[Plugin] SUClock - v3.0a - 19 May 20 - Tracking time in SU
Re: [Plugin] SUClock - v1.8a - 13 Nov 15 - Tracking time in
Postby thevzitor » Sun May 22, 2016 11:12 am
Hello Fredo,
Thank you so much for all the Extensions you bring to us. They make our work so much more efficient.
I came across a tiny glitch with SU Clock recently and don't know why it happens. It counts certain days with much more than 24 hours giving tremendous amount of hours in the total.
Here a screenshot to show an example of 60:43:18 worked in a single day... :-)
Could it be because of shared access of the temp file (stored on dropbox) from 2 different computers ?
thanks for the insight !
thevzitor
thevzitor
Premium Member
Premium Member
Postby fredo6 » Tue May 24, 2016 9:09 am
@thevzitor,
There must be a bug somewhere, because even with 2 users, this represents a quite long day of 30 hours!!
Can you check the other statitics (by model, by tool) to see if you find similar anomalies.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby derei » Mon Jul 04, 2016 7:55 pm
By default, when choosing to save a new suclock file (start a new project), the save path opens in the same directory as the skp file. Would it be possible to set a default directory, where all suclock files are stored? Is a bit annoying to have to navigate every time on that location, for each newly started project. Having a "default path" declared would make it more convenient.
DESIGNER AND ARTIST DEREI.UK
derei
Postby thevzitor » Wed Jul 13, 2016 10:26 am
fredo6 wrote:@thevzitor,
Fredo
Hello Fredo,
Sorry for the long silence, I forgot to check the answers on the forum.
30 hours is a long day indeed but It's getting even better with days of 282 hours or 397 hours !
but I swear I stayed in this galaxy :-)
To give more precisions, I should tell you that I am the only user of these files.
The fact is I put all my work and affiliates suclock files on my Google Drive, which I access indifferently from two different computers.
When I started to see incoherences I tried to change the Directory for temporary tracker files on the SUClock startup parameters dialog, but without success. Could this come from there?
But since this bug is occurring on many of my files (even by tools) and seems worsening quite recently, I wonder
if this could be related to SUpro 2016 ?
Here are a few screenshots to give you an idea.
Thanks again. Cheers !
PS: I forgot to mention I keep all suclock files (including the temp files folder) in a folder on the Google Drive
thevzitor
Premium Member
Premium Member
Postby fredo6 » Thu Jul 14, 2016 5:06 pm
Thanks. I'll have a look to see what can break the clock.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] SUClock 1.1a - 17 Apr 11 - Tracking time in SU
Postby Sait Moore » Mon Aug 01, 2016 6:31 pm
thomthom wrote:Remember people to use the donation button. Fredo deserves it!
I'd like to, but I can't read French, so I don't know what the donate requirement are. Is it available in English for the Fredo6 donations?
Sait Moore
Re: [Plugin] SUClock - v1.9a - 16 Jan 17 - Tracking time in
Postby fredo6 » Mon Jan 16, 2017 11:16 pm
NEW RELEASE: SUClock v1.9a - 16 Jan 17
SUClock 1.9a is a cosmetic refresh of the plugin, with SU2017 certification.
See main post of this thread for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] SUClock - v1.9b - 30 Jan 17 - Tracking time in
Postby fredo6 » Mon Jan 30, 2017 8:01 pm
NEW RELEASE: SUClock v1.9b - 30 Jan 17
SUClock 1.9b fixes a major bug for Mac OSX platforms (it prevented the clock window to appear).
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby seamoo » Fri Mar 03, 2017 6:37 pm
Thanks, I'm looking forward to using this. the interface I find is a little tricky but with use....
is there anyway to get this to work with .layout files?
seamoo
Postby juju » Mon Mar 06, 2017 7:58 am
seamoo wrote:Thanks, I'm looking forward to using this. the interface I find is a little tricky but with use....
SKetchUp and Layout have different API's AFAIK, so it will mean a (C++) re-write of the plugin.
21 Sept. 2020. Please support this thread on the SketchUp forum to resolve Extension Warehouse problems. Faults being ignored is not an option.
juju
Premium Member
Premium Member
Postby SK_Man_2020 » Fri Sep 29, 2017 6:23 pm
It doesn't work for me: produces a string of error messages each time I start up SketchUp. According to the Extension Manager it is installed, but it does not appear on the "Extensions" menu. The errors are:
Error Loading File Fredo6_SUClock.rb
Error: #<LoadError: cannot load such file -- Fredo6_!LibFredo6.rb>
D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require'
C:/Users/Stuart/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_SUClock.rb:25:in `<top (required)>'
Based on that message, I assume that it must be missing the "LibFredo" library, which mentioned at the top of this page with a helpful message and link that says: "IMPORTANT: Requires to download LibFredo6 7.4c or higher if not already installed": I clicked on that link, but I get a message saying: "The requested topic does not exist.".
Bummer! This sounded like a great tool, and exactly what I need, but not much use if it doesn't work!
So please could you fix that link, or is there another way I can get that library that seems to be missing?
SK_Man_2020
Postby TIG » Fri Sep 29, 2017 6:38 pm
Have you also installed the latest LibFredo ?
https://sketchucation.com/pluginstore?pln=LibFredo6
Most of Fredo's tools need the helper files provided by his Lib.
it is clearly explained in each of his tool's installation and usage instructions.
Install it and restart SketchUp.
Any improvement ?
Global Moderator
Postby SK_Man_2020 » Fri Sep 29, 2017 7:24 pm
Thanks! That fixed it. I figured it was the missing library, but since the link at the head of this page is broken, I didn't know where to find it.
Much appreciated! :thumb:
SK_Man_2020
Postby fredo6 » Fri Sep 29, 2017 8:09 pm
SK_Man_2020 wrote:Thanks! That fixed it. I figured it was the missing library, but since the link at the head of this page is broken, I didn't know where to find it.
Which link is broken exactly?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby TIG » Fri Sep 29, 2017 9:01 pm
I just fixed it !
The LibFredo link in post-1 was foobar !!
Global Moderator
Postby fredo6 » Fri Sep 29, 2017 9:44 pm
TIG wrote:I just fixed it !
TIG,
Thank you very much.
I don't know what happened, because this seems to be the case in other main posts where I refer to LibFredo6.
EDIT: It was the case: for whatever reason, the links to LibFredo6 page were no longer valid. I updated all posts with the correct URL.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby SK_Man_2020 » Fri Sep 29, 2017 11:14 pm
Thanks everyone. It's working great now, and very useful.
Just one more question: If I have several projects open at the same time in different instances of SketchUp, each with it's own clock, will that accumulate time correctly in each one, as I switch between projects and work on each one separately? No conflicts?
SK_Man_2020
Postby fredo6 » Sat Sep 30, 2017 10:53 am
SK_Man_2020 wrote:Thanks everyone. It's working great now, and very useful.
It depends if all models belong to the same project or to different projects.
If same project, then, in principle the times should accumulate. I am interested to know, by the way.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby SK_Man_2020 » Sat Sep 30, 2017 4:23 pm
Cool! I'll do some tests over the next few days, and let you know.
The reason I ask is because I do consulting work (recording studio design), and I often have several projects from different customers all open at the same time, and during the day I spend time on each of them, which I'd obviously like to account for separately. So I'd be billing each customer only for work I did on his project, not for work that I did on someone else's project but that got added to his by mistake.
And on the other hand, I sometimes do have two projects for the SAME customer open at once (such as two versions of the same studio design, with different layouts, that he's going to choose from later) and I'd like the work done on both of those to accumulate on one single clock.
From what I see in your documentation, I should be able to do this by having a separate suclock file for each customer, and pointing all of the SKP models related to that customer to the clock that has his name on it. That should work in theory, right?
Anyway, I'll try it out like that, and like you know what happens.
This is a great tool, by the way: Thanks for making it!
SK_Man_2020
Postby Rich O Brien » Sat Sep 30, 2017 8:12 pm
Looks like our URL fixing last week has f-ed up things again :oops:
Will look again Monday
Rich O Brien
Administrator
Postby TIG » Sat Sep 30, 2017 8:17 pm
I think Gábor has now resolved his self-inflicted injury !
All should now work everywhere, just as it should...
Global Moderator
Postby thevzitor » Mon Oct 02, 2017 5:16 pm
"And on the other hand, I sometimes do have two projects for the SAME customer open at once (such as two versions of the same studio design, with different layouts, that he's going to choose from later) and I'd like the work done on both of those to accumulate on one single clock"
SK man 2020:
Yes you can choose to create a different SU clock counter for each project, and even if you have multiple projects windows opened (if you have enough RAM), the clock will adjust to the front window project timer. That's the greatness of this tool (thank you Fredo!) On the other hand if you have two projects for the same client, you can choose to add the timer of your second project to the first one already created. It does appear on the dialog when you create a new clock. You have the choice to create a completely new clock or affect the timer to an existing clock. Usually you have the list of the most recently active clocks/projects and you can choose with one click to add your new timer to an existing one.
Hope this is clear enough (?) Cheers
thevzitor
Premium Member
Premium Member
[Plugin] SUClock - v1.9c - 12 Nov 17 - Tracking time in
Postby fredo6 » Sun Nov 12, 2017 3:22 pm
NEW RELEASE: SUClock - v1.9c - 12 Nov 17
SUClock 1.9c fixes a bug for the CSV export in non-English languages.
See SUClock plugin home page for Download.
See also main post of this thread for User Discussion.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] SUClock - v1.9b - 12 Nov 17 - Tracking time in
Postby jdcamc » Wed Jul 04, 2018 1:01 am
I'm having trouble getting the clock to work is sketchy 2018 pro. Here's a screenshot of the message I'm getting. I am assuming it's not available for 2018? Thanks! I have the latest version 1.9c.
jdcamc
Postby fredo6 » Wed Jul 04, 2018 7:10 am
jdcamc wrote:I'm having trouble getting the clock to work is sketchy 2018 pro. Here's a screenshot of the message I'm getting. I am assuming it's not available for 2018? Thanks! I have the latest version 1.9c.
A SUClock project file has extension .suclock, not skp.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby jdcamc » Wed Jul 04, 2018 1:25 pm
Here's a video of what it is doing. No matter which route I take, I get the same results - that the project file is invalid. I'm not sure what that means or why the sketchup file is considered invalid. I'm wondering if it has something to do with the sketchup file being 2018 version.
SUClock.mov
jdcamc
Postby fredo6 » Wed Jul 04, 2018 5:22 pm
@jdcamc
The SUClock information is saved in files with extension .suclock. This is independent from the Sketchup models, since several models can be attached to a SUClock 'project'.
In your case,
1) To track time for a model, you need to create a SUClock project. So use "Attach to New Project", and give it a unique name (in the video, you select an existing skp file instead). This will create the information file with extension .suclock
2) Once you have a SUClock project, you can attach a model to it by "Attach to an existing project", where you select the .suclock file.
There is a documentation on SUClock where you have the details and explanations on other use cases too.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby jdcamc » Wed Jul 04, 2018 8:49 pm
It is working now. For some reason it would not give me the .suclock extension when I first tried I, just the error message stating the file was invalid. Now it does give me the .suclock extension. Thanks for you help!
jdcamc
Re: [Plugin] SUClock - v2.0a - 31 Oct 18 - Tracking time in
Postby fredo6 » Wed Oct 31, 2018 9:40 pm
NEW RELEASE: SUClock v2.0a - 31 Oct 18
SUClock 2.0a provides bug fixing.
See plugin page of SUClock for information and download.
See main post of this thread for discussion.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby simMonster » Sat Dec 29, 2018 8:56 pm
Is it possible to modify your code to allow your plugin to determine the time spent on an older sketchup file? I am very anxious to hear from you.
simMonster
PreviousNext
Return to Plugins
Users browsing this forum: Bing [Bot], Wermerson and 10 guests
