Mar 05, 2013 11:22 pm
Did you first activate its Extension under Preferences ?
Global Moderator
Re: [Plugin] WireTool (Catenary) (1.4.1) – updated 06.03.201
Postby Aerilius » Wed Mar 06, 2013 12:06 pm
I've uploaded a new version 1.4.1 improving the 100% curve length issue (curve was too long).
The previous version didn't mention any toolbar (only icon image), though as it seems nobody else has a problem with one-button toolbars I added one :enlight: . I hope it doesn't increase the toolbar mess.
Aerilius
PluginStore Author
PluginStore Author
Postby Oxer » Wed Mar 06, 2013 2:38 pm
Thanks Aerilius!!
I have saw that you have included the line for the Toolbar and spanish language, thanks again.
Oxer
Postby irwanwr » Fri Mar 08, 2013 6:45 pm
Thank you very much for this plugin.
irwanwr
Postby slander » Fri Apr 26, 2013 8:33 am
Thanks very much for this. It produces a really lovely result for drawing thin arches.
I noticed a small problem when I move the endpoints of an existing catenary around - gravity seems to veer away at an peculiar angle. All plan-plane moves seem to work just fine though.
slander
Postby Aerilius » Fri Apr 26, 2013 5:12 pm
the resulting curve is just SketchUp geometry, and does not expose physical behavior of a wire. When moving one end point of an arc, it shows normal SketchUp behavior (ie. SketchUp tries to squeeze or stretch the arc to fit to both end points).
But a wire that really (physically) moves with attached objects would be a cool feature. The plugin would need observers to watch all the time on all these arcs, and recalculate an arc once an endpoint is changed.
Aerilius
PluginStore Author
PluginStore Author
Postby Ben Ritter » Thu Aug 15, 2013 10:17 pm
I cannot get the plugin to work with specific inputs. It creates a the same curve no matter what I enter.
Can you help?
Ben Ritter
Postby Ben Ritter » Thu Aug 15, 2013 10:44 pm
Never mind, I figured it out. You have to press Enter after entering the distance, etc.
Ben Ritter
Postby escufi » Tue Nov 19, 2013 5:35 pm
Nice Plugin Aerilius , very usefull. Thanks a lot
escufi
Postby derei » Wed Jul 15, 2015 4:18 pm
Very nice and useful !
One question: shouldn't be better suited under DRAW menu, instead of Extensions?
There is a uncanny tendency to put the plugins under Tools or Extensions menus... leaving all others with too little entries, even if the plugin in cause should better fit in other menu.
Cheers.
DESIGNER AND ARTIST DEREI.UK
derei
Postby Dave R » Wed Jul 15, 2015 4:24 pm
Nothing is preventing you from editing the .rb file and changing it to appear in the draw menu.
Global Moderator
Postby derei » Wed Jul 15, 2015 4:51 pm
Dave R wrote:Nothing is preventing you from editing the .rb file and changing it to appear in the draw menu.
Unless the author comes with a update at one point and the old (modified) script is replaced... that was my point. I already edited several of the plugins I use.
derei
Postby Einstein » Mon Apr 19, 2021 2:09 pm
I'm confused.
I can see this plugin had an update recently [Version Updated: 2021-04-12 09:26:24]
but it's been version 1.4.1 since 2013. Why was it updated now while it's still the same version and no changes were introduced?
Einstein
Postby TIG » Mon Apr 19, 2021 3:00 pm
The current version is v1.4.1
Download
Perhaps the author [ae] finally decided to re-sign it to suit the newer SketchUp versions, but the code was otherwise unchanged ?
Global Moderator
Previous
Return to Plugins
Users browsing this forum: creystl, mugdha1234 and 19 guests
