[Plugin] FredoTools - v4.5a - 02 Apr 24
how to download
Hello there,
When I try to download FredoTools it says "the file doesn't exist". I already have LibFredo6 installed. Am I doing something wrong?
Cheers.
Gabriela -
The link Fredo gave in that recent post is to the main page that outlines the tool's many functions.
Clicking on the red-button on the right starts the download process - you might need to login to the PluginStore first to allow this.Alternatively search in the PluginStore directly, and download its RBZ from there...
@gabichiele said:
Hello there,
Cheers.
GabrielaThere was a glitch in the matrix last night and the server holding the rbz files decided to go on holidays.
It came back early this morning looking tanned, relaxed and ready for a fight
@rich o brien said:
@gabichiele said:
Hello there,
Cheers.
Yay! That's wonderful, thank you!
Hello there,
I have the latest version of FredoTools-v 4.3a and lately the plugin ThruPaint stopped working correctly. It seems like "it is running" but the icons are invisible. It only shows the plugins toolbars background. Here is also the screenshot of the toolbar. I tried to check for any updates, see if that might be the solution of this, but "Check Fredo6 Plugins for update" window is not opening as well. Thanks for any advice in advance.
@veronikalietavova said:
Hello there,
Could you please open the Ruby Console before launching the tools and advise whether there are error messages displayed.
Will we See Fredo-Plugins for Ketchup on iPad ever?
(it is more a hope than a believe)
@sirflor said:
Will we see Fredo-Plugins for Sketchup on iPad ever?
It's more a conjecture....
Two possibilities:...when Ipad and other web versions of SketchUp support plugins. But also, this assumes that I write the plugins in this framework, whcih would likely be very different of the Ruby-based environment of Sketchup desktop.
- Trimble integrates the features within Sketchup Ipad and Web.
Some features not working.
- Elements Stats (shows the frames but not the texts)
- Report on Areas
- Label with Areas
Fredo6 Fredo Tools 4.3a - 03/06/22
SketchUp Pro 2022.0.354 64-bit
Windows 10 Pro 22H2The "Fredo Tools - Elements Stats - appearance.png" attached file is a printscreen of how it is working on my SketchUp test file (TESTE.skp).
The others one are about versions of SketchUp and Fredo Tools.
![How "Elements Stats" feature appears to me.](/uploads/imported_attachments/yKjf_FredoTools-ElementsStats-appearance.png "How "Elements Stats" feature appears to me.")
- Report on Areas
- Label with Areas
Could you upgrade to LibFredo6 v13.6a. This should solve the problem.
Dear Fredo:
Hi, I would like to know if the license perpetual/ one time purchase? "Fredo6Bundle2022 - A bundle of 8 plugins"
The licenses, including those in the bundle are perpetual, and only need to be purchased once.
Each license also lets you validate it on up to three different computers, so for example, you can use it at your home, in the office and on a laptop... -
NEW RELEASE: FredoTools v4.4a - 13 Nov 23
Requirement: LibFredo6 v12.5a or above
FredoTools 4.4a fixes a bug in SolidVolume, whereby the volumes of scaled objects could be mis-computed. It also adds the capability to compute the volume of pusedo-solids.
See FredoTools plugin home page for Download.
See also main post of this thread for User Discussion.
Surface on tools stopped working on SU 2023. I see on the site that I can use the normal TOS for later versions of SU but can't seem to find a link for that. Really need that plugin to work on a project.
Tools on Surface is working fine for me in SketchUp 2023. Share your .skp file so we can see what you are working with and what might be causing the problem.
File is attached. I re-downloaded the RBZ and license file, removed p[lug-in and re-added back. I don't see a place to use the license file and the plug-in is not complaining that a license was not found.
In addition, while checking my sketchucation license status it shows Tools On Surface as 0/3 as if it was not licensed. Maybe that's the issue?
You need to save the license file[s] somewhere sensible - I use a special licensing folder in my Documents.
Then you validate the license for that extension by using the validate button etc in the Tools > Fredo6 Collection > ExtensionName > License... submenu for that extension, which opens a dialog...
