[Plugin] FullScreen v5.1.1 (12 September 2021)
Postby Anton_S » Mon Jan 30, 2012 10:55 am
Showcase
New UI based on React and Material UI with light and dark themes.
Features
  • Click-and-drag UI by caption
  • Expand/collapse by clicking the caret at the upper-left corner
  • Snap UI to the edges of the viewport window (e.g by dragging to one of the view border)
  • Fade and unfade effects. If no cursor is present in the UI, the UI fades out - becomes semi transparent.
  • Switching full screen now has 3 modes:
    1. Primary: set full screen on main monitor
    2. Associated: set full screen on the monitor the sketchup window is associated with
    3. All: set full screen on all monitors by computing the bounding box all monitors and using that box as the new dimensions of the window.
Requirements
  • SU2016 - SU2021 (tested on SU2020) Compatibility for SU6 - SU2015 will be added soon.
  • Windows operating system only! This will not work with Mac OS X.
  • Since v5.0.0, AMS Library no longer needed.
Download
Download at the SketchUcation PluginStore: https://sketchucation.com/pluginstore?p ... owSettings
16
Anton_S
PluginStore Author
PluginStore Author
Re: [plugin] Window Style
Postby Gaieus » Mon Jan 30, 2012 11:59 am
Wow... :shock:
Some notes (using Windows XP on this machine):
  1. First I was confused until I figured that
    • hiding the toolbars hides floating toolbars
    • and hiding the control bars hides the parts of the SU window where the docked toolbars are.
  2. There is already a menu item under Window > "Hide dialogs/Show dialogs" - so your "Child windows" option here is a redundant duplicate.
  3. When I hide the status bar, any VCB entry still works. This is a pretty good function! :thumb:
All in all, a very useful plugin - especially (for me) the "control bars" hiding function. Thank you very much! :thumb: :thumb: :thumb:
I have long wished to be able to hide my (what is here called) "control bars" so that when making tutorial videos or teaching SU online, they do not confuse and scare away beginners. :D
User avatar
Postby Rich O Brien » Mon Jan 30, 2012 12:09 pm
Doesn't work on my Win7 64bit. Only Child Windows will toggle. I got toolbar chaos on install.
Nice concept though :thumb:
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby Gaieus » Mon Jan 30, 2012 12:15 pm
Rich O'Brien wrote:Doesn't work on my Win7 64bit.
Too bad. Hopefully it can be fixed (as it works on my 32 bit XP). My laptop (with, of course, a much smaller screen where I could use it better than on my 22" desktop monitor) is 64 bit Win 7.
Would there be a possibility to (instead of having a separate menu item to show and display the different elements) toggle them on/off? This would also allow to assign a single shortcut instead of two, different ones.
User avatar
Postby Gaieus » Mon Jan 30, 2012 1:37 pm
This is better than I thought. Here is what I did:
  1. Hid the control bar (with the docked toolbars - I only have them on the top in several rows)
  2. resized my window to extremely narrow (all toolbars by now would have been cluttered) - even narrower than my widest toolbar is - in fact, even the menu jumped into two rows now :shock:
  3. resized my window back to a safe width (where all my toolbars can fit)
  4. unhid my control bar and nothing was cluttered!
:sketchstatic:
Thank you again - and really hope that those compatibility issues can be solved!
User avatar
Postby Anton_S » Mon Jan 30, 2012 9:32 pm
Rich O'Brien wrote:Doesn't work on my Win7 64bit. Only Child Windows will toggle. I got toolbar chaos on install.
Yes, I knew it didn't work on win7 64 bit... Tested on my brothers laptop. I'm gonna mess with his laptop for a while and figure out a way.
Anton_S
PluginStore Author
PluginStore Author
Postby Rich O Brien » Mon Jan 30, 2012 9:38 pm
That'd be great :thumb:
User avatar
Rich O Brien
Administrator
Postby Vicspa » Mon Jan 30, 2012 9:56 pm
Yeah, that'd be great, thanks
Vicspa
Postby Anton_S » Mon Jan 30, 2012 10:08 pm
Gaieus wrote:There is already a menu item under Window > "Hide dialogs/Show dialogs" - so your "Child windows" option here is a redundant duplicate.
No, its not. The "hide dialogs" hides windows such as entity info, model info, soften smooth edges, but doesn't hides ruby console, photo textures, component options, and other child windows with a certain class that could be hidden.
Gaieus wrote:Would there be a possibility to (instead of having a separate menu item to show and display the different elements) toggle them on/off? This would also allow to assign a single shortcut instead of two, different ones.
It depends. Lets, say we have a "status_bar" option toggled. Checked: visible and Unchecked: hidden. And something happens: The user hides the status_bar using the other script. How would "status_bar" option know whatever it should be checked or unchecked? - Well, use set_validation_proc and let it ask every frame whatever the status_bar is hidden or not. I could make it like that, thought it will slow down sketchup:
Dan wrote:Menu.set_validation_proc
Arguments:
    menu_id: The id of a menu item on this menu. (The id is returned from the add_item method.)
    block_proc: a block or proc object that will be invoked by Sketchup went it redraws the UI. (Complex conditionals and calling many other methods can slow down Sketchup!)
I could make it toggable, but its ur option: yes or no :)
Anton_S
PluginStore Author
PluginStore Author
Postby Gaieus » Mon Jan 30, 2012 10:43 pm
Anton_S wrote:No, its not. The "hide dialogs" hides windows such as entity info, model info, soften smooth edges, but doesn't hides ruby console, photo textures, component options, and other child windows with a certain class that could be hidden.
Okay, point taken (and I do understand this).
Anton_S wrote:It depends. Lets, say we have a "status_bar" option toggled. Checked: visible and Unchecked: hidden. And something happens: The user hides the status_bar using the other script. How would "status_bar" option know whatever it should be checked or unchecked? - Well, use set_validation_proc and let it ask every frame whatever the status_bar is hidden or not. I could make it like that, thought it will slow down sketchup:
Point also taken (although I do not understand this)
Anyway, great plugin. Thanks a lot again! :thumb:
I (mainly) use it to hide my "control bars" - although from now on, I may also have some (less frequently used) toolbars also open (or hidden this way).
And of course for my 64 bit, Win 7 laptop, the (hopefully easily) updated version will also be welcome! :)
User avatar
Postby Aerilius » Tue Jan 31, 2012 12:49 am
I've been waiting to hide the menu bar (no joke). Thank you!
Aerilius
PluginStore Author
PluginStore Author
Postby Anton_S » Tue Jan 31, 2012 5:13 am
Anton_S wrote:use set_validation_proc and let it ask every frame whatever the status_bar is hidden or not. I could make it like that, thought it will slow down sketchup
Have to take my thought back. I thought that set_validation_proc updates every frame, but it only updates once you entered the submenu that contains that item. So, yes I'll modify it to be toggled, including make it work on windows 7 64 bit.
Thankyou for your replies!! They make me :)
Anton_S
PluginStore Author
PluginStore Author
Postby derei » Tue Jan 31, 2012 1:08 pm
What exactly this plugin does? From Rich O'Brien's post (download/file.php?id=81834&mode=view) I understand that it doesn't work... so let me rephrase: what this plugin SHOULD do?
Thank you very much.
P.S. - when posting plugins, it would be nice to add a image/animated GIF/movie to visually exemplify what the plugin does, if possible. Some users are already doing this, but I think it should be implemented as a "must" rule, for everybody.
DESIGNER AND ARTIST DEREI.UK
User avatar
derei
Postby thomthom » Tue Jan 31, 2012 1:15 pm
dereeei wrote:I understand that it doesn't work...
...on his system. For Gaieus it worked.
User avatar
PluginStore Author
PluginStore Author
Postby Aerilius » Tue Jan 31, 2012 1:18 pm
This plugin allows to turn off (or on) certain elements of the SketchUp interface. Something that wasn't possible before. For example someone has no need for a statusbar, or to make SketchUp fullscreen for a presentation. Maybe Anton can make a little gif animation for the first post (or I could do one).
Aerilius
PluginStore Author
PluginStore Author
Postby Rich O Brien » Tue Jan 31, 2012 1:22 pm
Please do. One of us can add it to Anton's OP for those that want to visualise its use.
User avatar
Rich O Brien
Administrator
Postby Aerilius » Tue Jan 31, 2012 8:41 pm
I've created an animated gif of how it looks:
Aerilius
PluginStore Author
PluginStore Author
Postby Anton_S » Wed Feb 01, 2012 12:12 am
Aerilius wrote:I've created an animated gif of how it looks:
Aerilius, thankyou really much!!! :) I'm just too lazy to add description myself.
Anton_S
PluginStore Author
PluginStore Author
Postby Rich O Brien » Wed Feb 01, 2012 12:12 am
I wanna play :(
User avatar
Rich O Brien
Administrator
Postby guanjin » Wed Feb 01, 2012 8:54 am
Great, my Windows XP
There is a problem, set the shortcut key to display the menu bar is invalid :roll: :roll:
User avatar
guanjin
Postby Anton_S » Wed Feb 01, 2012 9:54 am
guanjin wrote:Great, my Windows XP
Yes, it should be invalid!!! Wanna know why? Well, I explained it a bit on first post. Its just the way of how shortcut pereferences works. Shortcut Pereferences script tends to select the menu bar items once the shortcut key is pressed. But, When the menu it self is no more there, Sketchup can no longer select the items. What's weird is that once u hide the menu bar other shortcuts that were set by sketchup (Ex: "s" - scale, "p" - push) work, but once u click the shortcut that belong to "show menu bar," all shortcuts stop working. Show/hide menu bar was just for fun, so yeah don't use it. Though, I'll try to fix that issue too.
Anton_S
PluginStore Author
PluginStore Author
Postby guanjin » Wed Feb 01, 2012 10:18 am
Thank you! Can not be restored, the canceled, resulting in unnecessary trouble :roll:
User avatar
guanjin
Re:Win7 Patched by 4GB
Postby unclex » Wed Feb 01, 2012 8:04 pm
only fullscreen can work
and
suggest to change the plugin menu from “Plugins” to “Window"
unclex
Re: Re:Win7 Patched by 4GB
Postby Anton_S » Thu Feb 02, 2012 12:10 am
unclex wrote:only fullscreen can work"
Is that about the updated or the first version?
Anton_S
PluginStore Author
PluginStore Author
Re: [plugin] (updated February 1, 2012) Window Style
Postby unclex » Thu Feb 02, 2012 7:24 am
updated
@ SU8.0.11
@ win7 pro patched 4GB
unclex
Postby Anton_S » Fri Feb 03, 2012 2:13 am
unclex wrote:updated
@ SU8.0.11
Is it 32 or 64 bit processor?
Anton_S
PluginStore Author
PluginStore Author
Postby Anton_S » Sat Feb 04, 2012 6:06 pm
A bit better version of window settings. Its now better at updating the window and placed inside window/settings/. Can anyone check if it works on windows 7? If it would then I'll make it as a main update.
Edit: See first post to download
Anton_S
PluginStore Author
PluginStore Author
Postby unclex » Sat Feb 04, 2012 8:23 pm
WellDone
Win7X86Pro
Su8.0.11Pro
except Toolbar, all worked
and i can not dare try the Menu Option, if i close it, how reopen it ??
unclex
Postby Anton_S » Sat Feb 04, 2012 10:30 pm
unclex wrote:WellDone
Win7X86Pro
Su8.0.11Pro
The toolbars option is to hide toolbars that are not embedded into SU controll bar, meaning the onece that have a border and caption. They should work.
And yes, hide menu option is just for fun, There is no way of unhidding it through shortcut pereferences. Though you could set a timer or call a command to unhide it. Just read throuh posts and you'll figure it out.
Have you checked if show/hide "controll bars" work when SU is maximized or full_screen? If didn't, then can you please check that and reply.
Anton_S
PluginStore Author
PluginStore Author
Re: [plugin] (updated February 10, 2012) Window Settings
Postby Anton_S » Sat Feb 11, 2012 5:46 am
updated february 10th, 2012
Now works on windows 7 too!!! Well, read the 1st post for an info. ;)
Thankyou, for your replies and comments!!! They really improved the plugin plus my English. :D
Somehow, therefore, I don't strugle at the english essays anymore... :!: :berserk: :ecstatic:
Anton_S
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
Who is online
Users browsing this forum: sasr0007 and 25 guests
