[Plugin] Slicer5
Re: [Plugin] Slicer5
Postby Ahmed0007 » Fri Jan 25, 2019 5:50 pm
Pre Slotted works fine. its not update after changing.
i explain in previous gif
Ahmed0007
Postby Ahmed0007 » Fri Jan 25, 2019 6:00 pm
Ahmed0007
Postby TIG » Fri Jan 25, 2019 7:11 pm
Thank you.
Now I see your issue.
I'll investigate further...
Global Moderator
Postby Ahmed0007 » Fri Jan 25, 2019 7:18 pm
Thank you for your Time.
i also noticed another issue
Bug Splat when i try to export dxf with 2d text References
(without text it's works fine and fast)
Ahmed0007
Postby TIG » Fri Jan 25, 2019 7:55 pm
I think I've fixed the issue with the 'Add-Slot' tool failures...
Here's v6.0...
Download
Note that you can still only use this tool once on any 'un-slotted' set of parts...
Global Moderator
Postby Ahmed0007 » Fri Jan 25, 2019 8:36 pm
:-o :shock: Amazing Thank you soooooo Much.
Ahmed0007
Postby max444 » Tue Feb 26, 2019 11:40 pm
Hey TIG, awesome plugin here. I'm pretty new to sketchup but I decided it was what I needed to do what I'm trying to do so I'm working through it well. Quick question - I got my model sliced and ready but I'm having issues with the PNG export. It seems to save the background only, regardless of what setting I'm using to view the slices. I've tried wireframe and shaded ect. not sure what I'm missing here? Thanks again!
max444
Postby boramille » Wed Jul 10, 2019 6:21 pm
After It finished sliding, I can not see my object and everything in the file. Can anyone tell me how to get my object back?
boramille
Postby TIG » Wed Jul 10, 2019 7:21 pm
Run it with the Ruby Panel open and report error messages, if any...
Assuming that it has worked - use the Layers-Panel to switch your layers’ visibility on/off - the original object that you chose to slice is reassigned to layer “SLCR-HIDN”, which is then ‘hidden’, so you can see the results clearly…
Other layers used by the various slices also have names that start “SLCR-…”, so you can also toggle these on/off as needed…
Global Moderator
Postby Dave R » Wed Jul 10, 2019 7:28 pm
You might also try Zoom Extents.
Global Moderator
Postby boramille » Wed Jul 10, 2019 7:59 pm
TIG wrote:Run it with the Ruby Panel open and report error messages, if any...
It is still not appear when I already switch the visibility on.
boramille
Postby TIG » Wed Jul 10, 2019 10:15 pm
Please re-post, attaching the SKP files, 1 before your slice it and 2 after you slice it.
So we can look at the possibilities...
Global Moderator
Postby alexakaczor » Fri Oct 11, 2019 9:02 pm
Is it possible to get this for sketchup 2019?
alexakaczor
Postby Dave R » Sat Oct 12, 2019 4:01 pm
alexakaczor wrote:Is it possible to get this for sketchup 2019?
Yes. It already is compatible with SU2019. Right here: https://sketchucation.com/pluginstore?pln=TIG_Slicer
Install the Sketchucation Extension Store tool and let it install Slicer and other extensions for you directly.
Global Moderator
Postby alexakaczor » Sun Oct 13, 2019 11:47 pm
Is it possible to get this updated to be compatible with SKP 2019?? Thanks!
alexakaczor
Postby Dave R » Mon Oct 14, 2019 12:13 pm
alexakaczor wrote:Is it possible to get this updated to be compatible with SKP 2019?? Thanks!
It already is compatible with SU2019. I just made an example in SU2019 to show you.
Global Moderator
Postby Nudornn » Tue Feb 04, 2020 3:36 am
thxxxxxxxxxxx
Nudornn
Previous
Return to Plugins
Users browsing this forum: 7axixdesigns, osmuth, Wassnan and 11 guests
