[Plugin] Bolt Maker (Final Update 7-Feb-2012)
Re: [Plugin] Bolt Maker (Final Update 7-Feb-2012)
Postby bmike » Wed Feb 22, 2012 4:54 pm
very nice...
just tested it and it will come in handy for my timber to steel connections.
i did notice that if bolt 2 components together, it will update all components in the model with the holes, regardless of if those components were part of the bolt assembly. small niggle, and something i can work around, for sure.
nice work!
bmike
Postby sdmitch » Wed Feb 22, 2012 7:47 pm
Of course that's the nature of components. Editing one changes all. Before using Bolt Maker, right click on each and choose "Make Unique". Groups don't have that problem.
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby EscapeArtist » Wed Feb 22, 2012 8:23 pm
Very nice plugin. Thank you!
EscapeArtist
Top SketchUcator
Postby bmike » Wed Feb 22, 2012 9:14 pm
sdmitch wrote:Of course that's the nature of components. Editing one changes all. Before using Bolt Maker, right click on each and choose "Make Unique". Groups don't have that problem.
agreed.
wonder if there is code that can make only the components selected when running the plugin unique, or have them downgrade to groups...
but, nice work.
bmike
Re: [Plugin] Bolt Maker (Updated 06-Oct-11)
Postby ksor » Fri Feb 24, 2012 12:50 pm
sdmitch wrote:OOPS!!!! Sorry Bolt Maker fans. Dispite what I thought was adaquate testing, I found a problem while playing around with the plugin this morning. It has been corrected and a new copy posted.
Hi younger brother !
You say it's the file is updated but where is the updated file placed ?
Best regards
KSor, Denmark
Skype: keldsor
ksor
Postby TIG » Fri Feb 24, 2012 12:56 pm
Most logical authors put the current file download-link on the first post in the tool's thread.
So look there.
It's quite easy to add a link to that very page in the post announcing the update - see most of my scripts' threads...
Global Moderator
Postby ksor » Fri Feb 24, 2012 1:02 pm
TIG wrote:Most logical authors put the current file download-link on the first post in the tool's thread.
So look there.
I allready HAVE that file - so it's OK !
But normaly you can't place a new posting as the first posting i a thread - right ?
You have to EDIT the first post
Best regards
KSor, Denmark
Skype: keldsor
ksor
Postby TIG » Fri Feb 24, 2012 1:29 pm
Correct - the author owns the first post [usually where the first download link as given]... so he can edit that post later if the script is updated.
So if the file changes he updates the script on the first page and the thread's title to suit.
The Plugins Index 'sniffer-dog' spots titles starting with [Plugin] and also notices any changes to them for version/date etc so the index is auto-updated...
Global Moderator
Postby guanjin » Sun Feb 26, 2012 4:55 pm
bmike wrote:very nice...
nice work!
Too strong
I come from China, is to learn
guanjin
Postby guanjin » Sun Feb 26, 2012 5:19 pm
First select line prompt
Edge does not belong to the selected Surface
Too strong :sketchstatic:
guanjin
Postby guanjin » Sun Feb 26, 2012 5:29 pm
guanjin
Postby sdmitch » Sun Feb 26, 2012 7:41 pm
If you would care to attach the model to your post, I will try to determine what the problem is.
If an inference has been established to an edge on another face, that can confuse things and cause this error because the inferenced point is what you get and not the point you think you are pointing at.
sdmitch
PluginStore Author
PluginStore Author
Postby guanjin » Mon Feb 27, 2012 5:09 am
sdmitch wrote:If you would care to attach the model to your post, I will try to determine what the problem is.
Thank you:sdmitch
无标题.skp
guanjin
Postby sdmitch » Mon Feb 27, 2012 4:02 pm
juanjin,
I didn't have any problem with your model. It has to be a odd coincidence that you were getting the error message. Although it is not required that all entities be components or groups, I would highly recommend it so that the plugin can better identify the selected face.
sdmitch
PluginStore Author
PluginStore Author
Postby guanjin » Tue Feb 28, 2012 6:14 am
sdmitch wrote:juanjin,
Thank you:
sdmitch
But does not affect the use, multi-select time
guanjin
Postby jumpjack » Tue Oct 01, 2013 8:01 am
This plugin looks interesting, but my english is poor and terms used to describe how a bolt is built are hard to understand...
An animated GIF like above one, but showing how to PROPERLY use the plugin, inserted into first post, would be very good.
Additionally, I read in first posts about reversed faces in the bolt: I don't know if this bug has been fixed as it is not important in virtual world... but 3 years after creation of this plugin we have now 3d printers, which complain about inverted faces! A bolt with inverted faces cannot be printed, because it appears as a hole not surrounded by any material (i.e., impossible object).
jumpjack
Postby sdmitch » Tue Oct 01, 2013 2:34 pm
Have you viewed the tutorial on my blog?
sdmitch
PluginStore Author
PluginStore Author
Postby dammerel » Tue Dec 03, 2013 7:56 am
Great plugin but how easy would it be to include an option to add a washer under the nut ?
Andrew
dammerel
Postby sdmitch » Tue Dec 03, 2013 9:18 pm
dammerel wrote:Great plugin but how easy would it be to include an option to add a washer under the nut ?
Andrew
That option already exists.
sdmitch
PluginStore Author
PluginStore Author
Postby jumpjack » Sat Apr 05, 2014 5:57 pm
Is this plugin supposed to create 3d-printable bolts? I only get plain cylinders with DRAWN threads!
And, by the way, reversed faces prevent a model from being printable.
jumpjack
Postby sdmitch » Sat Apr 05, 2014 10:48 pm
jumpjack wrote:Is this plugin supposed to create 3d-printable bolts? I only get plain cylinders with DRAWN threads!
No. They are for visual effect only.
sdmitch
PluginStore Author
PluginStore Author
Postby jumpjack » Mon Apr 07, 2014 6:57 pm
Would it be possible to build a plugin based on this sketchup template?
http://woodwork.ars-informatica.ca/sket ... eaded_bolt
jumpjack
Postby sdmitch » Mon Apr 07, 2014 9:04 pm
jumpjack wrote:Would it be possible to build a plugin based on this sketchup template?
Possible yes, but nothing I would care to tackle at the moment.
sdmitch
PluginStore Author
PluginStore Author
Postby fredposh » Thu Oct 30, 2014 2:25 pm
Excellent plugin. Saves a lot of time. Thanks!
fredposh
Postby Pants » Tue Jan 06, 2015 3:47 am
Does this plugin still work, eg with Sketchup Pro 2013? I get no signs of life, though it's installed and appears to let me enter bolt basic data per samples in original post.
Pants
Postby Box » Tue Jan 06, 2015 4:36 am
Works for me, are you using it correctly?
Postby Pants » Tue Jan 06, 2015 6:49 pm
Box wrote:Works for me, are you using it correctly?
ummm...no...thanks for the GIF covering centering, etc - it's illustrative but still leaves me guessing. Maybe I do still have a problem. (I also watched the video on developer's blog - suggests to me that something basic about my tape-measure guidelines is running in another mode or just wonky - I never get a red-crosshairs/Z-axis guideline inferred from the X/Y guidelines I can create, as it appears is... normal behavior...?)
Other than that, since the GIF runs endlessly and we can't see which tools are selected, it's maybe less than clear what's being clicked at some times, other than the obvious plugin tool selections, and where each of the two modes starts (offset vs pick-points). I assume the sequence is something like this:
select the plugin
select bolt parameters
click OK
(somehow - how?) delineate the offset in X and Y
(somehow - how?) red crosshairs appear (doesn't do that for me)
I guess either you've selected the tape-measure tool to create those guidelines and we can't see that happen, or the plugin has a built-in pick-point/guideline creating routine - and mine isn't working. So I tried to create guidelines and a pick-point using the tape-measure tool, since I see no other option. But no luck with that, either. As mentioned above, the GIF shows the Z-axis guideline appearing with one click in a magical way that I've not seen, letting the pick-point be selected with just two clicks...or so it appears. I get no red-crosshairs cursor-change under any circumstances. Hints?
Pants
Postby Box » Wed Jan 07, 2015 1:35 am
I'm sorry if it wasn't clear.
The Gif is purely the plugin, no other tools.
I generally go out of my way to show all tools used, and their toolbar, when I make a gif.
It can be quite difficult to remember to select a tool from a toolbar rather than use your normal keyboard shortcuts. In this case I did use a shortcut to activate the plugin as the menu was too far offscreen.
Pants wrote:select the plugin
click OK
Click the face to select it, click one edge, move to position the pink offset and click again to set, rinse and repeat on the second edge, center guide appears when you click to set the second offset.
Then click on the face where the bolt needs to finish.
Pick point is exactly that, pick first point, pick second point, done.
If it doesn't do this for you then there is an issue with your setup.
Is it installed correctly?
How did you install it?
Have you tried Reinstalling it?
Do you have the latest version? Not one copied from an earlier plugin folder?
Postby sdmitch » Wed Jan 07, 2015 4:51 pm
I have little if anything to add to Box's excellent illustration of how the plugin works. The initial guidelines are generated by the plugin and are always parallel to the edge selected, not oriented to the model axis. The red "X", which is the standard SketchUp tooltip, will only appear when the cursor is at the point of intersection of the third guideline and the face where the nut will be located.
sdmitch
PluginStore Author
PluginStore Author
Postby Pants » Wed Jan 07, 2015 8:30 pm
Thanks for the encouragement and handholding - I don't know what else to try.
I just now deleted the .rb from my plugins folder, then redownloaded it (version VII). The only unusual/annoying issue in the process of reinstalling it seemed familiar from previous plugin installations: I wasn't allowed to directly download it to my plugins folder, so I put it in "downloads" first, then moved it to plugins (and had to "request" administrator permission to get it to move, but that's an every-time annoyance that I expect.)
As before, the bolt parameters can be entered, but on moving the cursor to a test-slab, I get only the standard arrow-cursor, no ability to create guide lines or pick points. I'm suspecting my Sketchup installation is somehow corrupted and maybe it's time to bite the bullet and get whatever the latest version is...one other old plugin (that I often had trouble with before) also doesn't work, though ("hole on solid") and that might be more evidence of corruption.
Are plugins capable of bad interaction/incompatibility?
Pants
PreviousNext
Return to Plugins
Users browsing this forum: dirkbonn, Google Bot, kulrin, medeek, ysinoh and 15 guests
