[Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20
• Page 2 of 2 • 1, 2
[Plugin] FredoTools::ReportLabelArea - v2.0a - 19 Dec 11Dear Fredo,
your tools are fantastic, as you probably know. They are like the knifes from Switzerland. One small question: Trying to export an CSV file, I get a message: "Error in generation of CSV file". Any idea ? Best Carotis Last edited by noitac on Wed Oct 28, 2015 9:00 am, edited 1 time in total.
Re: [Plugin] FredoTools::ReportLabelArea - v2.0a - 19 Dec 11Report on Areas:
trying to "Export CSV" I get the error code: "Error in generation of CSV file: //filename.csv please help Helmut Karger Re: [Plugin] FredoTools::ReportLabelArea - v2.1a - 09 Jul 15NEW RELEASE: ReportLabelArea 2.1a - 09 Jul 15
ReportLabelArea 2.1a fixes a problem related to glued components on faces. Now, for glued components in Cut opening mode, the contact area of theopening is deducted from the area of the face. See main post of this thread for more information. Fredo
Re: [Plugin] FredoTools::ReportLabelArea - v2.1a - 09 Jul 15This update is fantastic Fredo. This issue with glued components was the only thing keeping me from using it! Thank you very much!
Re: [Plugin] FredoTools::ReportLabelArea - v2.1a - 09 Jul 15HI Fredo,
Great tool concept! - this really improves things for those of us who create Site Plans in Sketchup. But I'm having trouble using the Label Areas function. I have selected a number of faces, and the areas are being reported when I hover over each one, as well as the total area of all faces. However, the area labels (text tags?) are not appearing when I click "Label Areas". I checked layer visibility. Is there something else I can try? If you can sort this out for me I will give you a nice big donation ![]() Thanks! Re: [Plugin] FredoTools::ReportLabelArea - v2.1a - 09 Jul 15You need to:
- Click and drag to place the label - or double-click to have the label appears without lead line Fredo
Re: [Plugin] FredoTools::ReportLabelArea - v2.1a - 09 Jul 15Hello,
i would be really happy to use this pludin in SU 2017 - but was not working ![]() Error Loading File Fredo6_FredoTools.rb Error: #<LoadError: cannot load such file -- Fredo6_!LibFredo6.rb> C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/Richie/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:25:in `<top (required)>' either i was trying SU 2013 - plugin was installed, but Report on Area (which i need) was not working ![]() so i tried it on SU8 ...but there i couldnt even find the way how to instal plugin (!!) oh i am just poor unhappy user ![]() Re: [Plugin] FredoTools::ReportLabelArea - v2.1a - 09 Jul 15naah ... it works ! in SU2017 ..
but why did not developer wrote for fredoTools plugin the necessity to install also FredLib where the error window show-up ??? thank you for these plugins Re: [Plugin] FredoTools::ReportLabelArea - v3.0a - 16 Oct 19NEW RELEASE: ReportLabelArea 3.0a - 16 Oct 19
ReportLabelArea 3.0a introduces a new view and report, called Outliner, based on a hierarchical tree of groups and components in the selection or the whole model. This also work for the export to Excel. See main post of this thread for more information. Fredo
Re: [Plugin] FredoTools::ReportLabelArea - v3.1e - 02 Nov 19NEW RELEASE: ReportLabelArea 3.1e - 02 Nov 19
ReportLabelArea 3.1e introduces a more interactive flow,
It is available as of FredoTools v3.7a. ------------------------------------------- See FredoTools plugin home page for Download. See also main post of this thread for User Discussion. Fredo
Re: [Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20NEW RELEASE: ReportLabelArea 3.2a - 05 Feb 20
ReportLabelArea 3.2a introduces an evolution in the reporting by material. It takes into account the material of the container objects, which are automatically assigned to faces which have no material defined. It is available as of FredoTools v3.8b and also requires LibFredo6 v9.5e or above. ------------------------------------------- See FredoTools plugin home page for Download. See also main post of this thread for User Discussion. Fredo
Re: [Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20I can only read the 1x line at the time. (See screenshot) The only option is to export the report as a CSV in order to be able to read it. Re: [Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20There is no screenshot attached...
But can you resize the dialog window ?
Yes, I can resize the window but the table stays collapsed. Re: [Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20I don't even know if you are on Windows or Mac, which version of Sketchup.
A screenshot would also help.
Re: [Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20Same problem here, table dont resize with window
windows 10, sketchup 20.1 Re: [Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20NEW RELEASE: ReportLabelArea 3.3a - 17 May 20
ReportLabelArea 3.3a fixes issues with display and resizing It is available as of FredoTools v4.0a. ------------------------------------------- See FredoTools plugin home page for Download. See also main post of this thread for User Discussion. Fredo
