I invite for acquaintance with Russian plug-in
• Page 2 of 3 • 1, 2, 3
Re: I invite for acquaintance with Russian plug-inthanks for the update. But still generates the same error, when using the tool "tube":
Error: #<ArgumentError: Not enough edges - at least 3 required> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:569:in `add_face' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:569:in `cp_create_pipe_geometry' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:110:in `onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:247 you can fix it? I use: windows xp in Spanish sketchup 8 pro in Spanish Re: I invite for acquaintance with Russian plug-inI receive the following error code after installing.
Thanks you in advance for your help. Ken Fight like your the third monkey on Noah's Ark gangway.
You must copy the file "iconv.so" in the folder: windows/system32 Re: I invite for acquaintance with Russian plug-inJorge
Will thanks for the advice, however I still have the same error code. Ken Fight like your the third monkey on Noah's Ark gangway.
hmm ... very strange ... I was not able to repeat that mistake, I can recommend: Line number 569 is:
Try replacing the line number 557:
on the line
or if not, then the line
language is not involved, but rather a problem of API in your version of SketchUP, although the design:
works with the version of SketchUp 6.0+, can you have an earlier version, not 8.0 PRO? in a previous version of the plug CoolPipe 1.2.0 you have the same problem was, nobody else it is not repeated Re: I invite for acquaintance with Russian plug-inThis solution does not work.
the list of error: Error: #<ArgumentError: Not enough edges - at least 3 required> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:570:in `add_face' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:570:in `cp_create_pipe_geometry' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:110:in `onLButtonDown' Error: #<NoMethodError: undefined method `bounds' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/ReducerTool.rb:90:in `creategeometry' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/ReducerTool.rb:67:in `onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:570 Error: #<NoMethodError: undefined method `bounds' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/TeeTool.rb:90:in `creategeometry' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/TeeTool.rb:68:in `onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/ReducerTool.rb:90 Error: #<NoMethodError: undefined method `bounds' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90:in `creategeometry' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:67:in `onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/TeeTool.rb:90 Error: #<NoMethodError: undefined method `bounds' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90:in `creategeometry' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:67:in `onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90 Objeto elegido CoolPipe = Error: #<NoMethodError: undefined method `[]' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:594:in `getparams_frompipe' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:327:in `reset' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:296:in `initialize' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:3070:in `new' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:3070:in `cp_edit_coolpipe_elements' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:21:in `cp_add_toolbar_button' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90:in `call' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90 Error: #<NoMethodError: undefined method `layer' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67:in `onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:594 Error: #<NoMethodError: undefined method `layer' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67:in `onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67 Error: #<NoMethodError: undefined method `length' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2819:in `cp_get_length_tube' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2931:in `generate_CoolPipe_specification' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2925:in `each' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2925:in `generate_CoolPipe_specification' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:25:in `cp_add_toolbar_button' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67:in `call' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67 Re: I invite for acquaintance with Russian plug-intry: face = entities.add_face( circle.edges )
Re: I invite for acquaintance with Russian plug-inThat's right, because you're not going to work. This plugin is targeted to the appropriate users. You have added a new document and a new tube without any parameters, of course anything you do will not work. The parameters necessary to specify everything: nominal diameter, outside diameter, wall thickness, the name of the pipeline, etc. All that is required.
So that promote your cause, or assist in the development or discourage new users Re: I invite for acquaintance with Russian plug-inPlease bring a list of documents for which you want to add elements. Now used only 2 Russian document on the piping. If you write a number of documents that you use and you can download them somewhere, I'll add them to the database to avoid similar mistakes.
i use x64 windows and i had the same problem copied iconv.so and iconv.dll to win2, wow64, sketchup plugins and coolpipe folders don't know which worked out but it's working
Re: I invite for acquaintance with Russian plug-inWell which one of those paths are in the $LOAD_PATH array ??
I can not open the page, to download, why not posted on the website I come from China, is to learn
Coolpipe.ru site - located in the ucoz.com - if none of the sites of ucoz you can not read - then the problem is with your provider. Re: I invite for acquaintance with Russian plug-in
Finally downloaded, loaded error I come from China, is to learn
in the file that you changed - Error! you must: "沿线 管道 目录 列表, replaced by "沿线 管道 目录 列表", should work Re: I invite for acquaintance with Russian plug-inSuccessfully translated into Chinese, but has not been used successfully, the of plumbing tools?
![]() ![]() ![]() I come from China, is to learn
Normative documents only Russian. To broaden the base of the elements - I need to know what documents you use. They are very much, all I add one can not afford Re: I invite for acquaintance with Russian plug-in
I do not know that you mean ,the file is a common indoor plumbing components I come from China, is to learn
Re: I invite for acquaintance with Russian plug-inI also do not understand what you want)))
Re: I invite for acquaintance with Russian plug-inI will say this: I have now developed a new version of the plugin, which will not appear on [iconv] and [web dialogues]. The most interesting thing to come, as the plugin will look - still a secret. When will the release of do not know. Work to be very much as I want to do everything in Ruby without any HTML and JavaScript
Re: I invite for acquaintance with Russian plug-inTime is now developing a new interface for plug-in.
Here is a screenshot I want to abandon HTML, JavaScript, CSV. I am looking for ways to solve problems with the database. Who share the standards DIN / EN / ISO / API / ASTM / ASME? Re: I invite for acquaintance with Russian plug-inWho shares the standards DIN / EN / ISO / API / ASTM / ASME?
For further development of the plugin. Interest standards for all items, not just on the tube. At least to start with 2 pcs. You can share the standard is not complete, but only the image and style options. Google Translator gives terrible translations))) In Russia, the translation is: "Your - my not understand")))) Re: I invite for acquaintance with Russian plug-inHello
I have tried and tried to get this program to work. I keep getting the attached error. I have the file, iconv.so in the correct directory as shown. So what is wrong, and can it be fixed? I deal with pipes diagrams and would like for this to work. So thanks in advance for your help. Ken Fight like your the third monkey on Noah's Ark gangway.
Start.rb is not finding iconv.so is what your message says, and it needs it so it reports an error.... I'm on mac, but it looks like you need to put the missing file into your plugins folder >>> iconv.so john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: I invite for acquaintance with Russian plug-inLooks like a very interesting plugin...
![]() Unfortunately I seem to share the same issue as Ken... I've never had any issue installing a plugin - before now... ![]() I even tried to copy the iconv.so to the plugins folder, but to no avail... ![]() Cheers
Kim Frederik
Re: I invite for acquaintance with Russian plug-inOK... Tried to see if I could see something in the coolpipe_Start.rb
(yep - it's dangerous when having a very limited knowledge when it comes to coding... ![]() The original code looked like this:
So I deleted the two spaces in line 62 in front of "require"
Now I get this Load Error message: Cheers
Kim Frederik
NO.. DO NOT ! It does not belong in the OS system directory !
Users browsing this forum: Google Bot, MGittens and 13 guests
